easyflash快速多次写入
发布于 2020-03-11 17:18:54 浏览:1974
在使用easyflash时,进行类似 while(1) { ef_set_env_blob("device_para", (char*)&device_set_parameter,sizeof(device_set_parameter)); rt_thread_mdelay(10); rt_kprintf("run
"); } 会出现 [Flash] (packages\EasyFlash-latest\src\ef_env.c:1059) Trigger a GC check after alloc ENV failed. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1190) Warning: Alloc an ENV (size 226) failed when new ENV. Now will GC then retry. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1258) The remain empty sector is 1, GC threshold is 1. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1174) Moved the ENV (boot_times) from 0x00001010 to 0x00000010. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1174) Moved the ENV (factory_set_flag) from 0x00001033 to 0x00000033. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1174) Moved the ENV (energy_para) from 0x00001061 to 0x00000061. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1174) Moved the ENV (RN8302_RegSet) from 0x000010D4 to 0x000000D4. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1174) Moved the ENV (device_para) from 0x00001ECD to 0x0000018F. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1238) Collect a sector @0x00001000 这是什么情况??
sunwan
2020-03-11
1个扇区写满了,然后把旧数据移动到新扇区,旧扇区擦除备用。
db520136
2020-03-12
[i=s] 本帖最后由 db520136 于 2020-3-12 08:19 编辑 [/i] >1个扇区写满了,然后把旧数据移动到新扇区,旧扇区擦除备用。 --- [Flash] (packages\EasyFlash-latest\src\ef_env.c:1059) Trigger a GC check after alloc ENV failed. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1190) Warning: Alloc an ENV (size 226) failed when new ENV. Now will GC then retry. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1258) The remain empty sector is 1, GC threshold is 1. (rt_object_get_type((rt_object_t)thread) == RT_Object_Class_Thread) assertion failed at function:rt_thread_control, line numbe\0 死在了rt_assert_handler()里,这个也是?为什么会死机??这个情况是程序中连续多次设置参数,每次设置参数都会调用ef_set_env_blob进行保存的,多来几次就出现异常死机了
sunwan
2020-03-12
>[Flash] (packages\EasyFlash-latest\src\ef_env.c:1059) Trigger a GC check after alloc ENV failed. >[F ... --- 我发现easyflash的读写操作对父线程(就是调用ef_set_env_blob或ef_get_env_blob函数的线程)的栈要大点,一般大于2048K或4096K会比较安全。
db520136
2020-03-14
>我发现easyflash的读写操作对父线程(就是调用ef_set_env_blob或ef_get_env_blob函数的线程)的栈要大点 ... --- 是的,我后来也是这么做的,把ef_set_env_blob函数放在了一个2048字节大小的线程中,就没有死机情况出现了! 感谢大哥,解答!!
2k
db520136
23
恩智浦mcxn947的RT-Thread的PIN驱动测评
