Kernel
SMP
SYSTICK_心跳时钟节拍
rt_tick_increase()在SMP时只增加当前核的TICK?
发布于 2019-04-09 17:54:15 浏览:1893
看代码好像目前是增加当前核的tick,但是对imx6q这种四核的话,其他核的thread岂不是就不能更新tick了? ```c * This function will notify kernel there is one tick passed. Normally, * this function is invoked by clock ISR. */ void rt_tick_increase(void) { struct rt_thread *thread; /* increase the global tick */ #ifdef RT_USING_SMP rt_cpu_self()->tick ++; #else ++ rt_tick; #endif /* check time slice */ thread = rt_thread_self(); -- thread->remaining_tick; if (thread->remaining_tick == 0) { /* change to initialized tick */ thread->remaining_tick = thread->init_tick; /* yield */ rt_thread_yield(); } /* check timer */ rt_timer_check(); } ```
hwx628
2019-04-09
```c rt_cpu_self()->tick ++; ``` 是否有必要改成 ```c for(int i =0 ;i
tick ++; } ``` 然后thread全部替换为`rt_cpu_index(i)->current_thread`?
2019-04-09
OS tick计数,整个系统只有一个的;如果多个都去计数就乱了。 多核具体情况,看后续的文档吧。。。这部分还有改动,所以文档也相应的靠后些
hwx628
2019-04-10
>OS tick计数,整个系统只有一个的;如果多个都去计数就乱了。 所以只是0核来负责当前的OS TICK刷新么? 其他核就完全指定thread在上面跑就可以了?
hwx628
2019-04-24
>OS tick计数,整个系统只有一个的;如果多个都去计数就乱了。 ```c #ifdef RT_USING_SMP static void rt_hw_timer2_isr(int vector, void *param) { rt_tick_increase(); /* clear interrupt */ timer_clear_pending(0); } void rt_hw_secondary_cpu_up(void) { extern void set_secondary_cpu_boot_address(void); set_secondary_cpu_boot_address(); __asm__ volatile ("dsb":::"memory"); rt_hw_ipi_send(0, 1 << 1); } void secondary_cpu_c_start(void) { rt_hw_vector_init(); rt_hw_spin_lock(&_cpus_lock); arm_gic_cpu_init(0, REALVIEW_GIC_CPU_BASE); arm_gic_set_cpu(0, IRQ_PBA8_TIMER0_1, 0x2); timer_init(0, 1000); rt_hw_interrupt_install(IRQ_PBA8_TIMER0_1, rt_hw_timer2_isr, RT_NULL, "tick"); rt_hw_interrupt_umask(IRQ_PBA8_TIMER0_1); rt_system_scheduler_start(); } void rt_hw_secondary_cpu_idle_exec(void) { asm volatile ("wfe":::"memory", "cc"); } #endif ``` 如上是`qemu_vexpress_a9`中 `secondary_cpu.c` 中,在启动2核时又重新定义了个计时器,其ISR中就重新对OS_TICK进行更新
w501229485
2020-09-03
请问楼主解决这个问题了么
1.9k
hwx628
cpu使用率分析
选择FreeRTOS, 还是RT-Thread。
thread heap stack overflow ?
rtt消息队列delay问题
释放被删除线程的内存地方在哪里啊
请教:各线程结束后,释放其中的内存的连续性问题
STM32F103中断关于信号量、邮箱问题
RTT中的线程栈大小如何控制
关于线程由执行态变为挂起态的代码实现,,,
