spi 注册时是RT_Object_Class_Mutex,运行时变成了RT_Object_Class_Semaphore
发布于 2022-12-01 18:21:34 浏览:343
注册时打印结果是3 ```c rt_err_t rt_spi_bus_register(struct rt_spi_bus *bus, const char *name, const struct rt_spi_ops *ops) { rt_err_t result; result = rt_spi_bus_device_init(bus, name); if (result != RT_EOK) return result; /* initialize mutex lock */ rt_mutex_init(&(bus->lock), name, RT_IPC_FLAG_FIFO); rt_kprintf("rt_object_get_type:%d\n",rt_object_get_type(&(bus->lock.parent.parent))); /* set ops */ bus->ops = ops; /* initialize owner */ bus->owner = RT_NULL; /* set bus mode */ bus->mode = RT_SPI_BUS_MODE_SPI; return RT_EOK; } ``` 运行时打印结果是2 ```c rt_err_t rt_mutex_take(rt_mutex_t mutex, rt_int32_t time) { register rt_base_t temp; struct rt_thread *thread; /* this function must not be used in interrupt even if time = 0 */ RT_DEBUG_IN_THREAD_CONTEXT; /* parameter check */ RT_ASSERT(mutex != RT_NULL); rt_kprintf("rt_object_get_type:%d\n",rt_object_get_type(&mutex->parent.parent)); RT_ASSERT(rt_object_get_type(&mutex->parent.parent) == RT_Object_Class_Mutex); /* get current thread */ thread = rt_thread_self(); /* disable interrupt */ temp = rt_hw_interrupt_disable(); } ```
2022-12-01
下个写断点,看看谁在篡改?是否栈溢出?
LVGRAPE
2022-12-02
发现地址没传过来,不知道哪里修改了 ```c //别人的内存地址是0x20002000以后的,它的确是0x3d LOG_D("0 0x%x %s-> 0x%x", spi1_dev_nrf24l01, "SPI1_BUS_", spi1_dev_nrf24l01->bus); LOG_D("1 0x%x %s-> 0x%x", spi_dev_nrf24l01, "SPI2_BUS_", spi_dev_nrf24l01->bus->lock.parent.parent.type); LOG_D("2 0x%x %s-> 0x%x", spi_dev_nrf24l01, "SPI2_BUS_", &spi_dev_nrf24l01->bus->lock.parent.parent.type); LOG_D("3 0x%x %s-> 0x%x", i2cp, "I2C_BUS_", i2cp->lock.parent.parent.type); LOG_D("4 0x%x %s-> 0x%x", i2cp, "I2C_BUS_", &i2cp->lock.parent.parent.type); [D/NRF24L01P] 0 0x20002ec8 SPI1_BUS_-> 0x3d [D/NRF24L01P] 1 0x20002f28 SPI2_BUS_-> 0x2 [D/NRF24L01P] 2 0x20002f28 SPI2_BUS_-> 0x3d [D/NRF24L01P] 3 0x20002e60 I2C_BUS_-> 0x83 [D/NRF24L01P] 4 0x20002e60 I2C_BUS_-> 0x20002e9c ```
LVGRAPE
BBB的SPI驱动
求个SPI上挂两个或多个设备的使用例子
SPI设备有个bug
SPI驱动
请教rt_spi_configure函数理解
SPI FLASH挂载的问题
SPI-FLASH 文件系统 SPIFFS
求助一个完整的 spi flash 驱动
关于同时使用文件系统与SPI FLASH的问题
