求助用scons生成不了mdk工程 mdk版本是5.15
发布于 2015-09-12 18:37:38 浏览:6731
mdk版本:5.15 使用scons生成mdk工程时出现 F: tos\RT-Thread\source t-thread-1.2.2\bsp\stm32f10x>scons --target = mdk4 -s scons: warning: host, target = ('amd64', 'amd64') not supported for MSVC version 6.0 File "F: tos\RT-Thread\source t-thread-1.2.2\bsp\stm32f10x\SConstruct", line 2 7, in
usage: scons [OPTION] [TARGET] ... SCons Error: --target option requires an argument F: tos\RT-Thread\source t-thread-1.2.2\bsp\stm32f10x> 使用scons在编译过程中也出现了警告 scons: warning: host, target = ('amd64', 'amd64') not supported for MSVC version 6.0 File "F: tos\RT-Thread\source t-thread-1.2.2\bsp\stm32f10x\SConstruct", line 2 7, in
scons: done reading SConscript files. scons: Building targets ... scons: building associated VariantDir targets: build CC build\applications\application.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\applications\startup.o Warning: C3912W: Option 'device' is deprecated. "applications\startup.c", line 60: Warning: #223-D: function "rt_hw_board_init" declared implicitly rt_hw_board_init(); ^ applications\startup.c: 1 warning, 0 errors Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\components\drivers\serial\serial.o Warning: C3912W: Option 'device' is deprecated. CC build\components\drivers\src\completion.o Warning: C3912W: Option 'device' is deprecated. CC build\components\drivers\src\dataqueue.o Warning: C3912W: Option 'device' is deprecated. CC build\components\drivers\src\pipe.o Warning: C3912W: Option 'device' is deprecated. CC build\components\drivers\src\portal.o Warning: C3912W: Option 'device' is deprecated. CC build\components\drivers\src ingbuffer.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\cmd.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\finsh_compiler.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\finsh_error.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\finsh_heap.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\finsh_init.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\finsh_node.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\finsh_ops.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\finsh_parser.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\finsh_token.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\finsh_var.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\finsh_vm.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\shell.o Warning: C3912W: Option 'device' is deprecated. CC build\components\finsh\symbol.o Warning: C3912W: Option 'device' is deprecated. CC build\components\init\components.o Warning: C3912W: Option 'device' is deprecated. CC build\drivers\board.o Warning: C3912W: Option 'device' is deprecated. "drivers\board.c", line 187: Warning: #223-D: function "rt_hw_usart_init" decla red implicitly rt_hw_usart_init(); ^ drivers\board.c: 1 warning, 0 errors Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\drivers\led.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\drivers\stm32f10x_it.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\drivers\usart.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\libcpu\arm\common\backtrace.o Warning: C3912W: Option 'device' is deprecated. CC build\libcpu\arm\common\div0.o Warning: C3912W: Option 'device' is deprecated. CC build\libcpu\arm\common\showmem.o Warning: C3912W: Option 'device' is deprecated. AS build\libcpu\arm\cortex-m3\context_rvds.o Warning: A3912W: Option 'device' is deprecated. "F: tos\RT-Thread\source t-thread-1.2.2\libcpu\arm\cortex-m3\context_rvds.S", line 206: Warning: A1581W: Added 2 bytes of padding at address 0xd6 206 000000d8 END 0 Errors, 2 Warnings CC build\libcpu\arm\cortex-m3\cpuport.o Warning: C3912W: Option 'device' is deprecated. AS build\Libraries\CMSIS\CM3\DeviceSupport\ST\STM32F10x\startup\arm\startup_stm3 2f10x_hd.o Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning CC build\Libraries\CMSIS\CM3\DeviceSupport\ST\STM32F10x\system_stm32f10x.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\misc.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_adc.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_bkp.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_can.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_cec.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_crc.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_dac.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_dbgmcu.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_dma.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_exti.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_flash.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_fsmc.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_gpio.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_i2c.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_iwdg.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_pwr.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_rcc.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_rtc.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_sdio.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_spi.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_tim.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_usart.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\Libraries\STM32F10x_StdPeriph_Driver\src\stm32f10x_wwdg.o Warning: C3912W: Option 'device' is deprecated. Warning: A3912W: Option 'device' is deprecated. 0 Errors, 1 Warning Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. CC build\src\clock.o Warning: C3912W: Option 'device' is deprecated. CC build\src\device.o Warning: C3912W: Option 'device' is deprecated. CC build\src\idle.o Warning: C3912W: Option 'device' is deprecated. CC build\src\ipc.o Warning: C3912W: Option 'device' is deprecated. CC build\src\irq.o Warning: C3912W: Option 'device' is deprecated. CC build\src\kservice.o Warning: C3912W: Option 'device' is deprecated. CC build\src\mem.o Warning: C3912W: Option 'device' is deprecated. CC build\src\mempool.o Warning: C3912W: Option 'device' is deprecated. CC build\src\object.o Warning: C3912W: Option 'device' is deprecated. CC build\src\scheduler.o Warning: C3912W: Option 'device' is deprecated. CC build\src\thread.o Warning: C3912W: Option 'device' is deprecated. CC build\src\timer.o Warning: C3912W: Option 'device' is deprecated. LINK rtthread-stm32.axf Warning: L3912W: Option 'device' is deprecated. Finished: 0 information, 1 warning and 0 error messages. fromelf --bin rtthread-stm32.axf --output rtthread.bin fromelf -z rtthread-stm32.axf ======================================================================== ** Object/Image Component Sizes Code (inc. data) RO Data RW Data ZI Data Debug Object Name 55744 6190 4480 464 6848 509186 rtthread-stm 32.axf (uncompressed) 55744 6190 4480 168 6848 509186 rtthread-stm 32.axf (compressed) 55744 6190 4480 168 0 0 ROM Totals f or rtthread-stm32.axf scons: done building targets. 编译的是rt-thread 1.22版本过程是照配置 rt-thread开发环境里面配的
2015-09-12
从末碰到楼主的问题,帮顶。
2015-09-12
lz的生成工程应该是空格的问题, scons --target = mdk4 -s 应该是 scons --target=mdk4 -s 等号两边都不应该有空格。scons编译的问题应该和MDK5相关,MDK5还没怎么用
筱l灬夏初eri
2015-09-13
已经解决了我将rt-thread升级到2.01版本就好了2.01版支持scons --target=mdk5 -s
lujun723
2015-09-19
2015-09-20
>Warning: C3912W: Option 'device' is deprecated. --- 新版本编译器参数更改了,可以自己修改下rtconfig.py。
tanek
2017-07-28
>Warning: C3912W: Option 'device' is deprecated. --- 改rtconfig.py的 DEVICE。例如原来是 DEVICE = ' --device DARMSTM', 改成这种形式 DEVICE = ' --cpu Cortex-M0+'就好了
坠々辰
2017-12-21
>lz的生成工程应该是空格的问题, >scons --target = mdk4 -s --- -是减号还是_啊
2017-12-21
>-是减号还是_啊 --- 减号
坠々辰
2017-12-21
>减号 --- 话说下载好的不是有源代码么 还要scons创建干嘛
坠々辰
2017-12-21
>减号 --- 哦 不对 是有工程了 发错了
6.7k
筱l灬夏初eri
