STMicroelectronics ST-LINK GDB server. Version 5.4.0
Copyright (c) 2019, STMicroelectronics. All rights reserved.
Starting server with the following options:
Persistent Mode : Disabled
LogFile Name : debug.log
Logging Level : 31
Listen Port Number : 61235
Status Refresh Delay : 15s
Verbose Mode : Disabled
SWD Debug : Enabled
Target connection mode: Default
Hardware watchpoint supported by the target
COM frequency = 4000 kHz
ST-LINK Firmware version : V2J34M25
Device ID: 0x414
PC: 0x800e0c8
ST-LINK device status: HALT_MODE
ST-LINK detects target voltage = 3.19 V
ST-LINK device initialization OK
Waiting for debugger connection...
Waiting for connection on port 61235...
Accepted connection on port 61235...
Debugger connected
------ Switching to STM32CubeProgrammer -----
STM32CubeProgrammer v2.3.0
Error: C:Users瀹嬮�婃枃AppDataLocalTempSTM32CubeProgrammer_a31404.log does not exist
ST-LINK SN : 0672FF575353667267191121
ST-LINK FW : V2J34M25
Voltage : 3.19V
SWD freq : 4000 KHz
Connect mode: Under Reset
Reset mode : Hardware reset
Device ID : 0x414
Device name : STM32F101/F103 High-density
Flash size : 512 KBytes
Device type : MCU
Device CPU : Cortex-M3
Memory Programming ...
Opening and parsing file: ST-LINK_GDB_server_a31404.srec
File : ST-LINK_GDB_server_a31404.srec
Address : 0x08000000
Erasing memory corresponding to segment 0:
Erasing internal memory sectors [0 45]
Download in Progress:
File download complete
Time elapsed during download operation: 00:00:04.812
Encountered Error when opening D:/RT-ThreadStudio/repo/Extract/Debugger_Support_Packages/STMicroelectronics/ST-LINK_Debugger/1.2.0/tools/binSTM32_Programmer_CLI.exe
------ Switching context -----
Error in STM32CubeProgrammer
Debugger connection lost.
Shutting down...
谢谢,换网上买的那种JLINK OB mini下载器可以支持吗?
@songxunwen 就买普通的jlink吧
