win7 64位,没有开杀毒软件,安装打开报错,附件是.log
发布于 2019-12-26 15:09:25 浏览:906
* 本帖最后由 bpdwn 于 2019-12-26 15:14 编辑 * 附件是.log文件 ![微信图片_20191226150844.png](https://oss-club.rt-thread.org/uploads/201912/26/150854hz31u63oddk2tn9d.png) 下载附件 [.log](https://oss-club.rt-thread.org/uploads/201912/26/151406jckcuscvluehg8vg.attach)
bpdwn
2019-12-26
!SESSION 2019-12-26 14:49:58.597 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2019-12-26 14:50:16.801 !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt". !STACK 0 java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons: C:\Users\huangjianqing\.swt\lib\win32\x86_64\chromium-3071\libcef.dll: %1 不是有效的 Win32 应用程序。 Can't load library: C:\Users\huangjianqing\.swt\lib\win32\x86_64\C:\Users\huangjianqing\.swt\lib\win32\x86_64\chromium-3071\libcef.dll at org.eclipse.swt.internal.Library.loadLibrary(Library.java:329) at org.eclipse.swt.internal.chromium.CEFFactory.create(CEFFactory.java:30) at org.eclipse.swt.chromium.Chromium.loadLib(Chromium.java:1654) at org.eclipse.swt.chromium.Chromium.
(Chromium.java:103) at org.eclipse.swt.chromium.Browser.
(Browser.java:32) at org.rtthread.studio.application.login.LoginPage.createBrowserLogin(LoginPage.java:43) at org.rtthread.studio.application.login.LoginAction.login(LoginAction.java:29) at org.rtthread.studio.application.login.LoginAction.run(LoginAction.java:24) at org.rtthread.studio.application.ApplicationWorkbenchWindowAdvisor.login(ApplicationWorkbenchWindowAdvisor.java:828) at org.rtthread.studio.application.ApplicationWorkbenchWindowAdvisor.postWindowCreate(ApplicationWorkbenchWindowAdvisor.java:812) at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:784) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001) at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:139) at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:95) at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:77) at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1487) at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1458) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:910) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:118) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.lambda$2(WorkbenchSourceProvider.java:671) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89) at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1193) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1054) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1064) at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1543) at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2193) at org.eclipse.swt.widgets.Control.windowProc(Control.java:4765) at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:348) at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1502) at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2153) at org.eclipse.swt.widgets.Display.windowProc(Display.java:4770) at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method) at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:211) at org.eclipse.swt.widgets.Shell.open(Shell.java:1263) at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:747) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:693) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:781) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:752) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:746) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:730) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1099) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156) at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:636) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:563) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151) at org.rtthread.studio.application.Application.start(Application.java:135) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595) at org.eclipse.equinox.launcher.Main.run(Main.java:1501) !ENTRY org.eclipse.osgi 4 0 2019-12-26 14:50:16.900 !MESSAGE 应用程序错误 !STACK 1 java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons: C:\Users\huangjianqing\.swt\lib\win32\x86_64\chromium-3071\libcef.dll: %1 不是有效的 Win32 应用程序。 Can't load library: C:\Users\huangjianqing\.swt\lib\win32\x86_64\C:\Users\huangjianqing\.swt\lib\win32\x86_64\chromium-3071\libcef.dll at org.eclipse.swt.internal.Library.loadLibrary(Library.java:329) at org.eclipse.swt.internal.chromium.CEFFactory.create(CEFFactory.java:30) at org.eclipse.swt.chromium.Chromium.loadLib(Chromium.java:1654) at org.eclipse.swt.chromium.Chromium.
rcp
2019-12-26
>!SESSION 2019-12-26 14:49:58.597 ----------------------------------------------- >eclipse.buildId=unk ... --- 具体是做什么操作的时候,发生错误,发生错误时,界面状态是怎么样的,有截图吗
bpdwn
2019-12-26
>具体是做什么操作的时候,发生错误,发生错误时,界面状态是怎么样的,有截图吗 ... --- 上面的那个是截图的,安装完以后(安装过程没有任何问题),打开程序,卡在这个界面2-3S,然后就跳出那个log问题
bpdwn
2019-12-26
卡在这个界面2-3s
rcp
2019-12-27
估计被你环境变量里C:\Users\huangjianqing\.swt\lib\win32\x86_64 自带的chromium库干扰了,检查下环境变量里是不是有指向C:\Users\huangjianqing\.swt\lib\win32\x86_64 这种路径,去掉后重启电脑再试试
bpdwn
2020-01-01
>估计被你环境变量里C:%users\huangjianqing\.swt\lib\win32\x86_64 自带的chromium库干扰了,检查下环境 ... --- 我查看了全部环境变量,并没有这个swt,不懂为啥
rcp
2020-01-02
>我查看了全部环境变量,并没有这个swt,不懂为啥 --- 把这个目录下 C:\Users\huangjianqing\.swt\lib\win32\x86_64\ 的 chromium-3071文件夹删除掉试试
906
bpdwn
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
恩智浦mcxn947的RT-Thread的PIN驱动测评
