还是串口收发的问题
发布于 2012-07-24 11:52:13 浏览:3808
我用read读出来,然后用write发,但是,第一次输入比如:0x35,然后write出0x35,第二次输入:0x36,但是第二次write的是0x35,0x36,这是为什么呢。。。
2012-07-24
no code, no information, no reason...
lujun723
2012-07-24
``` static void rs485_thread_entry(void* parameter) { extern rt_size_t rt_serial_write (rt_device_t dev, rt_off_t pos, const void* buffer, rt_size_t size); extern rt_size_t rt_serial_read (rt_device_t dev, rt_off_t pos, void* buffer, rt_size_t size); extern struct rt_device uart1_device; rt_size_t length; uint16_t cnt; rs485_init(); length=10; while (1) { rs485_rx_on(); cnt=50000; while(cnt--); rt_device_read(&uart1_device,0,in,length); rt_thread_delay( 50 ); rs485_tx_on(); cnt=50000; while(cnt--); rt_device_write(&uart1_device,0,in,length); rt_thread_delay( 50 ); } } void rs485_init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11|GPIO_Pin_12; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); } void rs485_rx_on(void) { GPIO_ResetBits(GPIOA, GPIO_Pin_11); GPIO_ResetBits(GPIOA, GPIO_Pin_12); } void rs485_tx_on(void) { GPIO_SetBits(GPIOA, GPIO_Pin_11); GPIO_SetBits(GPIOA, GPIO_Pin_12); } void USART1_IRQHandler(void) { #ifdef RT_USING_UART1 extern struct rt_device uart1_device; extern void rt_hw_serial_isr(struct rt_device *device); /* enter interrupt */ rt_interrupt_enter(); rt_hw_serial_isr(&uart1_device); /*leave interrupt */ rt_interrupt_leave(); #endif } ```
2012-07-24
你读到了几个数据,然后写入了几个数据? 你代码里都没去检查读到了几个数据
lujun723
2012-07-24
两个问题不明白: 一个是中断中的服务函数里面有收发,为何我在线程里还要开收和发; 还有一个就是,我也想计数,我以为长度length设成10,就是可以收发10个数了; 但,现实是收发10个数,但是上次发的数,还会依次打印出来 比如:一上来没发送时,打印的是0A,8A,00,00,00,00,00,00,00,00(这里为何不全为00?)我第一次发送:FB,71,61,51,41,31,21,11,01,BB后,循环显示0A,8A,00,00,00,00,00,00,00,00和FB,71,61,51,41,31,21,11,01,BB;第二次发FB,72,62,52,42,32,22,12,02,BB后,这三个循环显示,以此类推。。。
2012-07-24
>两个问题不明白: >一个是中断中的服务函数里面有收发,为何我在线程里还要开收和发; --- 线程收发是指 rs485_rx_on 和 rs485_tx_on? 这是你自己的应用需要的。 如果你的串口不是485,则不需要。 当然,也有人直接在驱动中修改为自动切换方向了,这样应用程序就不需要自己切换。 第二点,完全不能明白你在说什么。 你的程序没有判断到底接收到了多少个数据,则发送出去的数据可能是 部分数据是新收到,后面部分是buffer中缓存的。 或整个buffer都是旧的,因为一个数据都没有收到。
tanghong668
2012-07-24
485的驱动不是这么写的,你可以参考一下finsh下串口是怎么操作的,然后依葫芦画瓢实现485的驱动
3.8k
lujun723
33
131
FRDM-MCXN94 7Flash实践--W25Q64
