CANopen_canfestival
bootloader 里面不能运行 canfestiavl
发布于 2020-07-29 11:30:15 浏览:1322
最近想做一个带bootloader的项目。之前原来的项目里带了can的通讯也是用RTT里面的canfestival做的,可以正常运行和使用,但是为了IAP的升级把 flash的起始地址偏移了一下从LR_IROM1 0x08000000 改为 LR_IROM1 0x08020000,can的运行就存在问题,但是如果屏蔽can功能在IAP下其他程序都可以正常运行。以下是具体问题描述。 1,首先修改link.sct为 ``` LR_IROM1 0x08020000 0x000e0000 { ; load region size_region ER_IROM1 0x08020000 0x000e0000 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) } RW_IRAM1 0x20020000 0x00060000 { ; RW data .ANY (+RW +ZI) } } ``` 2,在main.c里加入了 ``` static int ota_app_vtor_reconfig(void) { #define NVIC_VTOR_MASK 0x3FFFFF80 /* Set the Vector Table base location by user application firmware definition */ SCB->VTOR = 0x08020000 & NVIC_VTOR_MASK; return 0; } INIT_BOARD_EXPORT(ota_app_vtor_reconfig); ``` 3运行了一段时间后在drv_can.c里面会把hcan->State = HAL_CAN_STATE_ERROR;赋值 具体原因是0号发送邮箱再新发送要求来的时候没有准备好,我不清楚为什么会这样? ``` static int _can_sendmsg(struct rt_can_device *can, const void *buf, rt_uint32_t box_num) { CAN_HandleTypeDef *hcan; hcan = &((struct stm32_can *) can->parent.user_data)->CanHandle; struct rt_can_msg *pmsg = (struct rt_can_msg *) buf; CAN_TxHeaderTypeDef txheader = {0}; HAL_CAN_StateTypeDef state = hcan->State; /* Check the parameters */ RT_ASSERT(IS_CAN_DLC(pmsg->len)); if ((state == HAL_CAN_STATE_READY) || (state == HAL_CAN_STATE_LISTENING)) { /*check select mailbox is empty */ switch (1 << box_num) { case CAN_TX_MAILBOX0: if (HAL_IS_BIT_SET(hcan->Instance->TSR, CAN_TSR_TME0) != SET) { /* Change CAN state */ ** hcan->State = HAL_CAN_STATE_ERROR;** /* Return function status */ return -RT_ERROR; } break; ``` 4,所以程序一直在can.c里的_can_int_tx进行死循环 ``` rt_inline int _can_int_tx(struct rt_can_device *can, const struct rt_can_msg *data, int msgs) { int size; struct rt_can_tx_fifo *tx_fifo; RT_ASSERT(can != RT_NULL); size = msgs; tx_fifo = (struct rt_can_tx_fifo *) can->can_tx; RT_ASSERT(tx_fifo != RT_NULL); while (msgs) { rt_base_t level; rt_uint32_t no; rt_uint32_t result; struct rt_can_sndbxinx_list *tx_tosnd = RT_NULL; rt_sem_take(&(tx_fifo->sem), RT_WAITING_FOREVER); level = rt_hw_interrupt_disable(); tx_tosnd = rt_list_entry(tx_fifo->freelist.next, struct rt_can_sndbxinx_list, list); RT_ASSERT(tx_tosnd != RT_NULL); rt_list_remove(&tx_tosnd->list); rt_hw_interrupt_enable(level); no = ((rt_uint32_t)tx_tosnd - (rt_uint32_t)tx_fifo->buffer) / sizeof(struct rt_can_sndbxinx_list); tx_tosnd->result = RT_CAN_SND_RESULT_WAIT; if (can->ops->sendmsg(can, data, no) != RT_EOK) { /* send failed. */ level = rt_hw_interrupt_disable(); rt_list_insert_after(&tx_fifo->freelist, &tx_tosnd->list); rt_hw_interrupt_enable(level); rt_sem_release(&(tx_fifo->sem)); ** continue;**在这里会死循环 } ``` 问题:为什么原来的程序没有出现这样的情况,而改了FLASH的启动偏移反而出现了这样的情况???请大神们来给点思路。这个问题找了很久了。
红枫
2020-07-29
看看CAN的初始化是不是在ota_app_vtor_reconfig之前了,如果是将CAN初始化延后就行了。RW_IRAM1 没必要也偏移0x20000
1.3k
dingzijie
进入bootloader的方式探讨
求助:IAP里的APP使用的RTT,跳转后出错。[已解决]
想做网口的IAP远程升级,不知可不可行
IAP问题
