STM32F411
STM32F411CE 编译成功,烧制不到板子里
发布于 2020-08-01 21:36:01 浏览:2205
报如下错误: 开始下载程序:2020-08-01 21:33:23 C:\RT-ThreadStudio>"C:/RT-ThreadStudio/repo/Extract/Debugger_Support_Packages/SEGGER/J-Link/6.80d/JLink.exe" -device STM32F411CE -ExitOnError -CommanderScript C:\RT-ThreadStudio\workspace/.metadata/Temp/rtthread_download_init.jlink SEGGER J-Link Commander V6.80d (Compiled Jun 26 2020 17:17:12) DLL version V6.80d, compiled Jun 26 2020 17:16:09 J-Link Commander will now exit on Error J-Link Command File read successfully. Processing script file... J-Link connection not established yet but required for command. Connecting to J-Link via USB...O.K. Firmware: J-Link OB-STM32F072-CortexM compiled Jan 7 2019 14:09:37 Hardware version: V1.00 S/N: -1 License(s): GDB, RDI, FlashBP, FlashDL, JFlash, RDDI VTref=3.300V Selecting SWD as current target interface. Device "STM32F411CE" selected. Selecting 1000 kHz as target interface speed Target connection not established yet but required for command. Device "STM32F411CE" selected. Connecting to target via SWD Found SW-DP with ID 0x2BA01477 Found SW-DP with ID 0x2BA01477 Unknown DP version. Assuming DPv0 Scanning AP map to find all available APs AP[1]: Stopped AP scan as end of AP map has been reached AP[0]: AHB-AP (IDR: 0x24770011) Iterating through AP map to find AHB-AP to use AP[0]: Core found AP[0]: AHB-AP ROM base: 0xE00FF000 CPUID register: 0x410FC241. Implementer code: 0x41 (ARM) Found Cortex-M4 r0p1, Little endian. FPUnit: 6 code (BP) slots and 2 literal slots CoreSight components: ROMTbl[0] @ E00FF000 ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7 ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM Cortex-M4 identified. Reset delay: 0 ms Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit. Reset: Halt core after reset via DEMCR.VC_CORERESET. Reset: Reset device via AIRCR.SYSRESETREQ. PC = 08008874, CycleCnt = 00000000 R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000 R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000 R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000 R12= 00000000 SP(R13)= 20000998, MSP= 20000998, PSP= 00000000, R14(LR) = FFFFFFFF XPSR = 01000000: APSR = nzcvq, EPSR = 01000000, IPSR = 000 (NoException) CFBP = 00000000, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 00 FPS0 = 00000000, FPS1 = 00000000, FPS2 = 00000000, FPS3 = 00000000 FPS4 = 00000000, FPS5 = 00000000, FPS6 = 00000000, FPS7 = 00000000 FPS8 = 00000000, FPS9 = 00000000, FPS10= 00000000, FPS11= 00000000 FPS12= 00000000, FPS13= 00000000, FPS14= 00000000, FPS15= 00000000 FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000 FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000 FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000 FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= 00000000 FPSCR= 00000000 Downloading file [C:\RT-ThreadStudio\workspace\STM32_F4\Debug\rtthread.bin]... J-Link: Flash download: Bank 0 @ 0x08000000: Skipped. Contents already match O.K. Reset delay: 0 ms Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit. Reset: Halt core after reset via DEMCR.VC_CORERESET. Reset: Reset device via AIRCR.SYSRESETREQ. Script processing completed. 执行完毕, 耗时:1597ms.
rcp
2020-08-04
看日志没有报错呢
qiaowei361
2020-08-07
学习中...
我使用j-flash擦一下就可以了,下载程序到板子里了。不知道为什么。 J-flash 可以到CSDN下载 ![image.png](/uploads/20200807/08f4d400779b27c9da5e49538afbfd8a.png) RTT控制台代码和上面的代码差不多,不知道什么原因,只能认为之前下载板子的flash卡死了,需要借助j-flash来擦除再使用RTT下载。 Download Start Address: 0x08000000 开始下载程序:2020-08-07 22:07:48 C:\RT-ThreadStudio>"C:/RT-ThreadStudio/repo/Extract/Debugger_Support_Packages/SEGGER/J-Link/6.80d/JLink.exe" -device STM32F411CE -ExitOnError -CommanderScript C:\RT-ThreadStudio\workspace/.metadata/Temp/rtthread_download_init.jlink SEGGER J-Link Commander V6.80d (Compiled Jun 26 2020 17:17:12) DLL version V6.80d, compiled Jun 26 2020 17:16:09 J-Link Commander will now exit on Error J-Link Command File read successfully. Processing script file... J-Link connection not established yet but required for command. Connecting to J-Link via USB...O.K. Firmware: J-Link OB-STM32F072-CortexM compiled Jan 7 2019 14:09:37 Hardware version: V1.00 S/N: -1 License(s): GDB, RDI, FlashBP, FlashDL, JFlash, RDDI VTref=3.300V Selecting SWD as current target interface. Device "STM32F411CE" selected. Selecting 1000 kHz as target interface speed Target connection not established yet but required for command. Device "STM32F411CE" selected. Connecting to target via SWD Found SW-DP with ID 0x2BA01477 Found SW-DP with ID 0x2BA01477 Unknown DP version. Assuming DPv0 Scanning AP map to find all available APs AP[1]: Stopped AP scan as end of AP map has been reached AP[0]: AHB-AP (IDR: 0x24770011) Iterating through AP map to find AHB-AP to use AP[0]: Core found AP[0]: AHB-AP ROM base: 0xE00FF000 CPUID register: 0x410FC241. Implementer code: 0x41 (ARM) Found Cortex-M4 r0p1, Little endian. FPUnit: 6 code (BP) slots and 2 literal slots CoreSight components: ROMTbl[0] @ E00FF000 ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7 ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM Cortex-M4 identified. Reset delay: 0 ms Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit. Reset: Halt core after reset via DEMCR.VC_CORERESET. Reset: Reset device via AIRCR.SYSRESETREQ. PC = 08008874, CycleCnt = 00000000 R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000 R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000 R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000 R12= 00000000 SP(R13)= 20000998, MSP= 20000998, PSP= 00000000, R14(LR) = FFFFFFFF XPSR = 01000000: APSR = nzcvq, EPSR = 01000000, IPSR = 000 (NoException) CFBP = 00000000, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 00 FPS0 = 00000000, FPS1 = 00000000, FPS2 = 00000000, FPS3 = 00000000 FPS4 = 00000000, FPS5 = 00000000, FPS6 = 00000000, FPS7 = 00000000 FPS8 = 00000000, FPS9 = 00000000, FPS10= 00000000, FPS11= 00000000 FPS12= 00000000, FPS13= 00000000, FPS14= 00000000, FPS15= 00000000 FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000 FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000 FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000 FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= 00000000 FPSCR= 00000000 Downloading file [F:\STM32\STM32_F4\Debug\rtthread.bin]... J-Link: Flash download: Bank 0 @ 0x08000000: 1 range affected (16384 bytes) J-Link: Flash download: Total: 1.118s (Prepare: 0.287s, Compare: 0.139s, Erase: 0.341s, Program & Verify: 0.335s, Restore: 0.015s) J-Link: Flash download: Program & Verify speed: 47 KB/s O.K. Reset delay: 0 ms Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit. Reset: Halt core after reset via DEMCR.VC_CORERESET. Reset: Reset device via AIRCR.SYSRESETREQ. Script processing completed. 执行完毕, 耗时:2012ms.
2.2k
qiaowei361
学习中...
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
