请教rt_spi_configure函数理解
发布于 2015-07-28 20:04:39
rt_err_t rt_spi_configure(struct rt_spi_device *device,
struct rt_spi_configuration *cfg)
rt_err_t result;
RT_ASSERT(device != RT_NULL);
/* set configuration */
device->config.data_width = cfg->data_width;
device->config.mode = cfg->mode & RT_SPI_MODE_MASK ;
device->config.max_hz = cfg->max_hz ;
if (device->bus != RT_NULL)
result = rt_mutex_take(&(device->bus->lock), RT_WAITING_FOREVER);
if (result == RT_EOK)
if (device->bus->owner == device)
device->bus->ops->configure(device, &device->config);
/* release lock */
rt_mutex_release(&(device->bus->lock));
return RT_EOK;
以sst25vfxx为例使用到device->bus->owner主要是以下2个函数,并没有对owner进行赋值 ,导致今天调试时发现底层的configure没有执行,请大家指教是我理解出错,还是其他原因。
rt_err_t sst25vfxx_init(const char * flash_device_name, const char * spi_device_name)
/* config spi */
struct rt_spi_configuration cfg;
cfg.data_width = 8;
cfg.mode = RT_SPI_MODE_0 | RT_SPI_MSB; /* SPI Compatible: Mode 0 and Mode 3 */
cfg.max_hz = 50000000; /* 50M */
rt_spi_configure(spi_flash->rt_spi_device, &cfg);
rt_err_t rt_spi_bus_register(struct rt_spi_bus *bus,
const char *name,
const struct rt_spi_ops *ops)
rt_err_t result;
result = rt_spi_bus_device_init(bus, name);
if (result != RT_EOK)
return result;
/* initialize mutex lock */
rt_mutex_init(&(bus->lock), name, RT_IPC_FLAG_FIFO);
/* set ops */
bus->ops = ops;
/* initialize owner */
bus->owner = RT_NULL;
return RT_EOK;
2k
3 个回答
aozima 2015-07-28
拒绝白嫖,拒绝键盘侠!
只保证将配置写入内存里面,如果当前就是自己在使用SPI,则写入硬件中。
不然就等下次实际操作硬件时再真正写入硬件中。
否则,如果当前SPI正在被其它人使用,直接写入硬件就会出问题。
请登录后再发布答案,点击登录
