正点原子的stm32f407挂在文件系统出错
发布于 2020-05-17 17:59:11 浏览:1440
按照教程开启相应的选项,初始化有一个错误[SFUD] Find a Winbond flash chip. Size is 16777216 bytes. [SFUD] W25Q128 flash device is initialize success. [31m[E/DFS] There is no space to register this file system (rom).[0m 哪位大神遇到过这个问题,指点一下
466305213
2020-05-17
是挂w25q128?是的话看看有没有block device
wang512528
2020-05-17
>是挂w25q128?是的话看看有没有block device --- 有的 [20:31:19.764]收←◆ \ | / - RT - Thread Operating System / | \ 3.1.3 build May 14 2020 2006 - 2019 Copyright by rt-thread team [SFUD] Find a Winbond flash chip. Size is 16777216 bytes. [SFUD] W25Q128 flash device is initialize success. [31m[E/DFS] There is no space to register this file system (rom).[0m File System initialized! msh /> [20:31:35.422]发→◇ls Directory /: [20:32:00.671]发→◇list_device device type ref count ------- -------------------- ---------- W25Q128 Block Device 1 spi10 SPI Device 0 spi1 SPI Bus 0 uart1 Character Device 2 pin Miscellaneous Device 0
2020-05-17
贴下你挂载文件系统地方的代码
wang512528
2020-05-18
>贴下你挂载文件系统地方的代码 --- 就在主函数加了个spiflash_test(),其他地方都是用ENV配置BSP,代码没有修改 /* * Copyright (c) 2006-2018, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2018-11-06 SummerGift first version * 2018-11-19 flybreak add stm32f407-atk-explorer bsp */ #include
/* defined the LED0 pin: PF9 */ #define LED0_PIN GET_PIN(F, 9) SPI_HandleTypeDef hspi1; void spiflash_test(void); int main(void) { int count = 1; /* set LED0 pin mode to output */ rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); HAL_SPI_MspInit(&hspi1); spiflash_test(); while (count++) { rt_pin_write(LED0_PIN, PIN_HIGH); rt_thread_mdelay(500); rt_pin_write(LED0_PIN, PIN_LOW); rt_thread_mdelay(500); } return RT_EOK; } void spiflash_test(void) { rt_device_t dev; dev = rt_device_find("W25Q128"); RT_ASSERT(dev != RT_NULL); if (dev != RT_NULL) { /* Filesystem Initialization */ #if defined(RT_USING_DFS) && defined(RT_USING_DFS_ELMFAT) /* mount sd card fat partition 1 as root directory */ //?????????? if (dfs_mount("W25Q128", "/", "elm", 0, 0) == 0) { rt_kprintf("File System initialized!\n"); } else { rt_kprintf("File System initialzation failed!\n"); } #endif /* RT_USING_DFS && RT_USING_DFS_ELMFAT */ } }
学长啊啊啊
2020-05-18
工程里找找 有个spi_flash_init.c 按照这里的示例运行
2020-05-18
看出来问题了哈; 1.HAL_SPI_MspInit(&hspi1); 这个不要了 2.你并没有挂载spi flash到spi bus上
wang512528
2020-05-18
>看出来问题了哈; >1.HAL_SPI_MspInit(&hspi1); 这个不要了 >2.你并没有挂载spi flash到spi bus上 ... --- 首先表示感谢,但是还是不行,去掉1,第二点不是很清楚 \ | / - RT - Thread Operating System / | \ 3.1.3 build May 18 2020 2006 - 2019 Copyright by rt-thread team [SFUD] Find a Winbond flash chip. Size is 16777216 bytes. [SFUD] W25Q128 flash device is initialize success. [31m[E/DFS] There is no space to register this file system (rom).[0m File System initialzation failed!
2020-05-18
>首先表示感谢,但是还是不行,去掉1,第二点不是很清楚 > \ | / >- RT - Thread Operating System --- ``` rt_hw_spi_device_attach("spi1", "spi10",GPIOE, GPIO_PIN_1); if (RT_NULL == rt_sfud_flash_probe("W25Q256", "spi10")) { return -RT_ERROR; }; device = rt_device_find("W25Q256"); while (device != RT_NULL) { if (dfs_mount("W25Q256", "/", "elm", 0, 0) == RT_EOK) { ```
abofly
2020-05-18
filesystem_table, 仿真看看这个结构体有值没有,是不是啥没使能比如:RT_USING_DFS_DEVFS
wang512528
2020-05-18
已解决,重新建了RTT工程,没有用建好的BSP,具体BSP不成功的原因还在找
1.4k
wang512528
