closesocket
长时间运行无法联网之sal_closesocket函数的bug
发布于 2019-03-23 17:27:31 浏览:1751
即前段时间使用at socket编程实现了产品功能,现在产品在现场运行经过24小时或更长时间后,设备无法再连接服务器,打印信息显示`socket(AF_AT, SOCK_STREAM, 0)`执行失败。 经过查看相关代码发现,sal_closesocket在执行,当4G通信模块 AT指令 `“AT+CIPCLOSE”`失败时,会导致sal socket不能释放。 当发生多次这种异常后,导致程序中sock资源用尽,无法socket_alloc分配到新的socket,就出现了设备运行了很长时间后,无法分配出新`socket`,`socket(AF_AT, SOCK_STREAM, 0)`执行失败,无法连接网络的情况。解决办法如下: ```c sal_closesocket函数的修改方法(标蓝色的是修改部分): int sal_closesocket(int socket) { struct sal_socket *sock; int error = 0; sock = sal_get_socket(socket); if (!sock) { return -1; } if (sock->ops->closesocket == RT_NULL) { return -RT_ENOSYS; } if (sock->ops->closesocket((int) sock->user_data) == 0) { #ifdef SAL_USING_TLS if (SAL_SOCKOPS_PROTO_TLS_VALID(sock, closesocket)) { if (proto_tls->ops->closesocket(sock->user_data_tls) < 0) { return -1; } } #endif error = 0; } else { error = -1; } /*zhaoshimin 2019.03.23 sometimes at socket close faile should free the sock */ rt_free(sock); socket_table.sockets[socket] = RT_NULL; return error; } ``` 另外socket_alloc函数中当socket分配出最大数量st->max_socket后,程序设计的用意为再增加4个socket资源,实际程序书写有误,并没有实现这个想法,应做如下修改 ```c static int socket_alloc(struct sal_socket_table *st, int f_socket) { int idx; /* find an empty socket entry */ for (idx = f_socket; idx < (int) st->max_socket; idx++) { if (st->sockets[idx] == RT_NULL) break; if (st->sockets[idx]->ops == RT_NULL) break; } /* allocate a larger sockte container */ if (idx == (int) st->max_socket && st->max_socket < SAL_SOCKETS_NUM) { int cnt, index; struct sal_socket **sockets; /* increase the number of socket with 4 step length */ cnt = st->max_socket + SOCKET_TABLE_STEP_LEN; /*zhaoshimin 2019.03.23 add 4 sockets */ cnt = cnt > SAL_SOCKETS_NUM ? cnt:SAL_SOCKETS_NUM; sockets = rt_realloc(st->sockets, cnt * sizeof(struct sal_socket *)); if (sockets == RT_NULL) goto __result; /* return st->max_socket */ /* clean the new allocated fds */ for (index = st->max_socket; index < cnt; index++) { sockets[index] = RT_NULL; } st->sockets = sockets; st->max_socket = cnt; } /* allocate 'struct sal_socket' */ if (idx < (int) st->max_socket && st->sockets[idx] == RT_NULL) { st->sockets[idx] = rt_calloc(1, sizeof(struct sal_socket)); if (st->sockets[idx] == RT_NULL) { idx = st->max_socket; } } __result: return idx; } ``` 请rt thread的专家帮助确认是否存在这些问题。
Cheney_Chen
2019-03-23
感谢楼主的问题反馈 1. 对于第一个sal_closesocket 问题,确实存在关闭失败之后socket空间没被释放影响后续创建问题,欢迎楼主提PR修复问题,注意 sal_shutdown 和 sal_closesocket 实现一致修复时可一并修复。 2. 对于第二个问题,这里 SAL_SOCKETS_NUM 是定义的 socket 最大支持的数量,socket 数量不是无限增加的,所以这里的原来实现没有问题。楼主可以再确认一下。
杰瑞鼠
2020-12-31
2024龙行天下
我用LibmodbusTCP也是,原软件包用的时close(),但如如此会出现![image.png](/uploads/20201231/a068dbdb81acfcd76ed5b0bff5f5ac37.png) 该成closesocket(client_sock_fd);,但运行长时间后系统会崩溃,根据cmbacktrace总是跟踪到 FD_SET(server_fd, &readset);这一句 请问后来怎么彻底解决的?
1.8k
fhqmcu
60
rt-thread 2g/3g/4g通信模块的教程有吗?
基于AT指令,用esp8266如何连接mqtt?
AT组件使用问题
官方AT客户端应用笔记的几个小tip
RTT的SAL能够判断使用LWIP或者AT?
rt_therad AT组件移植不成功(结贴)
AT组件在哪个版本的?
AT组件 连接 Onenet 连接失败
esp8266 AT指令 MQTT连接问题
AT组件使用问题之模块主动上报【已解决】
