自动重连
W5500 如何实现断开重连?
发布于 2020-07-11 16:32:22 浏览:2839
基于tcpclient_sample.c,我改为了while(1),会阻塞在recv()函数,如果连接断开连接也不能自动重连。 ```c #define BUFSZ 1024 static const char send_data[] = "This is TCP Client from RT-Thread.\n"; /* 发送用到的数据 */ void tcpclient(int argc, char **argv) { int ret; char *recv_data; struct hostent *host; int sock, bytes_received; struct sockaddr_in server_addr; const char *url; int port; struct wiz_socket *wsocket = RT_NULL; if (argc < 3) { rt_kprintf("Usage: tcpclient URL PORT\n"); rt_kprintf("Like: tcpclient 192.168.12.44 5000\n"); return; } url = argv[1]; port = strtoul(argv[2], 0, 10); /* 通过函数入口参数url获得host地址(如果是域名,会做域名解析) */ host = gethostbyname(url); while (1) //为了断线重连 { rt_thread_delay(1000); /* 分配用于存放接收数据的缓冲 */ recv_data = rt_malloc(BUFSZ); if (recv_data == RT_NULL) { rt_kprintf("No memory\n"); //return; continue; } /* 创建一个socket,类型是SOCKET_STREAM,TCP类型 */ if ((sock = socket(AF_INET, SOCK_STREAM, 0)) == -1) { /* 创建socket失败 */ rt_kprintf("Socket error\n"); /* 释放接收缓冲 */ rt_free(recv_data); //return; continue; } wsocket = wiz_get_socket(sock); /* 初始化预连接的服务端地址 */ server_addr.sin_family = AF_INET; server_addr.sin_port = htons(port); server_addr.sin_addr = *((struct in_addr *) host->h_addr); rt_memset(&(server_addr.sin_zero), 0, sizeof(server_addr.sin_zero)); /* 连接到服务端 */ if (connect(sock, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)) == -1) { /* 连接失败 */ rt_kprintf("Connect fail!\n"); closesocket(sock); /*释放接收缓冲 */ rt_free(recv_data); //return; continue; } else { /* 连接成功 */ rt_kprintf("Connect successful, sock=%d. , port=%d\n", sock, wsocket->port); } while (1) { /* 从sock连接中接收最大BUFSZ - 1字节数据 */ bytes_received = recv(sock, recv_data, BUFSZ - 1, 0); if (bytes_received < 0) { /* 接收失败,关闭这个连接 */ closesocket(sock); rt_kprintf("\nreceived error,close the socket.\r\n"); /* 释放接收缓冲 */ rt_free(recv_data); break; } else if (bytes_received == 0) { /* 默认 recv 为阻塞模式,此时收到0认为连接出错,关闭这个连接 */ closesocket(sock); rt_kprintf("\nreceived error,close the socket.\r\n"); /* 释放接收缓冲 */ rt_free(recv_data); break; } /* 有接收到数据,把末端清零 */ recv_data[bytes_received] = '\0'; /* 在控制终端显示收到的数据 */ rt_kprintf("\nReceived data = %s ", recv_data); /* 发送数据到sock连接 */ ret = send(sock, send_data, strlen(send_data), 0); if (ret < 0) { /* 接收失败,关闭这个连接 */ closesocket(sock); rt_kprintf("\nsend error,close the socket.\r\n"); rt_free(recv_data); break; } else { /* 打印send函数返回值为0的警告信息 */ rt_kprintf("\n Send warning,send function return %d.\r\n", ret); } } } return; } ```
2020-07-14
你都while1了,怎么退出呢? 楼主可以试试select
一路寻梦
2021-05-20
select 写唤醒有问题,也就是它的非阻塞移植是有问题的,还有就是如何在通迅中非法拔掉网线,那真是一场灾难。官方现在还没解决这些问题,只能自己想办法
文武斌
2022-03-27
recv的返回值可以判断是否出错 再检查 errno 就可以判断出 是接收到数据 还是因为阻塞超时 还是因为socket断开了
2.8k
Stoneman
W5500软件包开机无法解析link.rt-thread.org
W5500初始化全部都OK,电脑能ping板子,板子ping不通电脑
w5500 编译错误
求个SPI上挂W5500、Max6675两个设备的驱动例子
TFTP与W5500配合能传文件但无内容
wiznet(W5500) 设置MAC
SPI总线挂接2个W5500以太网芯片
多网卡建立链路问题,求官方解答
为什么W5500一直显示无法挂载
基于w5500的libmodbus复位后modbusTCP的监听一直失败
