USB虚拟成CDC设备问题
发布于 2020-08-27 22:19:10
目前我是用的USB控制器是DWC,然后把usb2.0虚拟成cdc,当usb接到电脑上的时候,可以在设备管理其上看到com口。但是当我使用串口调试助手去链接这个com口的时候,发现无法打开。一时找不到答案,我的usb如下配置:
define RT_USING_USB_DEVICE
define RT_USBD_THREAD_STACK_SZ 4096
define USB_VENDOR_ID 0x0FFE
define USB_PRODUCT_ID 0x0001
define RT_USB_DEVICE_COMPOSITE
define RT_USB_DEVICE_CDC
define RT_USB_DEVICE_NONE
define RT_VCOM_TASK_STK_SIZE 512
define RT_CDC_RX_BUFSIZE 128
define RT_VCOM_SERNO "32021919830108"
define RT_VCOM_SER_LEN 14
define RT_VCOM_TX_TIMEOUT 1000
static struct ep_id __ep_pool[] =
{0x00, USB_EP_ATTR_CONTROL,     USB_DIR_INOUT,  64, ID_ASSIGNED},
if DWC_FORCE_SPEED_FULL
{0x01, USB_EP_ATTR_INT,         USB_DIR_IN,     64, ID_UNASSIGNED},
{0x02, USB_EP_ATTR_BULK,        USB_DIR_OUT,    64, ID_UNASSIGNED},
{0x02, USB_EP_ATTR_BULK,        USB_DIR_IN,     64, ID_UNASSIGNED},
{0x04, USB_EP_ATTR_BULK,        USB_DIR_OUT,    64, ID_UNASSIGNED},
{0x04, USB_EP_ATTR_BULK,        USB_DIR_IN,     64, ID_UNASSIGNED},
else
{0x01, USB_EP_ATTR_INT,         USB_DIR_IN,    512, ID_UNASSIGNED},
{0x01, USB_EP_ATTR_INT,         USB_DIR_OUT,   512, ID_UNASSIGNED},
{0x02, USB_EP_ATTR_BULK,        USB_DIR_OUT,   512, ID_UNASSIGNED},
{0x02, USB_EP_ATTR_BULK,        USB_DIR_IN,    512, ID_UNASSIGNED},
{0x04, USB_EP_ATTR_BULK,        USB_DIR_OUT,   512, ID_UNASSIGNED},
{0x04, USB_EP_ATTR_BULK,        USB_DIR_IN,    512, ID_UNASSIGNED},
{0x06, USB_EP_ATTR_BULK,        USB_DIR_OUT,   512, ID_UNASSIGNED},
{0x06, USB_EP_ATTR_BULK,        USB_DIR_IN,    512, ID_UNASSIGNED},
endif
{0xFF, USB_EP_ATTR_TYPE_MASK,   USB_DIR_MASK,   0,  ID_ASSIGNED}
197
2 个回答
whj467467222 2020-08-28
尝试打开你串口助手的 RTS 与 DTR
nicholas
nicholas 2020-09-09
我也遇到这问题,有时能打开,有时打不开。PC发送数据是没有问题的,不过有时候接收不了数据。若楼主解决了 这问题,望告知!!
请登录后再发布答案,点击登录
