有哪位老铁使用了imx.rt1052的spi驱动?自己测了一下,最终spi时序有错。
测试如下:
1、使用MCUXpresso 配置了spi4的相关引脚:
2、配置使能
3、挂载spi设备
#define ADS1220_SPI_DEVICE_NAME "spi40"
#define ADS1220_SPI_BUS_NAME "spi4"
static struct rt_spi_device* spi_dev_ads1220; /* SPI设备ads1220对象 */
static int ads1220_spi_init(void)
rt_err_t ret;
struct rt_spi_configuration cfg;
ret = rt_hw_spi_device_attach(ADS1220_SPI_BUS_NAME,ADS1220_SPI_DEVICE_NAME,GET_PIN(2,20));
if(ret != RT_EOK)
LOG_E("ads1220 spi attach spi4 failed!");
return -RT_ERROR;
cfg.data_width = 8;
cfg.mode = RT_SPI_MASTER|RT_SPI_MODE_1|RT_SPI_MSB ;
cfg.max_hz = 500*1000;
spi_dev_ads1220 = (struct rt_spi_device*) rt_device_find(ADS1220_SPI_DEVICE_NAME);
ret = rt_spi_configure(spi_dev_ads1220,&cfg);
if(ret != RT_EOK)
LOG_E("ads1220 spi configure failed!");
return -RT_ERROR;
return RT_EOK;
/* 导出到自动初始化 */
INIT_COMPONENT_EXPORT(ads1220_spi_init);
查看设备,注册成功。
4、测试发一个数据
static void spi_ads1220_sample(void)
uint8_t reg_data = 0;
rt_err_t ret = RT_EOK;
rt_size_t size;
rt_uint8_t cmd = 0x20;
spi_dev_ads1220 =(struct rt_spi_device*)
if(!spi_dev_ads1220)
rt_kprintf("can't find %s device!\n",
else
while(1)
size = rt_spi_send(spi_dev_ads1220,&cmd,1);
if(size != 0)
LOG_D("ads1220发送信息成功!");
else
LOG_E("ads1220发送信息失败!");
rt_thread_mdelay(500);
最终逻辑分析仪抓取波形,cs电平有问题。
使用dma的话要配置成spi为4线模式,cs直接受spi控制
