Network
组播收不到数据
发布于 2019-03-19 17:17:31 浏览:2503
1、硬件:正点原子阿波罗F429 2、想实现接受来自239.255.255.1 的多播数据,程序在linux可用,但是移植到到RT-Thread调试了很久都没有结果,希望有大兄弟能指点一下迷津 下面是我在调试过程中在网上找的一些参考资料: STM32F4板子使用LWIP进行组播收发数据的完整过程,附代码 [_https://blog.csdn.net/xueyushenzhou/article/details/51381466_](https://blog.csdn.net/xueyushenzhou/article/details/51381466) 基于stm32f107 stm32cube 和 LWIP 协议实现 udp 组播通信 [_https://blog.csdn.net/zhanglifu3601881/article/details/85080907_](https://blog.csdn.net/zhanglifu3601881/article/details/85080907) 附件一直上传不成功,稍后上传 代码版本1的截图(内容同附件1): void udpclient(int argc, char **argv) { int recv_sock; int str_len; char buf[BUF_SIZE]; struct sockaddr_in adr; struct ip_mreq join_adr; //多播组结构体 if(argc != 3) { //rt_kprintf("Usage : %s
< ![25,25](file:///C:\Users\YEJIAS~1\AppData\Local\Temp\ksohtml7992\wps1.png) ort>
", argv[0]); return; } recv_sock = socket(AF_INET, SOCK_DGRAM, 0); rt_memset(&adr, 0, sizeof(adr)); adr.sin_family = AF_INET; adr.sin_addr.s_addr = htonl(INADDR_ANY); adr.sin_port = htons(atoi(argv[2])); if(bind(recv_sock, (struct sockaddr *)&adr, sizeof(adr)) == -1) rt_kprintf("bind() error"); //加入多播组 join_adr.imr_multiaddr.s_addr = inet_addr(argv[1]); join_adr.imr_interface.s_addr = htonl(INADDR_ANY); setsockopt(recv_sock, IPPROTO_IP, IP_ADD_MEMBERSHIP, (void *)&join_adr, sizeof(join_adr)); 附件2的内容void udpclient(int argc, char **argv){ int bytes_read; char recv_data[BUFSZ]; socklen_t addr_len; struct sockaddr_in myAddr,client_addr; int addrlen = 0; int sock, count; int res; unsigned char loop = 1; //设置IP_MULTICAST_LOOP //设置IP_MULTICAST_TTL 为1,即该多播最多只能经过一个路由器 unsigned char ttl = 1; struct ip_mreq mreq; rt_memset(&(myAddr), 0, sizeof(myAddr)); rt_memset(&(client_addr), 0, sizeof(client_addr)); /* 创建一个socket,类型是SOCK_DGRAM,UDP类型 */ if ((sock = socket(AF_INET, SOCK_DGRAM, 0)) == -1) { rt_kprintf("Socket error
"); return; } /* 初始化预连接的服务端地址 */ myAddr.sin_family = AF_INET; myAddr.sin_addr.s_addr = INADDR_ANY; myAddr.sin_port = htons(PORT); //绑定本地套接字 /*绑定socket*/ if(bind(sock, (struct sockaddr *)&myAddr, sizeof(myAddr)) != 0) { rt_kprintf("bind error
"); return; } //设置IP_MULTICAST_LOOP /*设置回环许可*/ if (setsockopt(sock, IPPROTO_IP, IP_MULTICAST_LOOP, &loop, sizeof(loop)) != 0) { rt_kprintf("setsockopt IP_MULTICAST_LOOP error
"); return; } //设置IP_MULTICAST_TTL 为1,即该多播最多只能经过一个路由器 if (setsockopt(sock, IPPROTO_IP, IP_MULTICAST_TTL, &ttl, sizeof(ttl)) != 0) { rt_kprintf("setsockopt IP_MULTICAST_TTL error
"); return; } //对struct ip_mreq这个结构体赋值 if (argc > 1) { if ((res = inet_pton(AF_INET, argv[1], &mreq.imr_multiaddr)) == -1)//设置IP地址 { rt_kprintf("setsockopt IP_MULTICAST_TTL error
"); return; } else if(res == 0) {rt_kprintf("IP error,please scanf again<224.0.0.1 ~ 239.255.255.255>
"); return; } }else { rt_kprintf("Usage:%s (224.0.0.1 ~ 239.255.255.255)
", argv[0]); return; }//mreq.imr_multiaddr.s_addr = inet_addr("239.255.255.1"); /*广播地址*/ mreq.imr_interface.s_addr = INADDR_ANY; //将本机加入多播组中 if (setsockopt (sock, IPPROTO_IP, IP_ADD_MEMBERSHIP, &mreq, sizeof(mreq)) != 0) { rt_kprintf("setsockopt IP_ADD_MEMBERSHIP error
"); return ; } rt_kprintf("Multicast is starting,waitting for information of Multicast.....
"); addrlen = sizeof(client_addr); while (1) { rt_kprintf("wait UDP data
"); /* 从sock中收取最大BUFSZ - 1字节数据 */ bytes_read = recvfrom(sock, recv_data, BUFSZ - 1, 0, NULL, 0); recv_data[bytes_read] = '\0'; /* 把末端清零 */ rt_kprintf("%s", recv_data); /* 线程休眠一段时间 */ rt_thread_delay(50); } /* 关闭这个socket */ closesocket(sock);}
beli
2019-03-19
[https://www.rt-thread.org/qa/thread-10359-1-1.html](我的收不到数应该不是这个问题)
beli
2019-03-20
void udpclient(int argc, char **argv) { int myFd, clientFd; struct sockaddr_in myAddr, clientAddr; struct ip_mreq mreq; int addrlen = sizeof(clientAddr); char buf[MAXBUF]; char addrTemp[INET_ADDRSTRLEN]; int db_Value=0; int i,fd_pipe_w; rt_memset(&myAddr, 0,sizeof(myAddr)); rt_memset(&clientAddr, 0,sizeof(clientAddr)); //创建套接字,datagrams if((myFd = socket(AF_INET, SOCK_DGRAM, 0)) == -1) { } //设置本地地址端口信息 myAddr.sin_family = AF_INET; myAddr.sin_addr.s_addr = INADDR_ANY; if (argc == 3) { myAddr.sin_port = htons(atoi(argv[2])); } else { myAddr.sin_port = htons(PORT); } //绑定本地套接字 if(bind(myFd, (struct sockaddr *)&myAddr, sizeof(myAddr)) != 0) { } //设置IP_MULTICAST_LOOP unsigned char loop = 1; if (setsockopt(myFd, IPPROTO_IP, IP_MULTICAST_LOOP, &loop, sizeof(loop)) != 0) { return ; } //设置IP_MULTICAST_TTL 为1,即该多播最多只能经过一个路由器 unsigned char ttl = 1; if (setsockopt(myFd, IPPROTO_IP, IP_MULTICAST_TTL, &ttl, sizeof(ttl)) != 0) { return ; } //对struct ip_mreq这个结构体赋值 if (argc > 1) { //设置IP地址 int res; if ((res = inet_pton(AF_INET, argv[1], &mreq.imr_multiaddr)) == -1) { exit(errno); } else if(res == 0) { rt_kprintf("IP地址无效\n"); rt_kprintf("请输入一个多播地址:224.0.0.1 ~ 239.255.255.255\n"); return ; } } else { rt_kprintf("Usage:%s 多播地址(224.0.0.1 ~ 239.255.255.255)\n", argv[0]); return ; } mreq.imr_interface.s_addr = INADDR_ANY; //将本机加入多播组中 if (setsockopt (myFd, IPPROTO_IP, IP_ADD_MEMBERSHIP, &mreq, sizeof(mreq)) != 0) { exit(errno); } rt_kprintf("Multicast is starting,waitting for information of Multicast.....\n"); while (1) { rt_memset(buf, 0,sizeof(buf)); rt_kprintf("wait UDP data\r\n"); if (recvfrom(myFd, buf, sizeof(buf) - 1, 0, (struct sockaddr *)&clientAddr, &addrlen) == -1) { return ; } rt_kprintf(".......\r\n"); /* 线程休眠一段时间 */ rt_thread_delay(50); } //退出广播组 if (setsockopt (myFd, IPPROTO_IP, IP_DROP_MEMBERSHIP, &mreq, sizeof(mreq)) != 0) { exit(errno); } return; }
beli
2019-03-20
上面时最新代码,依旧是收不到组播数据。各种百度和论坛上找答案, 排除了以下问题 1、在rtconfig.h已经使能IGMP 2、在绑定的时候使用的INADDR_ANY
mlf_003
2019-03-21
硬件驱动修改接收所有数据
beli
2019-03-23
>硬件驱动修改接收所有数据 --- 请问是更改LAN8720的配置吗?没有找到相关资料
2.5k
beli
33
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
