20 STM32 RTC 闹钟
发布于 2020-08-02 20:02:15
请问有那位大侠 完善了 rtthread 在 stm32 平台上的RTC 硬件闹钟啊? 能否分享一下Drv_rtc.c
394
2 个回答
李子成
李子成 2020-08-03
我没用rtt相关的rtc 直接拿我以前裸机的rtc用的。
mii
mii 2020-08-05
兄弟,还是我来拯救你吧!原本想做一下伸手党,发现大家都不太积极,只能靠自己了。新鲜出炉,今天刚刚捣鼓完代码。论坛的添加文件服务有问题。我直接粘代码,你复制替换。`/*
  • Copyright (c) 2006-2018, RT-Thread Development Team
  • SPDX-License-Identifier: Apache-2.0
  • Change Logs:
  • Date Author Notes
  • 2018-12-04 balanceTWK first version
include "board.h"
include<rtthread.h>
include<rtdevice.h>
include "drv_common.h"
ifdef BSP_USING_ONCHIP_RTC
ifndef RTC_BKP_DR1
define RTC_BKP_DR1 RT_NULL
endif
//#define DRV_DEBUG
define LOG_TAG "drv.rtc"
include <drv_log.h>
define BKUP_REG_DATA 0xA5A5
static struct rt_device rtc;
static RTC_HandleTypeDef RTC_Handler;
RT_WEAK uint32_t HAL_RTCEx_BKUPRead(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister)
return (~BKUP_REG_DATA);
RT_WEAK void HAL_RTCEx_BKUPWrite(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister, uint32_t Data)
return;
static time_t get_rtc_timestamp(void)
RTC_TimeTypeDef RTC_TimeStruct = {0};
RTC_DateTypeDef RTC_DateStruct = {0};
struct tm tm_new = {0};
HAL_RTC_GetTime(&RTC_Handler, &RTC_TimeStruct, RTC_FORMAT_BIN);
HAL_RTC_GetDate(&RTC_Handler, &RTC_DateStruct, RTC_FORMAT_BIN);
tm_new.tm_sec  = RTC_TimeStruct.Seconds;
tm_new.tm_min  = RTC_TimeStruct.Minutes;
tm_new.tm_hour = RTC_TimeStruct.Hours;
tm_new.tm_mday = RTC_DateStruct.Date;
tm_new.tm_mon  = RTC_DateStruct.Month - 1;
tm_new.tm_year = RTC_DateStruct.Year + 100;
LOG_D("get rtc time.");
return mktime(&tm_new);
static rt_err_t set_rtc_time_stamp(time_t time_stamp)
struct tm *p_tm;
p_tm = localtime(&time_stamp);
if (p_tm->tm_year < 100)
    return -RT_ERROR;
RTC_TimeStruct.Seconds = p_tm->tm_sec ;
RTC_TimeStruct.Minutes = p_tm->tm_min ;
RTC_TimeStruct.Hours   = p_tm->tm_hour;
RTC_DateStruct.Date    = p_tm->tm_mday;
RTC_DateStruct.Month   = p_tm->tm_mon + 1 ;
RTC_DateStruct.Year    = p_tm->tm_year - 100;
RTC_DateStruct.WeekDay = p_tm->tm_wday + 1;
if (HAL_RTC_SetTime(&RTC_Handler, &RTC_TimeStruct, RTC_FORMAT_BIN) != HAL_OK)
    return -RT_ERROR;
if (HAL_RTC_SetDate(&RTC_Handler, &RTC_DateStruct, RTC_FORMAT_BIN) != HAL_OK)
    return -RT_ERROR;
LOG_D("set rtc time.");
HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR1, BKUP_REG_DATA);
ifdef SOC_SERIES_STM32F1
/* F1 series does't save year/month/date datas. so keep those datas to bkp reg */
HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR2, RTC_DateStruct.Year);
HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR3, RTC_DateStruct.Month);
HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR4, RTC_DateStruct.Date);
HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR5, RTC_DateStruct.WeekDay);
endif
return RT_EOK;
static rt_err_t set_rtc_alarm_stamp(struct rt_rtc_wkalarm wkalarm)
RTC_AlarmTypeDef sAlarm = {0};
//struct tm *p_tm;
//p_tm = localtime(&time_stamp);
if(wkalarm.enable == RT_FALSE)
    if (HAL_RTC_DeactivateAlarm(&RTC_Handler,RTC_ALARM_A) != HAL_OK)
           return -RT_ERROR;
       LOG_D("stop rtc alarm.");
}else {
    /** Enable the Alarm A
    sAlarm.AlarmTime.Hours = wkalarm.tm_hour;
    sAlarm.AlarmTime.Minutes = wkalarm.tm_min;
    sAlarm.AlarmTime.Seconds = wkalarm.tm_sec;
    sAlarm.AlarmTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
    sAlarm.AlarmTime.StoreOperation = RTC_STOREOPERATION_RESET;
    sAlarm.AlarmMask = RTC_ALARMMASK_DATEWEEKDAY;
    sAlarm.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_DATE;
    sAlarm.AlarmDateWeekDay = 1;
    sAlarm.Alarm = RTC_ALARM_A;
    if (HAL_RTC_SetAlarm_IT(&RTC_Handler, &sAlarm, RTC_FORMAT_BIN) != HAL_OK)
        return -RT_ERROR;
    LOG_D("set rtc alarm.");
return RT_EOK;
  • @brief This function handles RTC alarms A and B interrupt through EXTI line 17.
void RTC_Alarm_IRQHandler(void)
/ USER CODE BEGIN RTC_Alarm_IRQn 0 /
/ USER CODE END RTC_Alarm_IRQn 0 /
HAL_RTC_AlarmIRQHandler(&RTC_Handler);
/ USER CODE BEGIN RTC_Alarm_IRQn 1 /
/ USER CODE END RTC_Alarm_IRQn 1 /
void HAL_RTC_AlarmAEventCallback(RTC_HandleTypeDef *hrtc)
rt_alarm_update(0,0);
struct rt_rtc_wkalarm get_rtc_alarm_stamp(void)
//struct tm tm_new = {0};
struct rt_rtc_wkalarm wkalarm;
if (HAL_RTC_GetAlarm(&RTC_Handler, &sAlarm,RTC_ALARM_A, RTC_FORMAT_BIN) != HAL_OK)
    LOG_D("get rtc alarm fail!.");
wkalarm.tm_sec  = sAlarm.AlarmTime.Seconds;
wkalarm.tm_min = sAlarm.AlarmTime.Minutes;
wkalarm.tm_hour = sAlarm.AlarmTime.Hours;
LOG_D("get rtc alarm.");
// return mktime(&tm_new);
return wkalarm;
static void rt_rtc_init(void)
ifndef SOC_SERIES_STM32H7
__HAL_RCC_PWR_CLK_ENABLE();
endif
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
ifdef BSP_RTC_USING_LSI
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
RCC_OscInitStruct.LSEState = RCC_LSE_OFF;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
else
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSE;
RCC_OscInitStruct.LSEState = RCC_LSE_ON;
RCC_OscInitStruct.LSIState = RCC_LSI_OFF;
endif
HAL_RCC_OscConfig(&RCC_OscInitStruct);
/ update RTC_BKP_DRx/
static void rt_rtc_f1_bkp_update(void)
HAL_PWR_EnableBkUpAccess();
__HAL_RCC_BKP_CLK_ENABLE();
RTC_DateStruct.Year    = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR2);
RTC_DateStruct.Month   = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR3);
RTC_DateStruct.Date    = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR4);
RTC_DateStruct.WeekDay = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR5);
    Error_Handler();
if (HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR4) != RTC_DateStruct.Date)
endif
static rt_err_t rt_rtc_config(struct rt_device *dev)
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RTC;
PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
else
PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
endif
HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
/* Enable RTC Clock */
__HAL_RCC_RTC_ENABLE();
/* RTC interrupt DeInit */
HAL_NVIC_SetPriority(RTC_Alarm_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(RTC_Alarm_IRQn);
RTC_Handler.Instance = RTC;
if (HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR1) != BKUP_REG_DATA)
    LOG_I("RTC hasn't been configured, please use <date> command to config.");
if defined(SOC_SERIES_STM32F1)
    RTC_Handler.Init.OutPut = RTC_OUTPUTSOURCE_NONE;
    RTC_Handler.Init.AsynchPrediv = RTC_AUTO_1_SECOND;
elif defined(SOC_SERIES_STM32F0)
    /* set the frequency division */
    RTC_Handler.Init.AsynchPrediv = 0XA0;
    RTC_Handler.Init.SynchPrediv = 0xFA;
else
    RTC_Handler.Init.AsynchPrediv = 0X7F;
    RTC_Handler.Init.SynchPrediv = 0x0130;
endif / BSP_RTC_USING_LSI /
    RTC_Handler.Init.HourFormat = RTC_HOURFORMAT_24;
    RTC_Handler.Init.OutPut = RTC_OUTPUT_DISABLE;
    RTC_Handler.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
    RTC_Handler.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
elif defined(SOC_SERIES_STM32F2) || defined(SOC_SERIES_STM32F4) || defined(SOC_SERIES_STM32F7) || defined(SOC_SERIES_STM32L4) || defined(SOC_SERIES_STM32H7)
    RTC_Handler.Init.AsynchPrediv = 0X7D;
else
    RTC_Handler.Init.SynchPrediv = 0XFF;
endif
    if (HAL_RTC_Init(&RTC_Handler) != HAL_OK)
        return -RT_ERROR;
else
    /* F1 series need update by bkp reg datas */
    rt_rtc_f1_bkp_update();
endif
return RT_EOK;
static rt_err_t rt_rtc_control(rt_device_t dev, int cmd, void *args)
rt_err_t result = RT_EOK;
RT_ASSERT(dev != RT_NULL);
switch (cmd)
case RT_DEVICE_CTRL_RTC_GET_TIME:
    *(rt_uint32_t *)args = get_rtc_timestamp();
    LOG_D("RTC: get rtc_time %x\n", *(rt_uint32_t *)args);
    break;
case RT_DEVICE_CTRL_RTC_SET_TIME:
    if (set_rtc_time_stamp(*(rt_uint32_t *)args))
        result = -RT_ERROR;
    LOG_D("RTC: set rtc_time %x\n", *(rt_uint32_t *)args);
    break;
case RT_DEVICE_CTRL_RTC_SET_ALARM:
    if (set_rtc_alarm_stamp(*(struct rt_rtc_wkalarm *)args))
       result = -RT_ERROR;
   LOG_D("RTC: set rtc_alarm tme : hour: %d , min: %d , sec:  %d \n", *(struct rt_rtc_wkalarm *)args->tm_hour,*(struct rt_rtc_wkalarm *)args->tm_min,*(struct rt_rtc_wkalarm *)args->tm_sec);
    break;
case RT_DEVICE_CTRL_RTC_GET_ALARM:
    *(struct rt_rtc_wkalarm *)args = get_rtc_alarm_stamp();
    LOG_D("RTC: get rtc_alarm time : hour: %d , min: %d , sec:  %d \n", *(struct rt_rtc_wkalarm *)args->tm_hour,*(struct rt_rtc_wkalarm *)args->tm_min,*(struct rt_rtc_wkalarm *)args->tm_sec);
     break;
return result;
ifdef RT_USING_DEVICE_OPS
const static struct rt_device_ops rtc_ops =
RT_NULL,
RT_NULL,
RT_NULL,
RT_NULL,
RT_NULL,
rt_rtc_control
endif
static rt_err_t rt_hw_rtc_register(rt_device_t device, const char *name, rt_uint32_t flag)
RT_ASSERT(device != RT_NULL);
rt_rtc_init();
if (rt_rtc_config(device) != RT_EOK)
    return -RT_ERROR;
device->ops         = &rtc_ops;
else
device->init        = RT_NULL;
device->open        = RT_NULL;
device->close       = RT_NULL;
device->read        = RT_NULL;
device->write       = RT_NULL;
device->control     = rt_rtc_control;
endif
device->type        = RT_Device_Class_RTC;
device->rx_indicate = RT_NULL;
device->tx_complete = RT_NULL;
device->user_data   = RT_NULL;
/* register a character device */
return rt_device_register(device, name, flag);
int rt_hw_rtc_init(void)
rt_err_t result;
result = rt_hw_rtc_register(&rtc, "rtc", RT_DEVICE_FLAG_RDWR);
if (result != RT_EOK)
    LOG_E("rtc register err code: %d", result);
    return result;
LOG_D("rtc init success");
return RT_EOK;
INIT_DEVICE_EXPORT(rt_hw_rtc_init);
endif / BSP_USING_ONCHIP_RTC /
请登录后再发布答案,点击登录
