发布于 2008-11-15 13:59:34 浏览:5813
以下为linux2.4.19在at91rm9200 上的寄存器设置: ``` EMAC_CTL:c EMAC_CFG:2043 EMAC_SR:4 EMAC_TAR:0 EMAC_TCR:0 EMAC_TSR:18 EMAC_RBQP:201a0008 EMAC_RSR:2 EMAC_ISR:0 EMAC_IER:0 EMAC_IDR:0 EMAC_IMR:349 EMAC_MAN:6016cde1 EMAC_FRA:0 EMAC_SCOL:0 EMAC_MCOL:0 EMAC_OK:1 EMAC_SEQE:0 EMAC_ALE:0 EMAC_DTE:0 EMAC_LCOL:0 EMAC_ECOL:0 EMAC_CSE:0 EMAC_TUE:0 EMAC_CDE:0 EMAC_ELR:0 EMAC_RJB:0 EMAC_USF:0 EMAC_SQEE:0 EMAC_DRFC:0 EMAC_HSH:0 EMAC_HSL:0 EMAC_SA1L:ccbbaa00 EMAC_SA1H:dd EMAC_SA2L:0 EMAC_SA2H:0 EMAC_SA3L:0 EMAC_SA3H:0 EMAC_SA4L:0 EMAC_SA4H:0 the AIC_SMR:77000066660406555000000330000000 the AIC_SVR: AIC_IVR:20 AIC_FVR:20 AIC_ISR:0 AIC_IPR:92000000 AIC_IMR:2002 AIC_CISR:0 AIC_IECR:0 AIC_IDCR:0 AIC_ICCR:0 AIC_ISCR:0 AIC_EOICR:0 AIC_SPU:20 AIC_DCR:0 AIC_FFER:0 AIC_FFDR:0 AIC_FFSR:0 DBGU_CR:0 DBGU_MR:800 DBGU_IER:0 DBGU_IDR:0 DBGU_IMR:1 DBGU_CSR:40001818 DBGU_RHR:d DBGU_THR:0 DBGU_BRGR:20 DBGU_C1R:9290781 DBGU_C2R:0 DBGU_FNTR:0 DBGU_RPR:0 DBGU_RCR:0 DBGU_TPR:0 DBGU_TCR:0 DBGU_RNPR:0 DBGU_RNCR:0 DBGU_TNPR:0 DBGU_TNCR:0 DBGU_PTCR:0 DBGU_PTSR:101 PIOA_PER:0 PIOA_PDR:0 PIOA_PSR:3ffe0000 PIOA_OER:0 PIOA_ODR:0 PIOA_OSR:800000 PIOA_IFER:0 PIOA_IFDR:0 PIOA_IFSR:0 PIOA_SODR:0 PIOA_CODR:0 PIOA_ODSR:0 PIOA_PDSR:0 PIOA_IER:0 PIOA_IDR:0 PIOA_IMR:0 PIOA_ISR:0 PIOA_MDER:0 PIOA_MDDR:0 PIOA_MDSR:0 PIOA_PPUDR:0 PIOA_PPUER:0 PIOA_PPUSR:0 PIOA_ASR:0 PIOA_BSR:0 PIOA_ABSR:0 PIOA_OWER:0 PIOA_OWDR:0 PIOA_OWSR:0 PIOB_PER:0 PIOB_PDR:0 PIOB_PSR:3843ffff PIOB_OER:0 PIOB_ODR:0 PIOB_OSR:0 PIOB_IFER:0 PIOB_IFDR:0 PIOB_IFSR:0 PIOB_SODR:0 PIOB_CODR:0 PIOB_ODSR:0 PIOB_PDSR:0 PIOB_IER:0 PIOB_IDR:0 PIOB_IMR:0 PIOB_ISR:0 PIOB_MDER:0 PIOB_MDDR:0 PIOB_MDSR:0 PIOB_PPUDR:0 PIOB_PPUER:0 PIOB_PPUSR:0 PIOB_ASR:0 PIOB_BSR:0 PIOB_ABSR:2080000 PIOB_OWER:0 PIOB_OWDR:0 PIOB_OWSR:0 PIOC_PER:0 PIOC_PDR:0 PIOC_PSR:c074 PIOC_OER:0 PIOC_ODR:0 PIOC_OSR:0 PIOC_IFER:0 PIOC_IFDR:0 PIOC_IFSR:0 PIOC_SODR:0 PIOC_CODR:0 PIOC_ODSR:0 PIOC_PDSR:0 PIOC_IER:0 PIOC_IDR:0 PIOC_IMR:10 PIOC_ISR:0 PIOC_MDER:0 PIOC_MDDR:0 PIOC_MDSR:0 PIOC_PPUDR:0 PIOC_PPUER:0 PIOC_PPUSR:0 PIOC_ASR:0 PIOC_BSR:0 PIOC_ABSR:0 PIOC_OWER:0 PIOC_OWDR:0 PIOC_OWSR:0 PIOD_PER:0 PIOD_PDR:0 PIOD_PSR:fffffff PIOD_OER:0 PIOD_ODR:0 PIOD_OSR:0 PIOD_IFER:0 PIOD_IFDR:0 PIOD_IFSR:0 PIOD_SODR:0 PIOD_CODR:0 PIOD_ODSR:0 PIOD_PDSR:0 PIOD_IER:0 PIOD_IDR:0 PIOD_IMR:0 PIOD_ISR:0 PIOD_MDER:0 PIOD_MDDR:0 PIOD_MDSR:0 PIOD_PPUDR:0 PIOD_PPUER:0 PIOD_PPUSR:0 PIOD_ASR:0 PIOD_BSR:0 PIOD_ABSR:0 PIOD_OWER:0 PIOD_OWDR:0 PIOD_OWSR:0 PMC_SCER:0 PMC_SCDR:0 PMC_SCSR:1 PMC_PCER:0 PMC_PCDR:0 PMC_PCSR:1022000 CKGR_MOR:ff01 CKGR_MCFR:12327 CKGR_PLLAR:20263e04 CKGR_PLLBR:10483e0e PMC_MCKR:202 PMC_PCKR:0x00x00x00x00x00x00x00x0PMC_IER:0 PMC_IDR:0 PMC_SR:f PMC_IMR:0 ST_CR:0 ST_PIMR:148 ST_WDMR:20000 ST_RTMR:1 ST_SR:5 ST_IER:0 ST_IDR:0 ST_IMR:1 ST_RTAR:fa558 ST_CRTR:fbf3d RTC_CR:0 RTC_MR:0 RTC_TIMR:130 RTC_CALR:1819819 RTC_TIMALR:0 RTC_CALALR:1010000 RTC_SR:c RTC_SCCR:0 RTC_IER:0 RTC_IDR:0 RTC_IMR:0 RTC_VER:0 MC_RCR:0 MC_ASR:0 MC_AASR:0 MC_PUIA:0x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x0MC_PUP:0 MC_PUER:0 EBI_CSA:a EBI_CFGR:0 EBI_SMC2_CSR:0x32880x20000x20000x100041830x20000x20000x20000x2000EBI_SDRC_MR:0 EBI_SDRC_TR:2e0 EBI_SDRC_CR:2188c154 EBI_SDRC_SRR:0 EBI_SDRC_LPR:0 EBI_SDRC_IER:0 EBI_SDRC_IDR:0 EBI_SDRC_IMR:0 EBI_SDRC_ISR:0 EBI_BFC_MR:0 ```
tony
2008-11-15
寄存器的数值在rtthread 0.2.3 ``` EMAC_CTL:c EMAC_CFG:2953 EMAC_SR:4 EMAC_TAR:0 EMAC_TCR:0 EMAC_TSR:18 EMAC_RBQP:2004831c EMAC_RSR:3 EMAC_ISR:0 EMAC_IER:0 EMAC_IDR:0 EMAC_IMR:b79 EMAC_MAN:6016cde1 EMAC_FRA:0 EMAC_SCOL:0 EMAC_MCOL:0 EMAC_OK:1 EMAC_SEQE:0 EMAC_ALE:0 EMAC_DTE:0 EMAC_LCOL:0 EMAC_ECOL:0 EMAC_CSE:0 EMAC_TUE:0 EMAC_CDE:0 EMAC_ELR:0 EMAC_RJB:0 EMAC_USF:0 EMAC_SQEE:0 EMAC_DRFC:0 EMAC_HSH:0 EMAC_HSL:0 EMAC_SA1L:0 EMAC_SA1H:0 EMAC_SA2L:0 EMAC_SA2H:0 EMAC_SA3L:0 EMAC_SA3H:0 EMAC_SA4L:0 EMAC_SA4H:0 the AIC_SMR:20272020202020202020202020202020202202020202020320202020202020 the AIC_SVR: AIC_IVR:2000b740 AIC_FVR:2000b740 AIC_ISR:0 AIC_IPR:80020000 AIC_IMR:1020002 AIC_CISR:0 AIC_IECR:0 AIC_IDCR:0 AIC_ICCR:0 AIC_ISCR:0 AIC_EOICR:0 AIC_SPU:2000b740 AIC_DCR:0 AIC_FFER:0 AIC_FFDR:0 AIC_FFSR:0 DBGU_CR:0 DBGU_MR:800 DBGU_IER:0 DBGU_IDR:0 DBGU_IMR:1 DBGU_CSR:40001818 DBGU_RHR:d DBGU_THR:0 DBGU_BRGR:21 DBGU_C1R:9290781 DBGU_C2R:0 DBGU_FNTR:0 DBGU_RPR:0 DBGU_RCR:0 DBGU_TPR:0 DBGU_TCR:0 DBGU_RNPR:0 DBGU_RNCR:0 DBGU_TNPR:0 DBGU_TNCR:0 DBGU_PTCR:0 DBGU_PTSR:101 PIOA_PER:0 PIOA_PDR:0 PIOA_PSR:3ffe007e PIOA_OER:0 PIOA_ODR:0 PIOA_OSR:800000 PIOA_IFER:0 PIOA_IFDR:0 PIOA_IFSR:80000001 PIOA_SODR:0 PIOA_CODR:0 PIOA_ODSR:0 PIOA_PDSR:0 PIOA_IER:0 PIOA_IDR:0 PIOA_IMR:0 PIOA_ISR:0 PIOA_MDER:0 PIOA_MDDR:0 PIOA_MDSR:0 PIOA_PPUDR:0 PIOA_PPUER:0 PIOA_PPUSR:0 PIOA_ASR:0 PIOA_BSR:0 PIOA_ABSR:0 PIOA_OWER:0 PIOA_OWDR:0 PIOA_OWSR:0 PIOB_PER:0 PIOB_PDR:0 PIOB_PSR:3df7ffff PIOB_OER:0 PIOB_ODR:0 PIOB_OSR:0 PIOB_IFER:0 PIOB_IFDR:0 PIOB_IFSR:0 PIOB_SODR:0 PIOB_CODR:0 PIOB_ODSR:0 PIOB_PDSR:0 PIOB_IER:0 PIOB_IDR:0 PIOB_IMR:0 PIOB_ISR:0 PIOB_MDER:0 PIOB_MDDR:0 PIOB_MDSR:0 PIOB_PPUDR:0 PIOB_PPUER:0 PIOB_PPUSR:0 PIOB_ASR:0 PIOB_BSR:0 PIOB_ABSR:2080000 PIOB_OWER:0 PIOB_OWDR:0 PIOB_OWSR:0 PIOC_PER:0 PIOC_PDR:0 PIOC_PSR:c07f PIOC_OER:0 PIOC_ODR:0 PIOC_OSR:8 PIOC_IFER:0 PIOC_IFDR:0 PIOC_IFSR:8 PIOC_SODR:0 PIOC_CODR:0 PIOC_ODSR:8 PIOC_PDSR:0 PIOC_IER:0 PIOC_IDR:0 PIOC_IMR:0 PIOC_ISR:0 PIOC_MDER:0 PIOC_MDDR:0 PIOC_MDSR:0 PIOC_PPUDR:0 PIOC_PPUER:0 PIOC_PPUSR:0 PIOC_ASR:0 PIOC_BSR:0 PIOC_ABSR:0 PIOC_OWER:0 PIOC_OWDR:0 PIOC_OWSR:8 PIOD_PER:0 PIOD_PDR:0 PIOD_PSR:fffffff PIOD_OER:0 PIOD_ODR:0 PIOD_OSR:0 PIOD_IFER:0 PIOD_IFDR:0 PIOD_IFSR:0 PIOD_SODR:0 PIOD_CODR:0 PIOD_ODSR:0 PIOD_PDSR:0 PIOD_IER:0 PIOD_IDR:0 PIOD_IMR:0 PIOD_ISR:0 PIOD_MDER:0 PIOD_MDDR:0 PIOD_MDSR:0 PIOD_PPUDR:0 PIOD_PPUER:0 PIOD_PPUSR:0 PIOD_ASR:0 PIOD_BSR:0 PIOD_ABSR:0 PIOD_OWER:0 PIOD_OWDR:0 PIOD_OWSR:0 PMC_SCER:0 PMC_SCDR:0 PMC_SCSR:1 PMC_PCER:0 PMC_PCDR:0 PMC_PCSR:1020000 CKGR_MOR:ff01 CKGR_MCFR:12327 CKGR_PLLAR:20263e04 CKGR_PLLBR:10483e0e PMC_MCKR:202 PMC_PCKR:0x00x00x00x00x00x00x00x0PMC_IER:0 PMC_IDR:0 PMC_SR:f PMC_IMR:0 ST_CR:0 ST_PIMR:0 ST_WDMR:20000 ST_RTMR:8000 ST_SR:7 ST_IER:0 ST_IDR:0 ST_IMR:0 ST_RTAR:0 ST_CRTR:256 RTC_CR:0 RTC_MR:0 RTC_TIMR:958 RTC_CALR:1819819 RTC_TIMALR:0 RTC_CALALR:1010000 RTC_SR:c RTC_SCCR:0 RTC_IER:0 RTC_IDR:0 RTC_IMR:0 RTC_VER:0 MC_RCR:0 MC_ASR:0 MC_AASR:0 MC_PUIA:0x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x0MC_PUP:0 MC_PUER:0 EBI_CSA:2 EBI_CFGR:0 EBI_SMC2_CSR:0x32880x20000x20000x20000x20000x20000x20000x2000EBI_SDRC_MR:0 EBI_SDRC_TR:2e0 EBI_SDRC_CR:2188c154 EBI_SDRC_SRR:0 EBI_SDRC_LPR:0 EBI_SDRC_IER:0 EBI_SDRC_IDR:0 EBI_SDRC_IMR:0 EBI_SDRC_ISR:0 EBI_BFC_MR:0 descriptors0x2004831c, offset 0 EMAC_CTL:c EMAC_CFG:2953 EMAC_SR:4 EMAC_TAR:0 EMAC_TCR:0 EMAC_TSR:18 EMAC_RBQP:2004831c EMAC_RSR:3 EMAC_ISR:0 EMAC_IER:0 EMAC_IDR:0 EMAC_IMR:b79 EMAC_MAN:6016cde1 EMAC_FRA:0 EMAC_SCOL:0 EMAC_MCOL:0 EMAC_OK:0 EMAC_SEQE:0 EMAC_ALE:0 EMAC_DTE:0 EMAC_LCOL:0 EMAC_ECOL:0 EMAC_CSE:0 EMAC_TUE:0 EMAC_CDE:0 EMAC_ELR:0 EMAC_RJB:0 EMAC_USF:0 EMAC_SQEE:0 EMAC_DRFC:0 EMAC_HSH:0 EMAC_HSL:0 EMAC_SA1L:0 EMAC_SA1H:0 EMAC_SA2L:0 EMAC_SA2H:0 EMAC_SA3L:0 EMAC_SA3H:0 EMAC_SA4L:0 EMAC_SA4H:0 the AIC_SMR:20272020202020202020202020202020202202020202020320202020202020 the AIC_SVR: AIC_IVR:2000b740 AIC_FVR:2000b740 AIC_ISR:0 AIC_IPR:80020000 AIC_IMR:1020002 AIC_CISR:0 AIC_IECR:0 AIC_IDCR:0 AIC_ICCR:0 AIC_ISCR:0 AIC_EOICR:0 AIC_SPU:2000b740 AIC_DCR:0 AIC_FFER:0 AIC_FFDR:0 AIC_FFSR:0 DBGU_CR:0 DBGU_MR:800 DBGU_IER:0 DBGU_IDR:0 DBGU_IMR:1 DBGU_CSR:40001818 DBGU_RHR:d DBGU_THR:0 DBGU_BRGR:21 DBGU_C1R:9290781 DBGU_C2R:0 DBGU_FNTR:0 DBGU_RPR:0 DBGU_RCR:0 DBGU_TPR:0 DBGU_TCR:0 DBGU_RNPR:0 DBGU_RNCR:0 DBGU_TNPR:0 DBGU_TNCR:0 DBGU_PTCR:0 DBGU_PTSR:101 PIOA_PER:0 PIOA_PDR:0 PIOA_PSR:3ffe007e PIOA_OER:0 PIOA_ODR:0 PIOA_OSR:800000 PIOA_IFER:0 PIOA_IFDR:0 PIOA_IFSR:80000001 PIOA_SODR:0 PIOA_CODR:0 PIOA_ODSR:0 PIOA_PDSR:0 PIOA_IER:0 PIOA_IDR:0 PIOA_IMR:0 PIOA_ISR:0 PIOA_MDER:0 PIOA_MDDR:0 PIOA_MDSR:0 PIOA_PPUDR:0 PIOA_PPUER:0 PIOA_PPUSR:0 PIOA_ASR:0 PIOA_BSR:0 PIOA_ABSR:0 PIOA_OWER:0 PIOA_OWDR:0 PIOA_OWSR:0 PIOB_PER:0 PIOB_PDR:0 PIOB_PSR:3df7ffff PIOB_OER:0 PIOB_ODR:0 PIOB_OSR:0 PIOB_IFER:0 PIOB_IFDR:0 PIOB_IFSR:0 PIOB_SODR:0 PIOB_CODR:0 PIOB_ODSR:0 PIOB_PDSR:0 PIOB_IER:0 PIOB_IDR:0 PIOB_IMR:0 PIOB_ISR:0 PIOB_MDER:0 PIOB_MDDR:0 PIOB_MDSR:0 PIOB_PPUDR:0 PIOB_PPUER:0 PIOB_PPUSR:0 PIOB_ASR:0 PIOB_BSR:0 PIOB_ABSR:2080000 PIOB_OWER:0 PIOB_OWDR:0 PIOB_OWSR:0 PIOC_PER:0 PIOC_PDR:0 PIOC_PSR:c07f PIOC_OER:0 PIOC_ODR:0 PIOC_OSR:8 PIOC_IFER:0 PIOC_IFDR:0 PIOC_IFSR:8 PIOC_SODR:0 PIOC_CODR:0 PIOC_ODSR:8 PIOC_PDSR:0 PIOC_IER:0 PIOC_IDR:0 PIOC_IMR:0 PIOC_ISR:0 PIOC_MDER:0 PIOC_MDDR:0 PIOC_MDSR:0 PIOC_PPUDR:0 PIOC_PPUER:0 PIOC_PPUSR:0 PIOC_ASR:0 PIOC_BSR:0 PIOC_ABSR:0 PIOC_OWER:0 PIOC_OWDR:0 PIOC_OWSR:8 PIOD_PER:0 PIOD_PDR:0 PIOD_PSR:fffffff PIOD_OER:0 PIOD_ODR:0 PIOD_OSR:0 PIOD_IFER:0 PIOD_IFDR:0 PIOD_IFSR:0 PIOD_SODR:0 PIOD_CODR:0 PIOD_ODSR:0 PIOD_PDSR:0 PIOD_IER:0 PIOD_IDR:0 PIOD_IMR:0 PIOD_ISR:0 PIOD_MDER:0 PIOD_MDDR:0 PIOD_MDSR:0 PIOD_PPUDR:0 PIOD_PPUER:0 PIOD_PPUSR:0 PIOD_ASR:0 PIOD_BSR:0 PIOD_ABSR:0 PIOD_OWER:0 PIOD_OWDR:0 PIOD_OWSR:0 PMC_SCER:0 PMC_SCDR:0 PMC_SCSR:1 PMC_PCER:0 PMC_PCDR:0 PMC_PCSR:1020000 CKGR_MOR:ff01 CKGR_MCFR:12327 CKGR_PLLAR:20263e04 CKGR_PLLBR:10483e0e PMC_MCKR:202 PMC_PCKR:0x00x00x00x00x00x00x00x0PMC_IER:0 PMC_IDR:0 PMC_SR:f PMC_IMR:0 ST_CR:0 ST_PIMR:0 ST_WDMR:20000 ST_RTMR:8000 ST_SR:0 ST_IER:0 ST_IDR:0 ST_IMR:0 ST_RTAR:0 ST_CRTR:256 RTC_CR:0 RTC_MR:0 RTC_TIMR:959 RTC_CALR:1819819 RTC_TIMALR:0 RTC_CALALR:1010000 RTC_SR:c RTC_SCCR:0 RTC_IER:0 RTC_IDR:0 RTC_IMR:0 RTC_VER:0 MC_RCR:0 MC_ASR:0 MC_AASR:0 MC_PUIA:0x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x0MC_PUP:0 MC_PUER:0 EBI_CSA:2 EBI_CFGR:0 EBI_SMC2_CSR:0x32880x20000x20000x20000x20000x20000x20000x2000EBI_SDRC_MR:0 EBI_SDRC_TR:2e0 EBI_SDRC_CR:2188c154 EBI_SDRC_SRR:0 EBI_SDRC_LPR:0 EBI_SDRC_IER:0 EBI_SDRC_IDR:0 EBI_SDRC_IMR:0 EBI_SDRC_ISR:0 EBI_BFC_MR:0 ```
2008-11-17
主要的差别是什么?pinmux,clock,emac上有什么差别吗?
5.8k
tony
下载了0.23版本,编译s3ceb2410出错,提示lowlevel_init函数没实现
【学习分享】初探RT-Thread系统调度
