QSPI_core.c 库BUG请确认
发布于 2020-04-09 15:13:45 浏览:997
平台:lpc54608+MX25L256 Flash 由于使用4线QSPI模式故Flash需开启QSPI Mode 需要写flash寄存器 (规则=命令+寄存器) 利用rt_qspi_send函数 void mx25lxx_enter_qspi_mode(struct rt_qspi_device *device) { uint8_t cs = 1; uint8_t write_enable = 0x06; uint8_t read_status = 0x05; uint8_t read_status1 = 0x15; uint8_t status; uint8_t Config; uint8_t write_status_buf[3] = {0x01, 0x40}; rt_qspi_send_then_recv(device, &read_status, 1, &status, 1); rt_qspi_send_then_recv(device, &read_status1, 1, &Config, 1); rt_kprintf("read status register = %x %x
", status,Config); if((status&0x40)!=0x40){ rt_qspi_send(device, &write_enable, 1); rt_qspi_send(device, write_status_buf, 2); } rt_qspi_send_then_recv(device, &read_status, 1, &status, 1); rt_qspi_send_then_recv(device, &read_status1, 1, &Config, 1); qspi_mode_flag = 1; rt_kprintf("read status register = %x %x
", status,Config); rt_kprintf("mx25lxx_enter_qspi_mode
"); } 在函数rt_qspi_send中会发现函数里判断if (length > 1)如果大于1就认为是需要判断地址 并且还判断length长度是否为大于4 和5 (判断地址是3线还是4线) 当调用rt_qspi_send去写寄存器时命令加寄存器内容长度为2则会返回一个return -RT_ERROR;跳出命令和寄存器都不能发送出去 rt_err_t rt_qspi_send(struct rt_qspi_device *device, const void *send_buf, rt_size_t length) { RT_ASSERT(send_buf); RT_ASSERT(length != 0); struct rt_qspi_message message; char *ptr = (char *)send_buf; rt_size_t count = 0; rt_err_t result = 0; message.instruction.content = ptr[0]; message.instruction.qspi_lines = 1; count++; /* get address */ if (length > 1) { if (device->config.medium_size > 0x1000000 && length >= 5) { /* medium size greater than 16Mb, address size is 4 Byte */ message.address.content = (ptr[1] << 24) | (ptr[2] << 16) | (ptr[3] << 8) | (ptr[4]); message.address.size = 32; message.address.qspi_lines = 1; count += 4; } else if (length >= 4) { /* address size is 3 Byte */ message.address.content = (ptr[1] << 16) | (ptr[2] << 8) | (ptr[3]); message.address.size = 24; message.address.qspi_lines = 1; count += 3; } else { return -RT_ERROR; 当需要发送长度为2 3时此处跳出命令及寄存器无法发送 } } else { /* no address stage */ message.address.content = 0 ; message.address.qspi_lines = 0; message.address.size = 0; } message.alternate_bytes.content = 0; message.alternate_bytes.size = 0; message.alternate_bytes.qspi_lines = 0; message.dummy_cycles = 0; /* determine if there is data to send */ if (length - count > 0) { message.qspi_data_lines = 1; } else { message.qspi_data_lines = 0; } /* set send buf and send size */ message.parent.send_buf = ptr + count; message.parent.recv_buf = RT_NULL; message.parent.length = length - count; message.parent.cs_take = 1; message.parent.cs_release = 1; result = rt_qspi_transfer_message(device, &message); if (result == 0) { result = -RT_EIO; } else { result = length; } return result; } 由此引发无法配置Flash某些命令+寄存的配置 并且在msh中 sf status 写寄存器也会无法写成功 修改方案1:if (length > 1) 改成 if (length > 3) 修改方案2:return -RT_ERROR; 地方再加上length为2 3的处理
cychen
2020-04-09
flash的读写图无法上传:'(
RT-Thread小喇叭
2020-04-09
>flash的读写图无法上传 --- 无法上传图片?
cychen
2020-04-09
Flash 配置寄存器时序
cychen
2020-04-09
rt_qspi_send(device, write_status_buf, 2);此处发送会返回Err 导致配置不成功 因为长度为2 直接返回错误
XVJT_2779
2022-03-25
小白的发展过程!!!!
目前测试的确是这样,不知道官方怎么测试通过的。
997
cychen
66
