MDK4.6 编译错误 [已解决]
发布于 2013-02-17 21:16:21 浏览:4422
这是一个朋友给我提供的截图。 我手上没有安装MDK4.6,暂时不清楚是什么原因。 安装有MDK4.6的朋友帮忙看下。 PS,使用scons --target=mdk4 -s生成工程后编译没有问题。 几个可以参考帖子标记一下: 1. [http://www.amobbs.com/thread-5500080-1-1.html](http://www.amobbs.com/thread-5500080-1-1.html) 2. [http://www.360doc.com/content/13/0129/1 ... 6090.shtml](http://www.360doc.com/content/13/0129/16/10906019_263076090.shtml) 3. [http://www.keil.com/update/whatsnew.asp?p=RVMDK&v=4.60](http://www.keil.com/update/whatsnew.asp?p=RVMDK&v=4.60) ![QQ图片20130217211419.jpg](https://oss-club.rt-thread.org/uploads/3230_8f5066aa6e68ab83d309e2f6ce1b5471.jpg)
2013-02-19
看来MDK4.6不旦把ARMCC的目录换了,把库的目录也换了,脚本要做相应的更新。
2013-02-22
L6310W 链接错误信息如下:(来自[http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0495b/BABHAIBE.html](ARM)) >L6310W > > Unable to find ARM libraries. > > This is most often caused by a missing or invalid value of the environment variable RVCT40LIB or by incorrect arguments to --libpath. For example RVCT40LIB must be set when RVCT 4.0 is installed. Ensure this matches with the tools you are using. > > Alternatively, try specifying the path explicitly using --libpath switch. The default for a normal Windows installation is C:Program FilesARMRVCTData4.0uildlib. Ensure this path does not include: > > armlib > > cpplib > > any trailing slashes () at the end. These are added by the linker automatically. > > Use --verbose or --info libraries to display where the linker is attempting to get the libraries from. --- 按提示把 rtconfig.py 中的 ``` LFLAGS += ' --libpath ' + EXEC_PATH + '/ARM/RV31/LIB' ``` 修改成 ``` LFLAGS += ' --libpath ' + EXEC_PATH + '/ARM/ARMCC/LIB' ``` 可以链接成功。 但按 building.py 中处理ARMCC那们自动替换却没起作用 ``` if rtconfig.EXEC_PATH.find('bin40') > 0: rtconfig.EXEC_PATH = rtconfig.EXEC_PATH.replace('bin40', 'armcc/bin') print rtconfig.LFLAGS ##替换前打印 rtconfig.LFLAGS = rtconfig.LFLAGS.replace('RV31', 'armcc') print rtconfig.LFLAGS ##替换后打印 ``` 编译时的LOG如下 ``` bspxxx>scons scons: Reading SConscript files ... ##替换前打印 sct --libpath C:Keil_MDK_460/ARM/RV31/LIB ##替换后打印 sct --libpath C:Keil_MDK_460/ARM/armcc/LIB scons: done reading SConscript files. scons: Building targets ... scons: building associated VariantDir targets: build armlink -o ### --libpath C:Keil_MDK_460/ARM/RV31/LIB --keep### ``` 后记:[https://github.com/RT-Thread/rt-thread/pull/42](已更新scons脚本 [https://github.com/RT-Thread/rt-thread/pull/42](已更新scons脚本
$(function() {editormd.markdownToHTML("markdown-view-14070",{htmlDecode :"style,script,iframe",tocm :true,emoji :true,tex :true,flowChart :true,sequenceDiagram :true,});});
e_donkey
2013-09-30
刚安装mdk4.60,也遇到了问题,添加两个环境变量: 1: ARMCC5LIB 值: D:\KEIL\ARM\ARMCC\lib 2: ARMINC(就是这个与ads冲突) 值: D:\KEIL\ARM\ARMCC\include 问题解决。
4.4k
prife
550
MCXN947测评系列(二)串口设备测评
