OTA 片上FLASH擦除失败
发布于 2020-07-03 11:02:25 浏览:2123
![QQ截图20200703110004.png](/uploads/20200703/7721fa71b799d13ee2311dcc45278a83.png) ![5f6704f48a5b3a85ee3a5883664e463d.png](/uploads/20200707/5f6704f48a5b3a85ee3a5883664e463d.png) ![QQ截图20200703105936.png](/uploads/20200703/bc5229769f2f181e0ec32d668117bc60.png) ```c #define RT_APP_PART_ADDR 0x08010000 extern const struct fal_flash_dev stm32_onchip_flash; /* flash device table */ #define FAL_FLASH_DEV_TABLE \ { \ &stm32_onchip_flash, \ } /* ====================== Partition Configuration ========================== */ #ifdef FAL_PART_HAS_TABLE_CFG /* partition table */ #define FAL_PART_TABLE \ { \ {FAL_PART_MAGIC_WROD, "app", "onchip_flash", 64* 1024, 512 * 1024, 0}, \ {FAL_PART_MAGIC_WROD, "download", "onchip_flash", 576* 1024, 384 * 1024, 0}, \ } #endif /* FAL_PART_HAS_TABLE_CFG */ #endif /* _FAL_CFG_H_ */ ``` 后发现是我使用了硬件SPI的u8g2,导致片内flash擦写失败,提示:[E/FAL] (fal_partition_erase:510) Partition erase error! Flash device(onchip_flash) erase error! 去掉u8g2线程初始化就正常擦写,后来新建工程只添加硬件SPI 和FAL,还是同样的状况,使用的是ST官方的L496ZG开发板,rtt4.0.2,最新软件包 u8g2程序: ``` #include "menu.h" struct menu_entry_type { const uint8_t *font; uint16_t icon; const char *name; }; struct menu_state { int16_t menu_start; /* in pixel */ int16_t frame_position; /* in pixel */ uint8_t position; /* position, array index */ }; /* Icon configuration Width and height must match the icon font size GAP: Space between the icons BGAP: Gap between the display border and the cursor. */ #define ICON_WIDTH 32 #define ICON_HEIGHT 32 #define ICON_GAP 4 #define ICON_BGAP 16 #define ICON_Y 32+ ICON_GAP static struct menu_entry_type menu_entry_list[] = { { u8g2_font_open_iconic_play_4x_t, 77,"音乐播放" }, { u8g2_font_open_iconic_mime_4x_t, 64,"收音机" }, { u8g2_font_open_iconic_embedded_4x_t, 70,"心率检测" }, { u8g2_font_open_iconic_embedded_4x_t, 74,"蓝牙连接" }, { u8g2_font_open_iconic_embedded_4x_t, 66,"关于" }, { NULL, 0, NULL } }; static void draw(struct menu_state *state) { int16_t x; uint8_t i; x = state->menu_start; i = 0; while( menu_entry_list[i].icon > 0 ) { if ( x >= -ICON_WIDTH && x < u8g2.getDisplayWidth() ) { u8g2.setFont(menu_entry_list[i].font); u8g2.drawGlyph(x, ICON_Y, menu_entry_list[i].icon ); } i++; x += ICON_WIDTH + ICON_GAP; } u8g2.drawFrame(state->frame_position-1, ICON_Y-ICON_HEIGHT-1, ICON_WIDTH+2, ICON_WIDTH+2); u8g2.drawFrame(state->frame_position-2, ICON_Y-ICON_HEIGHT-2, ICON_WIDTH+4, ICON_WIDTH+4); u8g2.drawFrame(state->frame_position-3, ICON_Y-ICON_HEIGHT-3, ICON_WIDTH+6, ICON_WIDTH+6); } static void to_right(struct menu_state *state) { if ( menu_entry_list[state->position+1].font != NULL ) { if ( (int16_t)state->frame_position+ 2*(int16_t)ICON_WIDTH + (int16_t)ICON_BGAP < (int16_t)u8g2.getDisplayWidth() ) { state->position++; state->frame_position += ICON_WIDTH + (int16_t)ICON_GAP; } else { state->position++; state->frame_position = (int16_t)u8g2.getDisplayWidth() - (int16_t)ICON_WIDTH - (int16_t)ICON_BGAP; state->menu_start = state->frame_position - state->position*((int16_t)ICON_WIDTH + (int16_t)ICON_GAP); } } } static void to_left(struct menu_state *state) { if ( state->position > 0 ) { if ( (int16_t)state->frame_position >= (int16_t)ICON_BGAP+(int16_t)ICON_WIDTH+ (int16_t)ICON_GAP ) { state->position--; state->frame_position -= ICON_WIDTH + (int16_t)ICON_GAP; } else { state->position--; state->frame_position = ICON_BGAP; state->menu_start = state->frame_position - state->position*((int16_t)ICON_WIDTH + (int16_t)ICON_GAP); } } } static uint8_t towards_int16(int16_t *current, int16_t dest) { if ( *current < dest ) { (*current)++; return 1; } else if ( *current > dest ) { (*current)--; return 1; } return 0; } static uint8_t towards(struct menu_state *current, struct menu_state *destination) { uint8_t r = 0; r |= towards_int16( &(current->frame_position), destination->frame_position); r |= towards_int16( &(current->frame_position), destination->frame_position); r |= towards_int16( &(current->menu_start), destination->menu_start); r |= towards_int16( &(current->menu_start), destination->menu_start); return r; } static struct menu_state current_state = { ICON_BGAP, ICON_BGAP, 0 }; static struct menu_state destination_state = { ICON_BGAP, ICON_BGAP, 0 }; static void music_entry(void) { ... } static void fm_entry(void) { ... } static void health_entry(void) { ... } static void bluetooth_entry(void) { ... } static void menu_entry(void *parameter) { u8g2.begin(/*Select=*/ U8G2_PIN_SELECT, /*Right/Next=*/ U8G2_PIN_RIGHT, /*Left/Prev=*/ U8G2_PIN_LEFT, /*Up=*/ U8G2_PIN_UP, /*Down=*/ U8G2_PIN_DOWN, /*Home/Cancel=*/ U8G2_PIN_HOME); u8g2.enableUTF8Print(); u8g2.setFont(u8g2_font_wqy14_t_gb2312); u8g2.setContrast(128); u8g2.clearBuffer(); u8g2.setCursor(30, 20); u8g2.print("欢迎使用"); u8g2.sendBuffer(); rt_thread_mdelay(5000); u8g2.clearBuffer(); u8g2.setCursor(30, 20); u8g2.print("初始化中"); u8g2.setCursor(0, 50); u8g2.print("请耐心等待系统启动"); u8g2.sendBuffer(); rt_sem_take(init_sem, RT_WAITING_FOREVER); while(1) { int8_t event; do { u8g2.clearBuffer(); u8g2.setFont(u8g2_font_6x12_tr); draw(¤t_state); u8g2.setFont(u8g2_font_wqy14_t_gb2312); u8g2.setCursor((u8g2.getDisplayWidth()-u8g2.getUTF8Width(menu_entry_list[destination_state.position].name))/2,u8g2.getDisplayHeight()-5); u8g2.print(menu_entry_list[destination_state.position].name); u8g2.sendBuffer(); rt_thread_mdelay(10); event = u8g2.getMenuEvent(); if ( event == U8X8_MSG_GPIO_MENU_NEXT ) to_right(&destination_state); if ( event == U8X8_MSG_GPIO_MENU_PREV ) to_left(&destination_state); if ( event == U8X8_MSG_GPIO_MENU_UP ) rt_device_write(serial, 0, "AT+CE\r\n", sizeof("AT+CE\r\n")); if ( event == U8X8_MSG_GPIO_MENU_DOWN ) rt_device_write(serial, 0, "AT+CF\r\n", sizeof("AT+CF\r\n")); if ( event == U8X8_MSG_GPIO_MENU_SELECT ) { if ( destination_state.position == 0 ) { music_entry(); } else if ( destination_state.position == 1 ) fm_entry(); else if ( destination_state.position == 2 ) health_entry(); else if ( destination_state.position == 3 ) bluetooth_entry(); else if ( destination_state.position == 4 ) { u8g2.userInterfaceMessage(menu_entry_list[destination_state.position].name,"", "", " Ok "); } else { rt_kprintf ("position : %10d\r\n",destination_state.position); } } } while ( towards(¤t_state, &destination_state) ); rt_thread_mdelay(10); } } int rt_hw_menu_port(void) { menu = rt_thread_create("menu", menu_entry, RT_NULL, 2048, 3, 10); if (menu != RT_NULL) rt_thread_startup(menu); return 0; } INIT_APP_EXPORT(rt_hw_menu_port); MSH_CMD_EXPORT(rt_hw_menu_port,1); ```
2020-07-03
你的BootLoader设置的download区大小跟程序里设置好像不太一样。 BootLoader里是0x70000,程序里是0x60000。 把这两个地方改一致试试看能不能解决你的问题吧。
红枫
2020-07-03
用的那款mcu
打盹的消防车
2020-07-06
忙着打盹...
找到问题原因了,使用硬件SPI 的u8g2之后flash无法擦写,注释掉u8g2初始化线程就正常擦写
xp187oo
2020-07-06
你的问题修复了吗?我和你遇到类似的问题了。
2.1k
打盹的消防车
忙着打盹...
30
关于FAL移植
添加fal软件包之后编译出现错误,求助!
FAL驱动移植&构建脚本问题
帮我看一下这样分区会不会冲突??
EasyFlash 4.0疑似出BUG
疑似FAL日志输出与DFS冲突??
fal软件包偏移量大于等于当前分区的大小会报错
为什么片内Flash总是写失败?
片上flash的文件系统的建立
