AT_URC
AT Client URC 数据处理问题?
发布于 2020-07-15 23:28:33 浏览:1401
系统版本 `RT-Thread 4.0.0` 文件 at组件 `(V1.2.0)` 问题是回调函数有时候不能正确执行,rt_sem_take也不超时 下面这种情况可以正确处理 ``` [D/AT] recvline: 0000-0020: 00 55 53 52 2D 47 4D 33 20 56 33 2E 32 2E 30 0D 0A .USR-GM3 V3.2.0.. [D/AT] recvline: 0000-0020: 69 70 3D 31 31 30 2E 31 31 2E 37 33 2E 33 32 3B 70 6F 72 74 3D 38 39 30 30 3B 66 72 65 71 3D 36 ip=110.11.73.32;port=8900;freq=6 [D/AT] recvline: 0020-0040: 30 30 30 0D 0A 000.. ``` **下面这种情况不能正确处理,回调函数有时候不能正确执行,rt_sem_take也不超时** ``` [D/AT] recvline: 0000-0020: 00 55 53 52 2D 47 4D 33 20 56 33 2E 32 2E 30 0D 69 70 3D 31 31 30 2E 31 31 2E 37 33 2E 33 32 3B .USR-GM3 V3.2.0.ip=114.11.73.32; [D/AT] recvline: 0020-0040: 70 6F 72 74 3D 38 39 30 30 3B 66 72 65 71 3D 36 30 30 30 0D 0A port=8900;freq=6000.. ``` 相关代码如下: ```c void send_my_messsage(uint8_t Msg) { uint8_t buf = Msg; rt_mq_send(&mq, &buf, sizeof(buf)); } static void func_recv_welcome(const char *data, rt_size_t size) { rt_kprintf("--->[Info] ---> AT data=%s size=%d\r\n", data, size); send_my_messsage(1); rt_sem_release(&welcome_sem); } static struct at_urc urc_table[] = { {"ip=", "\r\n", func_recv_welcome}, }; ALIGN(RT_ALIGN_SIZE) static rt_uint8_t test_stack[1024]; static struct rt_thread test_thread; static void test_thread_entry(void* parameter) { int ret; send_my_messsage(1); ret = gm3_gprs_para_config(current_para->para_server_ip, current_para->para_server_port, GPRS_AT_CMD_TIMEOUT); // 等待欢迎信息 ret = rt_sem_take(&welcome_sem, rt_tick_from_millisecond(5000)); if (ret != RT_EOK) { send_my_messsage(2); rt_kprintf("--->[Warn] ---> No welcome message received !\r\n"); } } int at_client_port_init(void) { rt_sem_init(&welcome_sem, "welcome_sem", 0, RT_IPC_FLAG_FIFO); at_client_init("uart3", MAX_AT_INFO_SIZE); at_set_urc_table(urc_table, sizeof(urc_table) / sizeof(urc_table[0])); ret = rt_thread_init(&test_thread, "test", test_thread_entry, RT_NULL, (rt_uint8_t*)&test_stack[0], sizeof(test_stack), priority, 5); if (ret == RT_EOK) { rt_thread_startup(&test_thread); } return RT_EOK; } ```
xiangxistu
2020-07-16
AT 组件对 URC 数据的判断,是基于完整的一行,比如以 0D 0A 结尾的,便是一行数据;得到一行数据的时候,便开始判断是不是 URC 数据。 ```c (prefix_len ? !rt_strncmp(buffer, urc->cmd_prefix, prefix_len) : 1) && (suffix_len ? rt_strncmp(buffer + bufsz - suffix_len, urc->cmd_suffix, suffix_len) : 1) ``` 上面是判断 URC 的逻辑,与 urc_table 的参数匹配,匹配一行的前几位,匹配一行的后几位; * 第一种情况可以识别原因是因为数据清晰,后一种情况的不能识别的原因是有 ```USR-GM3```这些脏数据的插入。 * 第一种情况的 ```USR-GM3```有明显的 0D 0A 结尾,AT 组件判断到完整的一行数据,判断不是 URC 数据后不做处理,剩下的 ```ip=....\r\n```则可以正确识别。 * 第二种情况的 ```USR-GM3```却只以 0D 结尾,AT 组件不能判断为完整的一行数据,只能与剩下的 ```ip=....\r\n```一起并做一行,但是由于上面的匹配策略,所以不能识别 URC 数据。 问题的解决方法设想: 1. ```USR-GM3``` 是否为开机自动上报的 URC 数据,可否等待数据稳定再获取```ip=....\r\n```信息,避免脏数据干扰。 2. 这一种麻烦一些,如果一条数据不能确定是以 0D 0A 或者 0D 作为结尾,可以修改 AT 组件的结尾标识符,选择以 0D 结尾判断。不过可能其他的内容也要相应修改。 3. 判断模块是否有压缩数据的策略,比如多条数据发送,使用 0D 数据间隔替代 0D 0A,是否可以选择不压缩。 解决的方法与目的就是去除 ```USR-GM3``` 脏数据的干扰,可以详细考虑下如何实现。
1.4k
piaoxueboy
rt-thread 2g/3g/4g通信模块的教程有吗?
基于AT指令,用esp8266如何连接mqtt?
AT组件使用问题
官方AT客户端应用笔记的几个小tip
RTT的SAL能够判断使用LWIP或者AT?
rt_therad AT组件移植不成功(结贴)
AT组件在哪个版本的?
AT组件 连接 Onenet 连接失败
esp8266 AT指令 MQTT连接问题
AT组件使用问题之模块主动上报【已解决】
