Network
lwip总算ping通了
发布于 2019-01-20 21:28:59 浏览:2665
![ping 通.png](/uploads/201901/20/212011z63up1cmkkhx17g7.png)感谢@aozima @whj467467222 @summer_gift 几位大佬的热心帮助,总算成功Ping通!但是还有一个问题,我要怎么将我的tcpserv函数导入到shell中?输入help之后我的tcpserv还是没有shell命令,是我的操作方式不对吗? ![7.png](/uploads/201901/20/212714ynx90ni3onn4paii.png) 应该怎么样将它导入?下面是我的tcpserv函数 ```static const char send_data[] = "This is TCP Server from RT-Thread!
"; /*发送用到的数据*/ void tcpserv(void){ char *recv_data; /*用于接受用的指针, 后面会做一次动态分配以请求内存 */ rt_uint32_t sin_size; int sock, connected, bytes_received; struct sockaddr_in server_addr, client_addr; rt_bool_t stop = RT_FALSE; /*停止标志*/ recv_data = rt_malloc(1024); /*分配接收用的数据缓冲*/ if(recv_data == RT_NULL){ rt_kprintf("No Memory!
"); return; } /*一个socket在使用之前,需要先预先创建出来,指定SOCK_STREAM为TCP的socket */ if((sock = socket(AF_INET, SOCK_STREAM, 0)) == -1){ /*创建失败的错误处理*/ rt_kprintf("socket error!
"); /*释放已经分配的接收缓存*/ rt_free(recv_data); return; } /*初始化服务器地址*/ server_addr.sin_family = AF_INET; server_addr.sin_port = htons(5000); /*服务器工作的端口*/ server_addr.sin_addr.s_addr = INADDR_ANY; rt_memset(&(server_addr.sin_zero), 8, sizeof(server_addr.sin_zero)); /*绑定socket到服务端地址*/ if(bind(sock, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)) == -1){ /*绑定失败*/ rt_kprintf("Unable to bind!
"); /*释放已经分配的缓存*/ rt_free(recv_data); return; } /*在socket上进行监听*/ if(listen(sock, 5) == -1){ rt_kprintf("listen error!
"); /* release recv buffer*/ rt_free(recv_data); return; } rt_kprintf("
TCPSever waiting for client on port 5000..
!"); while(stop != RT_TRUE){ sin_size = sizeof(struct sockaddr_in); /*接受一个客户端连接socket的请求,这个函数调用时阻塞式的*/ connected = accept(sock, (struct sockaddr *)&client_addr, &sin_size); /*返回链接成功的socket*/ /*接收返回的client_addr指向客户端的地址信息*/ rt_kprintf("I got a connection from (%s, %d)
", inet_ntoa(client_addr.sin_addr), ntohs(client_addr.sin_port)); /*客户端连接的处理*/ while(1){ /*发送数据到connected socket*/ send(connected, send_data, strlen(send_data), 0); /*从connect socket中接收数据,接收buffer是1024大小,但并不一定能够收到1024大小*/ bytes_received = recv(connected, recv_data, 1024, 0); if(bytes_received <= 0){ /*接收失败,关闭这个connected socket*/ lwip_close(connected); break; } /*接收到数据,把末端清0*/ recv_data[bytes_received] = '\0'; if(strcmp(recv_data, "q") == 0 || strcmp(recv_data, "Q") == 0){ /*如果首字母是q或者Q,关闭这个连接*/ lwip_close(connected); break; } else if(strcmp(recv_data, "exit") == 0){ /*如果接收的是eixt,则关闭整个服务器*/ lwip_close(connected); stop = RT_TRUE; break; } else{ /*在控制终端显示收到的数据*/ rt_kprintf("Received Data = %s
", recv_data); } } } /*退出服务*/ lwip_close(sock); /*释放接收缓存*/ rt_free(recv_data); return; } #ifdef RT_USING_FINSH #include
/*输出tcpserv函数到finsh shell中*/ FINSH_FUNCTION_EXPORT(tcpserv, startup tcp server); #endif```
2019-01-21
看来有必要同时提供msh和finsh的命令才行。 楼主使用 MSH_CMD_EXPORT 来导出命令。
chenghaiyang
2019-01-21
>看来有必要同时提供msh和finsh的命令才行。 >楼主使用 MSH_CMD_EXPORT 来导出命令。 ... --- 好的谢谢
chenghaiyang
2019-01-21
>看来有必要同时提供msh和finsh的命令才行。 >楼主使用 MSH_CMD_EXPORT 来导出命令。 ... --- 成功导出到了shell中,谢谢帮助。[attach]7295[/attach] 但是我在使用网络调试助手连接我的tcpserv的时候,连接不上,选择的是TCPclient模式,IP正确。 [attach]7297[/attach] 下方会出现这样的提示信息:[attach]7298[/attach] 我使用了wireshark进行抓包,结果如下: [attach]7296[/attach] 请问,为什么我的问题出在什么地方啊?
2019-01-21
netstat看看,另外检查下 rtconfig.h的连接数和socket/fd数量是否足够
chenghaiyang
2019-01-21
>netstat看看,另外检查下 rtconfig.h的连接数和socket/fd数量是否足够 --- netstat之后是这样一个情况: [attach]7301[/attach] 连接数是这些吗? [attach]7302[/attach]
2.7k
chenghaiyang
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
