阿里云JSON数据解析问题-part2
发布于 2019-10-26 14:01:42    浏览:1370
前几天出差,上周的遗留问题没有解决,我在查询了相关资料后,了解到RTT有CJSON库,就在ENV工具里配置了,CJSON的函数如下
但是在调用CJSON函数的时候遇到了问题
请问这个获取根目录的函数应该数据哪个参数?
下面是mqtt_sample的源码
* Copyright (c) 2006-2018 RT-Thread Development Team. All rights reserved.
* License-Identifier: Apache-2.0
* Licensed under the Apache License, Version 2.0 (the "License"); you may
* not use this file except in compliance with the License.
* You may obtain a copy of the License at
* [url=][/url]
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
#include "cJSON.h"
#include "iot_import.h"
#include "iot_export.h"
#include "rtthread.h"
#if defined(MQTT_ID2_AUTH) && defined(ON_DAILY)
#define PRODUCT_KEY "9rx2yMNV5l0"
#define DEVICE_NAME "sh_online_sample_mqtt"
#define DEVICE_SECRET "v9mqGzepKEphLhXmAoiaUIR2HZ7XwTky"
#elif defined(ON_DAILY)
#define PRODUCT_KEY "gsYfsxQJgeD"
#define DEVICE_NAME "DailyEnvDN"
#define DEVICE_SECRET "y1vzFkEgcuXnvkAfm627pwarx4HRNikX"
#elif defined(MQTT_ID2_AUTH)
#define PRODUCT_KEY "micKUvuzOps"
#define DEVICE_NAME "00AAAAAABBBBBB4B645F5800"
#else
#ifdef PKG_USING_ALI_IOTKIT_PRODUCT_KEY
#define PRODUCT_KEY PKG_USING_ALI_IOTKIT_PRODUCT_KEY
#else
#define PRODUCT_KEY "yfTuLfBJTiL"
#endif
#ifdef PKG_USING_ALI_IOTKIT_DEVICE_NAME
#define DEVICE_NAME PKG_USING_ALI_IOTKIT_DEVICE_NAME
#else
#define DEVICE_NAME "TestDeviceForDemo"
#endif
#ifdef PKG_USING_ALI_IOTKIT_DEVICE_SECRET
#define DEVICE_SECRET PKG_USING_ALI_IOTKIT_DEVICE_SECRET
#else
#define DEVICE_SECRET "fSCl9Ns5YPnYN8Ocg0VEel1kXFnRlV6c"
#endif
#endif
#ifdef PKG_USING_ALI_IOTKIT_IS_LINKDEVELOP
/* ALINK TSL Device attribute report */
#define ALINK_PROPERTY_POST_PUB "/sys/"PRODUCT_KEY"/"DEVICE_NAME"/thing/event/property/post"
#define ALINK_PROPERTY_POST_REPLY_SUB "/sys/"PRODUCT_KEY"/"DEVICE_NAME"/thing/event/property/post_reply"
#define ALINK_PROPERTY_SET_REPLY_SUB "/sys/"PRODUCT_KEY"/"DEVICE_NAME"/thing/event/property/set_reply"
#define ALINK_SERVICE_SET_SUB "/sys/"PRODUCT_KEY"/"DEVICE_NAME"/thing/service/property/set"
#else
#define TOPIC_UPDATE "/"PRODUCT_KEY"/"DEVICE_NAME"/update"
#define TOPIC_ERROR "/"PRODUCT_KEY"/"DEVICE_NAME"/update/error"
#define TOPIC_GET "/"PRODUCT_KEY"/"DEVICE_NAME"/get"
#define TOPIC_DATA "/"PRODUCT_KEY"/"DEVICE_NAME"/data"
#endif
/* These are pre-defined topics format*/
#define TOPIC_UPDATE_FMT "/%s/%s/update"
#define TOPIC_ERROR_FMT "/%s/%s/update/error"
#define TOPIC_GET_FMT "/%s/%s/get"
#define TOPIC_DATA_FMT "/%s/%s/data"
#define MQTT_MSGLEN (1024)
#define EXAMPLE_TRACE(fmt, ...) \
do { \
HAL_Printf("%s|%03d :: ", __func__, __LINE__); \
HAL_Printf(fmt, ##__VA_ARGS__); \
HAL_Printf("%s", "\r\n"); \
} while(0)
static char __product_key[PRODUCT_KEY_LEN + 1];
static char __device_name[DEVICE_NAME_LEN + 1];
static char __device_secret[DEVICE_SECRET_LEN + 1];
static int user_argc;
static char *user_param = NULL;
static void *pclient;
static uint8_t is_running = 0;
static char* rt_strlwr(char *str)
if(str == NULL)
return NULL;
char *p = str;
while (*p != '\0')
if(*p >= 'A' && *p <= 'Z')
*p = (*p) + 0x20;
p++;
return str;
static void event_handle(void *pcontext, void *pclient, iotx_mqtt_event_msg_pt msg)
iotx_mqtt_topic_info_pt topic_info = (iotx_mqtt_topic_info_pt)msg->msg;
uintptr_t packet_id = (uintptr_t)(msg->msg);
if (topic_info == NULL)
rt_kprintf("Topic info is null! Exit.");
return;
switch (msg->event_type) {
case IOTX_MQTT_EVENT_UNDEF:
EXAMPLE_TRACE("undefined event occur.");
break;
case IOTX_MQTT_EVENT_DISCONNECT:
EXAMPLE_TRACE("MQTT disconnect.");
break;
case IOTX_MQTT_EVENT_RECONNECT:
EXAMPLE_TRACE("MQTT reconnect.");
break;
case IOTX_MQTT_EVENT_SUBCRIBE_SUCCESS:
EXAMPLE_TRACE("subscribe success, packet-id=%u", (unsigned int)packet_id);
break;
case IOTX_MQTT_EVENT_SUBCRIBE_TIMEOUT:
EXAMPLE_TRACE("subscribe wait ack timeout, packet-id=%u", (unsigned int)packet_id);
break;
case IOTX_MQTT_EVENT_SUBCRIBE_NACK:
EXAMPLE_TRACE("subscribe nack, packet-id=%u", (unsigned int)packet_id);
break;
case IOTX_MQTT_EVENT_UNSUBCRIBE_SUCCESS:
EXAMPLE_TRACE("unsubscribe success, packet-id=%u", (unsigned int)packet_id);
break;
case IOTX_MQTT_EVENT_UNSUBCRIBE_TIMEOUT:
EXAMPLE_TRACE("unsubscribe timeout, packet-id=%u", (unsigned int)packet_id);
break;
case IOTX_MQTT_EVENT_UNSUBCRIBE_NACK:
EXAMPLE_TRACE("unsubscribe nack, packet-id=%u", (unsigned int)packet_id);
break;
case IOTX_MQTT_EVENT_PUBLISH_SUCCESS:
EXAMPLE_TRACE("publish success, packet-id=%u", (unsigned int)packet_id);
break;
case IOTX_MQTT_EVENT_PUBLISH_TIMEOUT:
EXAMPLE_TRACE("publish timeout, packet-id=%u", (unsigned int)packet_id);
break;
case IOTX_MQTT_EVENT_PUBLISH_NACK:
EXAMPLE_TRACE("publish nack, packet-id=%u", (unsigned int)packet_id);
break;
case IOTX_MQTT_EVENT_PUBLISH_RECVEIVED:
EXAMPLE_TRACE("topic message arrived but without any related handle: topic=%.*s, topic_msg=%.*s",
topic_info->topic_len,
topic_info->ptopic,
topic_info->payload_len,
topic_info->payload);
break;
case IOTX_MQTT_EVENT_BUFFER_OVERFLOW:
EXAMPLE_TRACE("buffer overflow, %s", msg->msg);
break;
default:
EXAMPLE_TRACE("Should NOT arrive here.");
break;
static void _demo_message_arrive(void *pcontext, void *pclient, iotx_mqtt_event_msg_pt msg)
cJSON* root=cJSON_Parse((const char)* ptopic_info);
iotx_mqtt_topic_info_pt ptopic_info = (iotx_mqtt_topic_info_pt) msg->msg;
/* print topic name and topic message X*/
EXAMPLE_TRACE("----");
EXAMPLE_TRACE("packetId: %d", ptopic_info->packet_id);
EXAMPLE_TRACE("Topic: '%.*s' (Length: %d)",
ptopic_info->topic_len,
ptopic_info->ptopic,
ptopic_info->topic_len);
EXAMPLE_TRACE("Payload: '%.*s' (Length: %d)",
ptopic_info->payload_len,
ptopic_info->payload,
ptopic_info->payload_len);
// char * red =strstr(ptopic_info->payload,"\params\RGBColor\"Red\":");
// red +=strlen("\"Red\":");
// if(*(red+1)=='}')
// data=*red-'0';
// else if(*(red+2)=='}')
// data = (*red-'0')*10+(*(red+1)-'0');
// else if(*(red+3)=='}')
// data = (*red-'0')*100+(*(red+1)-'0')*10+(*(red+2)-'0');
// EXAMPLE_TRACE("Red:%d",data);
// EXAMPLE_TRACE("----");
#ifndef MQTT_ID2_AUTH
static void mqtt_client(void)
int rc = 0;
iotx_conn_info_pt pconn_info;
iotx_mqtt_param_t mqtt_params;
char *msg_buf = NULL, *msg_readbuf = NULL;
IOT_OpenLog("mqtt");
IOT_SetLogLevel(IOT_LOG_DEBUG);
if (NULL == (msg_buf = (char *)HAL_Malloc(MQTT_MSGLEN))) {
EXAMPLE_TRACE("not enough memory");
rc = -1;
goto do_exit;
if (NULL == (msg_readbuf = (char *)HAL_Malloc(MQTT_MSGLEN))) {
rc = -1;
goto do_exit;
HAL_GetProductKey(__product_key);
HAL_GetDeviceName(__device_name);
HAL_GetDeviceSecret(__device_secret);
/* Device AUTH */
if (0 != IOT_SetupConnInfo(__product_key, __device_name, __device_secret, (void **)&pconn_info)) {
EXAMPLE_TRACE("AUTH request failed!");
rc = -1;
goto do_exit;
/* Initialize MQTT parameter */
memset(&mqtt_params, 0x0, sizeof(mqtt_params));
mqtt_params.port = pconn_info->port;
mqtt_params.host = pconn_info->host_name;
mqtt_params.client_id = pconn_info->client_id;
mqtt_params.username = pconn_info->username;
mqtt_params.password = pconn_info->password;
mqtt_params.pub_key = pconn_info->pub_key;
mqtt_params.request_timeout_ms = 2000;
mqtt_params.clean_session = 0;
mqtt_params.keepalive_interval_ms = 60000;
mqtt_params.pread_buf = msg_readbuf;
mqtt_params.read_buf_size = MQTT_MSGLEN;
mqtt_params.pwrite_buf = msg_buf;
mqtt_params.write_buf_size = MQTT_MSGLEN;
mqtt_params.handle_event.h_fp = event_handle;
mqtt_params.handle_event.pcontext = NULL;
/* Convert uppercase letters in host to lowercase */
rt_kprintf("host: %s\r\n", rt_strlwr((char*)mqtt_params.host));
/* Construct a MQTT client with specify parameter */
pclient = IOT_MQTT_Construct(&mqtt_params);
if (NULL == pclient) {
EXAMPLE_TRACE("MQTT construct failed");
rc = -1;
goto do_exit;
/* Subscribe the specific topic */
rc = IOT_MQTT_Subscribe(pclient, ALINK_SERVICE_SET_SUB, IOTX_MQTT_QOS1, _demo_message_arrive, NULL);
#else
rc = IOT_MQTT_Subscribe(pclient, TOPIC_DATA, IOTX_MQTT_QOS1, _demo_message_arrive, NULL);
#endif
if (rc < 0) {
IOT_MQTT_Destroy(&pclient);
EXAMPLE_TRACE("IOT_MQTT_Subscribe() failed, rc = %d", rc);
rc = -1;
goto do_exit;
rc = IOT_MQTT_Subscribe(pclient, ALINK_PROPERTY_POST_REPLY_SUB, IOTX_MQTT_QOS1, _demo_message_arrive, NULL);
if (rc < 0) {
rc = -1;
goto do_exit;
#endif
IOT_MQTT_Yield(pclient, 200);
do {
/* handle the MQTT packet received from TCP or SSL connection */
HAL_SleepMs(2000);
} while (is_running);
IOT_MQTT_Unsubscribe(pclient, ALINK_PROPERTY_POST_REPLY_SUB);
IOT_MQTT_Unsubscribe(pclient, ALINK_SERVICE_SET_SUB);
#else
IOT_MQTT_Unsubscribe(pclient, TOPIC_DATA);
#endif
do_exit:
if (NULL != msg_buf) {
HAL_Free(msg_buf);
if (NULL != msg_readbuf) {
HAL_Free(msg_readbuf);
if (NULL != user_param)
HAL_Free(user_param);
user_param = NULL;
IOT_DumpMemoryStats(IOT_LOG_DEBUG);
IOT_CloseLog();
is_running = 0;
EXAMPLE_TRACE("out of sample!");
#endif /* MQTT_ID2_AUTH */
#ifdef MQTT_ID2_AUTH
#include "tfs.h"
static char __device_id2[TFS_ID2_LEN + 1];
static void mqtt_client_secure()
int rc = 0, msg_len, cnt = 0;
void *pclient;
iotx_mqtt_topic_info_t topic_msg;
char msg_pub[128];
char topic_update[IOTX_URI_MAX_LEN] = {0};
char topic_error[IOTX_URI_MAX_LEN] = {0};
char topic_get[IOTX_URI_MAX_LEN] = {0};
char topic_data[IOTX_URI_MAX_LEN] = {0};
rc = -1;
goto do_exit;
rc = -1;
goto do_exit;
HAL_GetID2(__device_id2);
/* Device AUTH */
rc = IOT_SetupConnInfoSecure(__product_key, __device_id2, __device_id2, (void **)&pconn_info);
if (rc != 0) {
goto do_exit;
HAL_Snprintf(topic_update,IOTX_URI_MAX_LEN,TOPIC_UPDATE_FMT,__product_key,__device_id2);
HAL_Snprintf(topic_error,IOTX_URI_MAX_LEN,TOPIC_ERROR_FMT,__product_key,__device_id2);
HAL_Snprintf(topic_get,IOTX_URI_MAX_LEN,TOPIC_GET_FMT,__product_key,__device_id2);
HAL_Snprintf(topic_data,IOTX_URI_MAX_LEN,TOPIC_DATA_FMT,__product_key,__device_id2);
pclient = IOT_MQTT_ConstructSecure(&mqtt_params);
rc = -1;
goto do_exit;
rc = IOT_MQTT_Subscribe(pclient, topic_data, IOTX_MQTT_QOS1, _demo_message_arrive, NULL);
if (rc < 0) {
rc = -1;
goto do_exit;
HAL_SleepMs(1000);
/* Initialize topic information */
memset(&topic_msg, 0x0, sizeof(iotx_mqtt_topic_info_t));
strcpy(msg_pub, "message: hello! start!");
topic_msg.qos = IOTX_MQTT_QOS1;
topic_msg.retain = 0;
topic_msg.dup = 0;
topic_msg.payload = (void *)msg_pub;
topic_msg.payload_len = strlen(msg_pub);
rc = IOT_MQTT_Publish(pclient, topic_data, &topic_msg);
EXAMPLE_TRACE("rc = IOT_MQTT_Publish() = %d", rc);
do {
/* Generate topic message */
cnt++;
msg_len = snprintf(msg_pub, sizeof(msg_pub), "{\"attr_name\":\"temperature\", \"attr_value\":\"%d\"}", cnt);
if (msg_len < 0) {
EXAMPLE_TRACE("Error occur! Exit program");
rc = -1;
break;
topic_msg.payload_len = msg_len;
if (rc < 0) {
EXAMPLE_TRACE("error occur when publish");
rc = -1;
break;
EXAMPLE_TRACE("packet-id=%u, publish topic msg='0x%02x%02x%02x%02x'...",
(uint32_t)rc,
msg_pub[0], msg_pub[1], msg_pub[2], msg_pub[3]
/* infinite loop if running with 'loop' argument */
if (user_argc >= 2 && user_param && !strcmp("loop", user_param)) {
HAL_SleepMs(2000);
cnt = 0;
} while (cnt < 1);
HAL_SleepMs(200);
do_exit:
HAL_Free(msg_buf);
user_param = NULL;
IOT_CloseLog();
#endif /* MQTT_ID2_AUTH*/
static int ali_mqtt_test_pub(void)
int rc = 0;
static uint16_t pub_msg_cnt = 0;
uint8_t rgb_switch = 0, rand_num_r = 0, rand_num_g = 0, rand_num_b = 0;
char msg_pub[512];
if (!is_running)
HAL_Printf("MQTT test is not running! Please start MQTT first by using the \"ali_mqtt_test start\" command");
return 0;
if (user_param && !strcmp("open", user_param))
rgb_switch = 1;
else if (user_param && !strcmp("close", user_param))
rgb_switch = 0;
else
return 0;
srand((int)(rt_tick_get()) / (pub_msg_cnt + 1));
rand_num_r = (uint8_t)(rand()%255);
srand((int)(rt_tick_get()) / (pub_msg_cnt + 2));
rand_num_g = (uint8_t)(rand()%255);
srand((int)(rt_tick_get()) / (pub_msg_cnt + 3));
rand_num_b = (uint8_t)(rand()%255);
memset(msg_pub, 0x0, sizeof(msg_pub));
"{\"id\" : \"%d\",\"version\":\"1.0\",\"params\" : "
"{\"RGBColor\" : {\"Red\":%d,\"Green\":%d,\"Blue\":%d},"
"\"LightSwitch\" : %d},"
"\"method\":\"thing.event.property.post\"}",
++pub_msg_cnt, rand_num_r, rand_num_g, rand_num_b, rgb_switch);
topic_msg.dup = 0;
rc = IOT_MQTT_Publish(pclient, ALINK_PROPERTY_POST_PUB, &topic_msg);
if (rc < 0) {
rc = -1;
return rc;
EXAMPLE_TRACE("\n publish message: \n topic: %s\n payload: %s\n rc = %d", ALINK_PROPERTY_POST_PUB, topic_msg.payload, rc);
#else
rc = IOT_MQTT_Publish(pclient, TOPIC_UPDATE, &topic_msg);
if (rc < 0) {
rc = -1;
return rc;
EXAMPLE_TRACE("\n publish message: \n topic: %s\n payload: \%s\n rc = %d", TOPIC_UPDATE, topic_msg.payload, rc);
rc = IOT_MQTT_Publish(pclient, TOPIC_DATA, &topic_msg);
if (rc < 0) {
rc = -1;
return rc;
EXAMPLE_TRACE("\n publish message: \n topic: %s\n payload: \%s\n rc = %d", TOPIC_DATA, topic_msg.payload, rc);
#endif
return 0;
static int ali_mqtt_main(int argc, char **argv)
rt_thread_t tid;
user_argc = argc;
if (2 == user_argc)
if (!strcmp("start", argv[1]))
if (1 == is_running)
HAL_Printf("MQTT test is already running! Please stop running first by using the \"ali_mqtt_test stop\" command\n");
return 0;
is_running = 1;
else if (!strcmp("stop", argv[1]))
if (0 == is_running)
HAL_Printf("MQTT test is already stopped!\n");
return 0;
is_running = 0;
// stop mqtt test
return 0;
else
HAL_Printf("Input param error! Example: ali_mqtt_test start/stop or ali_mqtt_test pub open/close\n");
return 0;
else if(3 == user_argc)
if (!strcmp("pub", argv[1]))
user_param = (char*)rt_strdup((const char*)argv[2]);
HAL_Printf("param:%s\n", user_param);
// publish
ali_mqtt_test_pub();
return 0;
else
return 0;
else
return 0;
#ifdef IOTX_PRJ_VERSION
HAL_Printf("iotkit-embedded sdk version: %s\n", IOTX_PRJ_VERSION);
#endif
HAL_SetProductKey(PRODUCT_KEY);
HAL_SetDeviceName(DEVICE_NAME);
HAL_SetDeviceSecret(DEVICE_SECRET);
tid = rt_thread_create("ali-mqtt",
(void (*)(void *))mqtt_client, NULL,
6 * 1024, RT_THREAD_PRIORITY_MAX / 2 - 1, 10);
#else
mqtt_client_secure, NULL,
#endif
if (tid != RT_NULL)
rt_thread_startup(tid);
return 0;
#ifdef RT_USING_FINSH
MSH_CMD_EXPORT_ALIAS(ali_mqtt_main, ali_mqtt_test, Example: ali_mqtt_test start/pub [open/close]/stop);
#endif
10 个回答
flyboy
flyboy 2019-10-26
第一步应该是把这个做参数解析,ptopic_info->payload_len
coulson
coulson 2019-10-27
能否详细说一下,我的微信15518189521
coulson
coulson 2019-10-27
cJSON* root=cJSON_Parse(ptopic_info->payload);
我是这样做的,但是通过cJSON* itemName = cJSON_GetObjectItem(root, "parms");后得到值是空的
bigjmagic
bigjmagic 2019-10-28
代码太长了,应该放json解析的关键代码,这样看起来才明白一些。第三张图片,cJSON_Parse存放的是json格式的数据串。
coulson
coulson 2019-10-28
coulson
coulson 2019-10-28
bigjmagic 发表于 2019-10-28 09:37
代码太长了,应该放json解析的关键代码,这样看起来才明白一些。第三张图片,cJSON_Parse存放的是json格式 ...
下面是解析部分的代码,我之前看错了,以为cJSON_Parse()是获取json字符串的跟目录,昨天发现不是,但是我参考网上的资料获取json字符串里的代码还是不正确,能帮我看看吗,私聊也可以,我的weixin15518189521
coulson
coulson 2019-10-29
输入ptopic_info-> payload_len这个参数编译出错,只有ptopic_info-> payload是正常的
flyboy
flyboy 2019-10-29
嗯嗯,我当时打错了,确实应该是这个 ptopic_info-> payload
flyboy
flyboy 2019-10-29
coulson 发表于 2019-10-28 11:22
下面是解析部分的代码,我之前看错了,以为cJSON_Parse()是获取json字符串的跟目录,昨天发现不是,但 ...
解析不对的话,可以多换几个API试试,cjson 一共没几个API,可以都处理一边这块内存,看哪个能解析出来。
coulson
coulson 2019-10-30
flyboy 发表于 2019-10-29 14:23
解析不对的话,可以多换几个API试试,cjson 一共没几个API,可以都处理一边这块内存,看哪个能解析出来。 ...
好的,经过反复测试,JSON的数据解析问题已经解决了,非常感谢
请登录后再发布答案,点击登录
1.4k
