为啥释放不出来信号量?帮忙看看程序
发布于 2013-03-05 11:57:12 浏览:3436
```extern void rt_hw_key_init(void); static struct rt_semaphore static_sem; ALIGN(RT_ALIGN_SIZE) static rt_uint8_t led_stack[ 1024 ]; static struct rt_thread led_thread; static void led_thread_entry(void* parameter) { unsigned int count=0; rt_err_t result; rt_tick_t tick; rt_hw_led_init(); while (1) { // rt_sem_release(&static_sem); //:shock: ①处 result = rt_sem_take(&static_sem, RT_WAITING_FOREVER); if (result != RT_EOK) { rt_kprintf("take a static semaphore, failed. "); rt_sem_detach(&static_sem); return; } rt_kprintf("take a staic semaphore, done. "); rt_sem_detach(&static_sem); /* led1 on */ #ifndef RT_USING_FINSH rt_kprintf("led on, count : %d ",count); #endif count++; rt_hw_led_on(0); rt_thread_delay( RT_TICK_PER_SECOND/2 ); /* sleep 0.5 second and switch to other thread */ /* led1 off */ #ifndef RT_USING_FINSH rt_kprintf("led off "); #endif rt_hw_led_off(0); rt_thread_delay( RT_TICK_PER_SECOND/2 ); } } static void key_thread_entry(void *parameter) { rt_time_t next_delay; struct rtgui_event_kbd kbd_event; /* init keyboard event */ RTGUI_EVENT_KBD_INIT(&kbd_event); kbd_event.mod = RTGUI_KMOD_NONE; kbd_event.unicode = 0; while (1) { next_delay = 50; kbd_event.key = RTGUIK_UNKNOWN; kbd_event.type = RTGUI_KEYDOWN; if ( key_down_GETVALUE() == 0 ) { rt_kprintf("key_down "); kbd_event.key = RTGUIK_DOWN; rt_sem_release(&static_sem); // :shock: ②处 } if ( key_up_GETVALUE() == 0 ) { rt_kprintf("key_up "); kbd_event.key = RTGUIK_UP; } if ( key_right_GETVALUE() == 0 ) { rt_kprintf("key_right "); kbd_event.key = RTGUIK_RIGHT; } if ( key_left_GETVALUE() == 0 ) { rt_kprintf("key_left "); kbd_event.key = RTGUIK_LEFT; } if (kbd_event.key != RTGUIK_UNKNOWN) { /* post down event */ // rtgui_server_post_event(&(kbd_event.parent), sizeof(kbd_event)); // next_delay = 10; // /* delay to post up event */ // rt_thread_delay(next_delay); /* post up event */ // kbd_event.type = RTGUI_KEYUP; // rtgui_server_post_event(&(kbd_event.parent), sizeof(kbd_event)); } GPIOB->ODR ^= GPIO_Pin_5; /* wait next key press */ rt_thread_delay(next_delay); } } static char key_stack[1024]; static rt_thread_t key_tid; struct rt_thread key; void rt_hw_key_init(void) { rt_err_t result; GPIO_Configuration(); /* key_tid = rt_thread_init("key", &key_thread_entry, RT_NULL, 1024, 11, 30); */ rt_thread_init(&key, "key", //consumer key_thread_entry, RT_NULL, (rt_uint8_t*)&key_stack[0], sizeof(key_stack),11,24); if (result == RT_EOK) { rt_thread_startup(&key); } } int rt_application_init() { rt_thread_t init_thread; rt_err_t result; result = rt_sem_init(&static_sem, "ssem", 0, RT_IPC_FLAG_FIFO); if (result != RT_EOK) { rt_kprintf("init dynamic semaphore failed. "); return -1; } rt_hw_key_init(); /* init led thread */ result = rt_thread_init(&led_thread, "led", led_thread_entry, RT_NULL, (rt_uint8_t*)&led_stack[0], sizeof(led_stack), 11, 30); if (result == RT_EOK) { rt_thread_startup(&led_thread); } init_thread = rt_thread_create("init", rt_init_thread_entry, RT_NULL, 2048, 8, 20); if (init_thread != RT_NULL) rt_thread_startup(init_thread); return 0; } ``` 我本意是通过按键释放信号量,指示灯收到后动作。结果奇怪了!按键线程已经工作,并且按key_down键能够串口输出key_down 但运行过②处的rt_sem_release(&static_sem); 后static_sem的value并没有+1;所以LED不动作。但是在LED线程中①处的rt_sem_release(&static_sem); 使能后,LED线程能够正常运行,不能满足我的要求。KEY的现场动态 静态添加都试过 均失败! 点解?
2013-03-05
``` rt_sem_detach(&static_sem); ``` 点解?
eliucheng
2013-03-05
脱离信号量对象。 注释掉效果一样,因为压根就没执行到那里!等不到信号量!
eliucheng
2013-03-05
在LED中释放再持有就OK 在key中释放失败 持有的话直接FINSH输出错误 [2013:03:05:15:33:42][接收] ``` | / - RT - Thread Operating System / | 1.2.0 build Mar 4 2013 2006 - 2012 Copyright by rt-thread team psr: 0x61000000 pc: 0x0800184c lr: 0x0800187b r12: 0x00000000 r03: 0x00000000 r02: 0x00000000 r01: 0x20000b64 r00: 0x20000744 hard fault on thread: key thread pri status sp stack size max used left tick error -------- ---- ------- ---------- ---------- ---------- ---------- --- tidle 0x1f ready 0x00000040 0x00000100 0x00000040 0x00000020 000 tshell 0x14 ready 0x00000040 0x00000800 0x00000040 0x0000000a 000 led 0x0b ready 0x00000040 0x00000400 0x00000040 0x0000001e 000 key 0x0b suspend 0x00000040 0x00000400 0x00000070 0x00000018 000 init 0x08 close 0x00000068 0x00000800 0x00000068 0x00000013 000 ``` Help!Help!Help!Help!Help!Help!Help!Help!Help!Help!Help!Help!Help!Help!Help!Help!
2013-03-05
不会你执行到detach的代码,然后奔掉了吧
grissiom
2013-03-06
什么 BSP?RTT 是什么版本,源代码有没有改动?…… 奇怪的是 key 线程的状态是 suspend,而 hardfault 却是发生在 key 上……
2013-03-06
>什么 BSP?RTT 是什么版本,源代码有没有改动?…… > >奇怪的是 key 线程的状态是 suspend,而 hardfault 却是发生在 key 上…… --- 我估计就是因为semaphore有问题了(例如detached),这个时候再去持有,那么会先把key thread状态设置成suspend,然后再进行semaphore操作,但是semaphore是错的,所以最终hard fault。
3.4k
eliucheng
