Modbus
libmodbus驱动可以同时应用在多个串口上面吗
发布于 2020-09-08 11:32:32 浏览:2041
modbus_new_rtu这个函数返回的是modbus结构体指针*ctx,通过创建多个不同的结构体指针,我觉得应该可以创建串口多个modbus接口,不知道是不是这样,有人试过吗
文武斌
2020-09-08
可以的,只要你的控制块不一样就行
晨起小酌
2020-09-08
```c modbus_t* modbus_new_rtu(const char *device, int baud, char parity, int data_bit, int stop_bit) { modbus_t *ctx; modbus_rtu_t *ctx_rtu; /* Check device argument */ if (device == NULL || *device == 0) { fprintf(stderr, "The device string is empty\n"); errno = EINVAL; return NULL; } /* Check baud argument */ if (baud == 0) { fprintf(stderr, "The baud rate value must not be zero\n"); errno = EINVAL; return NULL; } ctx = (modbus_t *)malloc(sizeof(modbus_t)); _modbus_init_common(ctx); ctx->backend = &_modbus_rtu_backend; ctx->backend_data = (modbus_rtu_t *)malloc(sizeof(modbus_rtu_t)); ctx_rtu = (modbus_rtu_t *)ctx->backend_data; ctx_rtu->device = NULL; /* Device name and \0 */ ctx_rtu->device = (char *)malloc((strlen(device) + 1) * sizeof(char)); strcpy(ctx_rtu->device, device); ctx_rtu->baud = baud; if (parity == 'N' || parity == 'E' || parity == 'O') { ctx_rtu->parity = parity; } else { modbus_free(ctx); errno = EINVAL; return NULL; } ctx_rtu->data_bit = data_bit; ctx_rtu->stop_bit = stop_bit; #if HAVE_DECL_TIOCSRS485 /* The RS232 mode has been set by default */ ctx_rtu->serial_mode = MODBUS_RTU_RS232; #endif #if HAVE_DECL_TIOCM_RTS /* The RTS use has been set by default */ ctx_rtu->rts = MODBUS_RTU_RTS_NONE; /* Calculate estimated time in micro second to send one byte */ ctx_rtu->onebyte_time = 1000000 * (1 + data_bit + (parity == 'N' ? 0 : 1) + stop_bit) / baud; ctx_rtu->rts_pin = 0; /* The internal function is used by default to set RTS */ ctx_rtu->set_rts = _modbus_rtu_ioctl_rts; /* The delay before and after transmission when toggling the RTS pin */ ctx_rtu->rts_delay = ctx_rtu->onebyte_time; #endif ctx_rtu->confirmation_to_ignore = FALSE; return ctx; } ```
ching
2020-09-08
看代码像是可以的
lizhen9880
2020-09-08
可以
2k
晨起小酌
ModbusRTU协议栈漏发送最后一个字节
3.0 增加freemodbus,编译不过
关于 freemodbus 里存在的一点问题分享
请教如何使用组件里的FreeMODBUS
求一个FreeModbus的从机测试程序
FreeModbus的从机调试说明(含测试程序)
rtt_freemodbus
freemodbus怎么配置到uart
FreeModeBus从机调试问题
