Network
局域网环境tcp发送超时导致重启
发布于 2015-04-20 17:56:19 浏览:2085
环境: rt-thread 1.0.1 lwip 1.4.0 mcu:stm32f103 网卡:enc28j60 设备与pc在同一局域网,pc为server,设备client. 设备向pc端发送tcp数据 。 发送使用select,有可用资源时再write数据 出现问题:: 每隔几分钟出现select超时,tcp write失败并关闭链接,多次后设备重启!!。。 分析: 为什么会出现select超时以及发送失败? 发送速度大概几k每秒。 若采用设备pc直连方式就没有频繁超时重启的问题。 应用层是用的标准的发送流程,应该没有什么问题,是否是协议栈及lwip的性能稳定性问题? 或者能否有些调试的思路和方法 项目很急,万分感谢!! 串口log如下,可以看到超时及发送失败多次后设备重启了。。 insh>>send failed, close connect... send failed, close connect... select() timeout for writing select() timeout for writing select() timeout for writing select() timeout for writing select() timeout for writing select() timeout for writing select() timeout for writing select() timeout for writing select() timeout for writing select() timeout for writing select() timeout for writing send() failed! sock_err=104send failed, close connect... send failed, close connect... enc28j60 clkrdy signal 1 enc28j60 clkrdy ok Onevo TM->To enter the BOOT upgrade mode , press the 'Enter' time_S is 5 waitting time end into app... | / - RT - Thread Operating System / | 1.0.1 build Apr 17 2015 2006 - 2011 Copyright by rt-thread team TCP/IP initialized. TCP/IP initialized! 设备端发送代码: ```int app_tcp_send(int sock, struct data_packet *wdata, uint32_t timeout_usec) { struct timeval timeout; fd_set w_fd; int cnt; int ret = 0; int len; int wlen; if(sock < 0 || wdata == NULL) { syslog(WARN,"app_tcp_send() invalid para! "); return -1; } len = DATA_HEAD_LEN+wdata->len; wdata->len = htons(wdata->len); timeout.tv_sec = timeout_usec/1000000; timeout.tv_usec = timeout_usec%1000000; FD_ZERO(&w_fd); //初始化 w_fd 为空 FD_SET(sock,&w_fd); //把sock添加到 w_fd中去 cnt = select(sock+1,NULL,&w_fd,NULL,&timeout); if ( cnt < 0 ) { syslog(WARN,"select() failed! sock_err=%d ",lwip_get_error(sock)); rt_kprintf("select() failed! sock_err=%d ",lwip_get_error(sock)); ret = -1; } else if ( cnt == 0 ){ syslog(WARN,"select() timeout for writing "); rt_kprintf("select() timeout for writing "); ret = 1; } else { wlen = writen(sock,(const uint8_t *)wdata,len); if( wlen < 0) { syslog(WARN,"send() failed! sock_err=%d",lwip_get_error(sock)); rt_kprintf("send() failed! sock_err=%d",lwip_get_error(sock)); ret = -1; } else if( wlen == len) { ret = 1; // syslog(INFO,"send ok! len=%d",len); } else{ syslog(WARN,"send failed!send len =%d, data len =%d",wlen, len); rt_kprintf("send failed!send len =%d, data len =%d",wlen, len); ret = -1; } } return ret; }```
2015-04-20
先判断为什么会重启?开了狗,不能喂狗导致重启?另外,你用的EMAC芯片亮了
toasun
2015-04-21
当然,如果硬件没问题的话 不用select测试一下阻塞发包呢? 或者直接在send中设置为非阻塞试试看。
huhu
2015-04-21
>先判断为什么会重启?开了狗,不能喂狗导致重启?另外,你用的EMAC芯片亮了 --- 是开了狗,在systick中断里喂得狗。 我推测是网络收发包方面原因导致系统异常,但是无法确定是什么具体原因。 而且在局域网中问题变得严重,有什么好的调试协议栈网卡的手段? 另外emac亮了指的啥?
huhu
2015-04-21
>当然,如果硬件没问题的话 >不用select测试一下阻塞发包呢? >或者直接在send中设置为非阻塞试试看。 --- 恩 回头试试
2.1k
huhu
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
