Filesystem
树莓派_Raspberry-Pi
树莓派sd卡上面两个分区,只能挂载sd0,挂载sd1就失败
发布于 2020-06-14 15:20:51 浏览:1749
系统启动正常,也能识别到两个sd,sd0和sd1如下所示: ``` \ | / - RT - Thread Operating System / | \ 4.0.3 build May 31 2020 2006 - 2020 Copyright by rt-thread team [32m[I/I2C] I2C bus [i2c0] registered[0m [32m[I/I2C] I2C bus [i2c1] registered[0m [15:06:39.181]收←◆[32m[I/SDIO] SD card capacity 31166976 KB.[0m file system initialization failed! boot cpu:3 cpu 3 startup. found part[0], begin: 4194304, size: 256.0MB found part[1], begin: 272629760, size: 6.580GB start OK: CPU 3 boot cpu:2 cpu = 0x00000002 cpu 2 startup. start OK: CPU 2 boot cpu:1 cpu = 0x00000001 cpu 1 startup. start OK: CPU 1 ``` 也能发现两个设备,如下所示: ``` [15:06:48.373]收←◆list_device device type ref count -------- -------------------- ---------- sd1 Block Device 0 sd0 Block Device 1 hdmi Graphic Device 0 rtc RTC 0 spi0.1 SPI Device 0 spi0.0 SPI Device 0 spi0 SPI Bus 0 wdg Miscellaneous Device 0 i2c1 I2C Bus 0 i2c0 I2C Bus 0 gpio Miscellaneous Device 0 timer3 Timer Device 0 timer1 Timer Device 0 uart1 Character Device 2 ``` 但是代码里,dfs_mount只能挂载sd0,sd0改成sd1就挂载失败 `dfs_mount("sd0", "/", "elm", 0, 0)` 可以 `dfs_mount("sd1", "/", "elm", 0, 0)` 失败
w501229485
2020-06-14
有人有同样的情况么?
w501229485
2020-06-14
hello???
2020-06-14
不要都挂载在 / 目录下 你可以在 / 目录下创建一个新的文件夹 然后sd1挂载到这个目录下
w501229485
2020-06-14
>不要都挂载在 / 目录下 你可以在 / 目录下创建一个新的文件夹 然后sd1挂载到这个目录下 ... 试了,我挂载了两个,还是sd0成功,sd1失败
w501229485
2020-06-14
挂载两个的时候有错误提示了 There is no space to mount this file system (elm). file system2 initialization failed! 我mnt.c源码如下所示: ```c #ifdef BSP_USING_SDIO0 #include
int mnt_init(void) { rt_thread_delay(RT_TICK_PER_SECOND); if (dfs_mount("sd0", "/", "elm", 0, 0) == 0) { rt_kprintf("file system1 initialization done!\n"); }else{ rt_kprintf("file system1 initialization failed!\n"); } rt_thread_delay(RT_TICK_PER_SECOND); if (dfs_mount("sd1", "/home", "elm", 0, 0) == 0) { rt_kprintf("file system2 initialization done!\n"); }else{ rt_kprintf("file system2 initialization failed!\n"); } return 0; } INIT_ENV_EXPORT(mnt_init); #endif ```
2020-06-14
>挂载两个的时候有错误提示了 > >There is no space to mount this file system (elm). 修改一下rtconfig.h试试 ```c #define RT_USING_DFS #define DFS_USING_WORKDIR #define DFS_FILESYSTEMS_MAX 3 #define DFS_FILESYSTEM_TYPES_MAX 2 #define DFS_FD_MAX 16 #define RT_USING_DFS_ELMFAT ```
w501229485
2020-06-14
>修改一下rtconfig.h试试 --- 还是不行,也不报错了,就是第二个挂载失败 [17:35:38.436]收←◆file system1 initialization done! [17:35:38.788]收←◆file system2 initialization failed!
w501229485
2020-06-14
也不知道是否是解决了,上电进入系统 mkdfs -t elm sd1一下,然后再把mnt.c文件中更改为挂载sd1,从新镜像导入,然后上电,就挂载上了!???,蜜汁操作结果解决了,不过又来了一个新问题,之前sd卡有两个分区,boot和root,现在root在linux上不显示了,哈哈哈哈,而且我在在线手册上都找不到mkdfs这个是干嘛的指令,就是进入rtt系统才看到
w501229485
2020-06-14
小结一下,mkdfs 是格式化成rtt能使用的文件系统格式,然后就可以多个挂载了,按照我上面的方法就能够同时挂载多个文件系统
1.7k
w501229485
23
字库除了SD卡和http还有别的方式导入吗
EasyFlash好棒
SD卡挂在的SPI总线又要加个DA设备
请教ramfs使用方法
rtt stable2.0.x版本 sd卡及文件系统
nandflash文件系统UFFS请教
关于SD卡挂载文件系统的问题(已解决)
Yaffs采用GPL2许可
