5 使用rtthread官方例程读取SD卡信息,在rt_device_open处卡死
发布于 2020-07-13 10:48:55
#include <rtthread.h>
#include <rtdevice.h>
#include <stdlib.h>
#define SD_DEVICE_NAME    "sd0"
void fill_buffer(rt_uint8_t *buff, rt_uint32_t buff_length)
    rt_uint32_t index;
    /* 往缓冲区填充随机数 */
    for (index = 0; index < buff_length; index++)
        buff[index] = ((rt_uint8_t)rand()) & 0xff;
static int sd_sample(int argc, char *argv[])
    rt_err_t ret;
    rt_device_t sd_device;
    char sd_name[RT_NAME_MAX];
    rt_uint8_t *write_buff, *read_buff;
    struct rt_device_blk_geometry geo;
    rt_uint8_t block_num;
    /* 判断命令行参数是否给定了设备名称 */
    if (argc == 2)
        rt_strncpy(sd_name, argv[1], RT_NAME_MAX);
    else
        rt_strncpy(sd_name, SD_DEVICE_NAME, RT_NAME_MAX);
    /* 查找设备获取设备句柄 */
    sd_device = rt_device_find(sd_name);
    if (sd_device == RT_NULL)
        rt_kprintf("find device %s failed!\n", sd_name);
        return RT_ERROR;
    /* 打开设备 */
    ret = rt_device_open(sd_device, RT_DEVICE_OFLAG_RDWR);
    if (ret != RT_EOK)
        rt_kprintf("open device %s failed!\n", sd_name);
        return ret;
    rt_memset(&geo, 0, sizeof(geo));
    /* 获取块设备信息 */
    ret = rt_device_control(sd_device, RT_DEVICE_CTRL_BLK_GETGEOME, &geo);
    if (ret != RT_EOK)
        rt_kprintf("control device %s failed!\n", sd_name);
        return ret;
    rt_kprintf("device information:\n");
    rt_kprintf("sector  size : %d byte\n", geo.bytes_per_sector);
    rt_kprintf("sector count : %d \n", geo.sector_count);
    rt_kprintf("block   size : %d byte\n", geo.block_size);
    /* 准备读写缓冲区空间,大小为一个块 */
    read_buff = rt_malloc(geo.block_size);
    if (read_buff == RT_NULL)
        rt_kprintf("no memory for read buffer!\n");
        return RT_ERROR;
    write_buff = rt_malloc(geo.block_size);
    if (write_buff == RT_NULL)
        rt_kprintf("no memory for write buffer!\n");
        rt_free(read_buff);
        return RT_ERROR;
    /* 填充写数据缓冲区,为写操作做准备 */
    fill_buffer(write_buff, geo.block_size);
    /* 把写数据缓冲的数据写入SD卡中,大小为一个块,size参数以块为单位 */
    block_num = rt_device_write(sd_device, 0, write_buff, 1);
    if (1 != block_num)
        rt_kprintf("write device %s failed!\n", sd_name);
    /* 从SD卡中读出数据,并保存在读数据缓冲区中 */
    block_num = rt_device_read(sd_device, 0, read_buff, 1);
    if (1 != block_num)
        rt_kprintf("read %s device failed!\n", sd_name);
    /* 比较写数据缓冲区和读数据缓冲区的内容是否完全一致 */
    if (rt_memcmp(write_buff, read_buff, geo.block_size) == 0)
        rt_kprintf("Block test OK!\n");
    else
        rt_kprintf("Block test Fail!\n");
    /* 释放缓冲区空间 */
    rt_free(read_buff);
    rt_free(write_buff);
    return RT_EOK;
/* 导出到 msh 命令列表中 */
MSH_CMD_EXPORT(sd_sample, sd device sample);
INIT_APP_EXPORT(sd_sample);
static int rt_hw_spi1_tfcard(void)
    __HAL_RCC_GPIOC_CLK_ENABLE();
    rt_hw_spi_device_attach("spi1", "spi10", GPIOA, GPIO_PIN_3);
    return msd_init("sd0", "spi10");
INIT_DEVICE_EXPORT(rt_hw_spi1_tfcard);
217
3 个回答
nongxiaoming
nongxiaoming 2020-07-13
卡死有什么信息吗?还有这个rt_hw_spi_device_attach("spi1", "spi10", GPIOA, GPIO_PIN_3);这句__HAL_RCC_GPIOC_CLK_ENABLE();起什么作用?
JQRR_7669
JQRR_7669 认证专家 2020-07-13
这句__HAL_RCC_GPIOC_CLK_ENABLE();应该改为__HAL_RCC_GPIOA_CLK_ENABLE();功能是使能gpio口A口时钟,时钟要和引脚所在口对应上。
大漠孤烟
大漠孤烟 2020-07-13
/* For simplicity reasons, this example is just waiting till the end of the
       transfer, but application may perform other tasks while transfer operation
       is ongoing. */
    while (HAL_SPI_GetState(spi_handle) != HAL_SPI_STATE_READY);
    在这个地方卡死
请登录后再发布答案,点击登录
