MQTTPacket_readPacket 这个接口会导致内存溢出
发布于 2020-02-04 17:08:49 浏览:2007
`MQTTPacket_readPacket`接口存在bug,如果接受的数据超过缓冲区的长度会出现内存溢出,没有判断缓冲区的长度。mqtt这个有点复杂,不知道怎么修复这个问题 ```c static int MQTTPacket_readPacket(MQTTClient *c) { int rc = PAHO_FAILURE; MQTTHeader header = {0}; int len = 0; int rem_len = 0; /* 1. read the header byte. This has the packet type in it */ if (net_read(c, c->readbuf, 1, 0) != 1) goto exit; len = 1; /* 2. read the remaining length. This is variable in itself */ decodePacket(c, &rem_len, 50); len += MQTTPacket_encode(c->readbuf + 1, rem_len); /* put the original remaining length back into the buffer */ /* 3. read the rest of the buffer using a callback to supply the rest of the data */ if (rem_len > 0 && (net_read(c, c->readbuf + len, rem_len, 300) != rem_len)) goto exit; header.byte = c->readbuf[0]; rc = header.bits.type; exit: return rc; } ``` rem_len 是网络的待接收的数据长度. `c->readbuf`是接收数据的缓冲区,如果rem_len的值大于readbuf的大小就会出现溢出 ```c static int net_read(MQTTClient *c, unsigned char *buf, int len, int timeout) { int bytes = 0; int rc; while (bytes < len) { #ifdef MQTT_USING_TLS if (c->tls_session) { rc = mbedtls_client_read(c->tls_session, &buf[bytes], (size_t)(len - bytes)); if (rc <= 0) { bytes = -1; break; } else { bytes += rc; } goto _continue; } #endif rc = recv(c->sock, &buf[bytes], (size_t)(len - bytes), MSG_DONTWAIT); if (rc == -1) { if (errno != ENOTCONN && errno != ECONNRESET) { bytes = -1; break; } } else bytes += rc; #ifdef MQTT_USING_TLS _continue: #endif if (bytes >= len) { break; } if (timeout > 0) { fd_set readset; struct timeval interval; LOG_D("net_read %d:%d, timeout:%d", bytes, len, timeout); // modify by k999 ([email]hijxyz@163.com[/email]) if (timeout >= 1000) { interval.tv_sec = timeout / 1000; interval.tv_usec = (timeout % 1000) * 1000; } else { interval.tv_sec = 0; interval.tv_usec = timeout * 1000; } timeout = 0; FD_ZERO(&readset); FD_SET(c->sock, &readset); select(c->sock + 1, &readset, RT_NULL, RT_NULL, &interval); } else { LOG_D("net_read %d:%d, break!", bytes, len); break; } } return bytes; } ```
Polarbear
2021-06-25
楼主有出现过因为 ```c if (net_read(c, c->readbuf, 1, 0) != 1) goto exit; ``` 执行了 ```c LOG_D("net_read %d:%d, break!", bytes, len); ``` 导致出现的掉线重连的情况吗?
2020-02-04
你的单个消息有多大啊?
hijxyz
2020-02-04
>你的单个消息有多大啊? --- 我一开始是设置缓冲区是1500,我就用2000的包去测试,就发现死机了。我觉得这个问题是直接导致死机的是比较严重的
2020-02-04
嗯,楼主可以尝试限制下,在拷贝payload的时候限制一下长度。
hijxyz
2020-02-04
>嗯,楼主可以尝试限制下,在拷贝payload的时候限制一下长度。 ```c /* 2. read the remaining length. This is variable in itself */ decodePacket(c, &rem_len, 50); len += MQTTPacket_encode(c->readbuf + 1, rem_len); /* put the original remaining length back into the buffer */ // add by k999 ([email]hijxyz@163.com[/email]) if(rem_len > (c->readbuf_size - len)){ LOG_D("rem_len(%d) > read_buf_size(%d)", rem_len, c->readbuf_size - len); rem_len = c->readbuf_size - len; } /* 3. read the rest of the buffer using a callback to supply the rest of the data */ if (rem_len > 0 && (net_read(c, c->readbuf + len, rem_len, 300) != rem_len)) goto exit; ``` 我加了这段判断限制了,是可以接受这段数据不会死机,但是接收完之后就会断开mqtt的连接了。像似没有把整个包接收完整,会影响下一个数据包的接收
2020-02-05
嗯,需要把后面的数据空读,以丢弃掉。
hijxyz
2020-02-06
>嗯,需要把后面的数据空读,以丢弃掉。 好的,我试试:victory:
2k
hijxyz
