想把GPS的经纬度上传给onenet,平台上可以看到位置信息的数据点显示
但并没有显示百度地图
相关代码
改装了两个函数
rt_err_t onenet_mqtt_get_string_gpsDIY( char* lat,char* lon,char **out_buff, size_t *length)
rt_err_t result = RT_EOK;
cJSON *root = RT_NULL;
cJSON *pvalue = RT_NULL;
char *msg_str = RT_NULL;
/* RT_ASSERT(ds_name);
RT_ASSERT(str);*/
RT_ASSERT(out_buff);
RT_ASSERT(length);
root = cJSON_CreateObject();
pvalue = cJSON_CreateObject();
if (!root)
LOG_E("MQTT publish string data failed! cJSON create object error return NULL!");
return -RT_ENOMEM;
cJSON_AddStringToObject(pvalue, "lat", lat);
cJSON_AddStringToObject(pvalue, "lon", lon);
cJSON_AddItemToObject(root,"loc",pvalue);
/* render a cJSON structure to buffer */
msg_str = cJSON_PrintUnformatted(root);
if (!msg_str)
LOG_E("MQTT publish string data failed! cJSON print unformatted error return NULL!");
result = -RT_ENOMEM;
goto __exit;
*out_buff = ONENET_MALLOC(strlen(msg_str) + 3);
if (!(*out_buff))
LOG_E("ONENET mqtt upload string data failed! No memory for send buffer!");
return -RT_ENOMEM;
strncpy(&(*out_buff)[3], msg_str, strlen(msg_str));
*length = strlen(&(*out_buff)[3]);
/* mqtt head and json length */
(*out_buff)[0] = 0x03;
(*out_buff)[1] = (*length & 0xff00) >> 8;
(*out_buff)[2] = *length & 0xff;
*length += 3;
__exit:
if (root)
cJSON_Delete(root);
if (msg_str)
cJSON_free(msg_str);
return result;
* upload string data to OneNET cloud.
* @param ds_name datastream name
* @param str string data
* @return 0 : upload digit data success
* -5 : no memory
rt_err_t onenet_mqtt_upload_GPSDIY(char* lat,char* lon)
char *send_buffer = RT_NULL;
size_t length = 0;
result = onenet_mqtt_get_string_gpsDIY(lat,lon,&send_buffer, &length);
if (result < 0)
goto __exit;
result = onenet_mqtt_publish(ONENET_TOPIC_DP, (uint8_t *) send_buffer, length);
if (result < 0)
LOG_E("onenet publish failed (%d)!", result);
goto __exit;
__exit: if (send_buffer)
ONENET_FREE(send_buffer);
return result;
然后在发送线程里调用
onenet_mqtt_upload_GPSDIY(info->coord.location.longitude.string,info->coord.location.latitude.string)
OK
这不是经纬度准不准的问题,我用OneNet-Mqtt模拟-v1.0.7上传{"loc":{"lat":23.170923,"lon":113.455275}}是可以被onenet解析为地图坐标的。但我程序上传的会被认为是纯文本,估计是onenet软件包没有提供嵌套的json函数导致
