PWM配置一直没法输出?
发布于 2020-09-12 15:06:24 浏览:2204
stm32f103zet6芯片,根据官方配置的pwm一直没有输出,求各位大佬指点一下
KJUS_6193
2020-09-12
我刚刚完成了PWM控制LED的实验,分享一下吧,有两个地方比较关键 1:例如要把 ```c void HAL_TIM_MspPostInit(TIM_HandleTypeDef *htim); /** * Initializes the Global MSP. */ void HAL_MspInit(void) { /* USER CODE BEGIN MspInit 0 */ /* USER CODE END MspInit 0 */ __HAL_RCC_AFIO_CLK_ENABLE(); __HAL_RCC_PWR_CLK_ENABLE(); /* System interrupt init*/ /** NOJTAG: JTAG-DP Disabled and SW-DP Enabled */ __HAL_AFIO_REMAP_SWJ_NOJTAG(); /* USER CODE BEGIN MspInit 1 */ /* USER CODE END MspInit 1 */ } /** * @brief TIM_Base MSP Initialization * This function configures the hardware resources used in this example * @param htim_base: TIM_Base handle pointer * @retval None */ void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base) { if(htim_base->Instance==TIM3) { /* USER CODE BEGIN TIM3_MspInit 0 */ /* USER CODE END TIM3_MspInit 0 */ /* Peripheral clock enable */ __HAL_RCC_TIM3_CLK_ENABLE(); /* USER CODE BEGIN TIM3_MspInit 1 */ /* USER CODE END TIM3_MspInit 1 */ } } void HAL_TIM_MspPostInit(TIM_HandleTypeDef* htim) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(htim->Instance==TIM3) { /* USER CODE BEGIN TIM3_MspPostInit 0 */ /* USER CODE END TIM3_MspPostInit 0 */ __HAL_RCC_GPIOB_CLK_ENABLE(); /**TIM3 GPIO Configuration PB4 ------> TIM3_CH1 */ GPIO_InitStruct.Pin = GPIO_PIN_4; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); __HAL_AFIO_REMAP_TIM3_PARTIAL(); /* USER CODE BEGIN TIM3_MspPostInit 1 */ /* USER CODE END TIM3_MspPostInit 1 */ } } /** * @brief TIM_Base MSP De-Initialization * This function freeze the hardware resources used in this example * @param htim_base: TIM_Base handle pointer * @retval None */ void HAL_TIM_Base_MspDeInit(TIM_HandleTypeDef* htim_base) { if(htim_base->Instance==TIM3) { /* USER CODE BEGIN TIM3_MspDeInit 0 */ /* USER CODE END TIM3_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_TIM3_CLK_DISABLE(); /* USER CODE BEGIN TIM3_MspDeInit 1 */ /* USER CODE END TIM3_MspDeInit 1 */ } } ``` cubeMX中定时器配置的代码复制到board.c 2:要做主函数手动初始化定时器,例如 ```c /* * Copyright (c) 2006-2020, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2020-09-08 RT-Thread first version */ #include
TIM_HandleTypeDef htim3; static void MX_TIM3_Init(void); int main(void) { int count = 1; MX_TIM3_Init(); while (count++) { LOG_D("Hello RT-Thread!"); rt_thread_mdelay(2000); } return RT_EOK; } static void MX_TIM3_Init(void) { /* USER CODE BEGIN TIM3_Init 0 */ /* USER CODE END TIM3_Init 0 */ TIM_ClockConfigTypeDef sClockSourceConfig = {0}; TIM_MasterConfigTypeDef sMasterConfig = {0}; TIM_OC_InitTypeDef sConfigOC = {0}; /* USER CODE BEGIN TIM3_Init 1 */ /* USER CODE END TIM3_Init 1 */ htim3.Instance = TIM3; htim3.Init.Prescaler = 0; htim3.Init.CounterMode = TIM_COUNTERMODE_UP; htim3.Init.Period = 0; htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE; if (HAL_TIM_Base_Init(&htim3) != HAL_OK) { Error_Handler(); } sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL; if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK) { Error_Handler(); } if (HAL_TIM_PWM_Init(&htim3) != HAL_OK) { Error_Handler(); } sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET; sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK) { Error_Handler(); } sConfigOC.OCMode = TIM_OCMODE_PWM1; sConfigOC.Pulse = 0; sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH; sConfigOC.OCFastMode = TIM_OCFAST_DISABLE; if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_1) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN TIM3_Init 2 */ /* USER CODE END TIM3_Init 2 */ HAL_TIM_MspPostInit(&htim3); } ``` 我用的是studio v1.1.3其他的仔细看教程
夏天的da风
2020-09-25
3.关于static void MX_TIM3_Init(void),这个函数可以不要,因为在drv_pwm.c里面的stm32_hw_pwm_init已经做了相关的设置了。 那么问题来了,为什么MX_TIM3_Init(void)不放在main()里面没有PWM波输出呢?因为stm32_hw_pwm_init函数本身有问题!正确的写法是![drv_pwm_c.JPG](/uploads/20200925/25b36007baf9c9db9880e264a27fb68d.jpg) ,即HAL_TIM_MspPostInit()必须放在HAL_TIM_PWM_ConfigChannel函数之前! 4.其实这里的PWM作为一个设备,是很勉强的,但是timer作为一个设备却很合理,因为timer在不同的工作模式下,才会导致PWM的输出方式有很多种,并且作为PWM输出的Pin脚在其他的模式下,几乎可以指定为任意引脚(例如:比较模式输出下)。 5.HAL_TIM_MspPostInit其实就只配置需要做为PWM输出脚,但是不知道为什么取这么理解的名字
yangjie
2020-09-12
hello
什么版本的代码?
2020-09-12
[STM32 系列外设驱动添加指南](https://gitee.com/rtthread/rt-thread/blob/gitee_master/bsp/stm32/docs/STM32%E7%B3%BB%E5%88%97%E5%A4%96%E8%AE%BE%E9%A9%B1%E5%8A%A8%E6%B7%BB%E5%8A%A0%E6%8C%87%E5%8D%97.md) 这个文档看过了吗
yutian0606
2020-09-16
是的,board.h 中关于PWM的介绍不完整 ```c /*-------------------------- PWM CONFIG BEGIN --------------------------*/ /** if you want to use pwm you can use the following instructions. * * STEP 1, open pwm driver framework support in the RT-Thread Settings file * * STEP 2, define macro related to the pwm * such as #define BSP_USING_PWM1 * * STEP 3, copy your pwm timer init function from stm32xxxx_hal_msp.c generated by stm32cubemx to the end if board.c file * such as void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base) and * void HAL_TIM_MspPostInit(TIM_HandleTypeDef* htim) * * STEP 4, modify your stm32xxxx_hal_config.h file to support pwm peripherals. define macro related to the peripherals * such as #define HAL_TIM_MODULE_ENABLED ```
富士山下_LJH
2020-11-13
有源码分享吗
RT_Jerry
2021-03-29
楼主解决了吗,同问
autodevice
2021-08-11
遇到同样问题了,回去按楼上说的试试看@夏天的da风
2.2k
Zqm
玩iot camera笔记之3测试试用3路pwm
[已解决]PWM输出异常分析
给RT-Thread添加PWM驱动框架
关于rt-thread-3.1.0 pwm
stm32f103ze 添加pwm 设备失败
MCXN947测评系列(二)串口设备测评
