IAP_在线更新
IAP程序下载到80%就下不进去了
发布于 2020-09-13 15:05:10 浏览:911
![IAP.png](/uploads/20200913/cda6cea0c4aa8adf208bbd3a0ae9421a.png) 芯片我用的是STM32L412,IAP程序参考了L4固件库的IAP例程, ```c COM_StatusTypeDef Ymodem_Receive ( uint32_t *p_size ) { uint32_t i, packet_length, session_done = 0, file_done, errors = 0, session_begin = 0; uint32_t flashdestination, ramsource, filesize; uint8_t *file_ptr; uint8_t file_size[FILE_SIZE_LENGTH], tmp, packets_received; COM_StatusTypeDef result = COM_OK; /* Initialize flashdestination variable */ flashdestination = APPLICATION_ADDRESS; while ((session_done == 0) && (result == COM_OK)) { packets_received = 0; file_done = 0; while ((file_done == 0) && (result == COM_OK)) { switch (ReceivePacket(aPacketData, &packet_length, DOWNLOAD_TIMEOUT)) { case HAL_OK: errors = 0; switch (packet_length) { case 2: /* Abort by sender */ Serial_PutByte(ACK); result = COM_ABORT; break; case 0: /* End of transmission */ Serial_PutByte(ACK); file_done = 1; break; default: /* Normal packet */ if (aPacketData[PACKET_NUMBER_INDEX] != packets_received) { Serial_PutByte(NAK); } else { if (packets_received == 0) { /* File name packet */ if (aPacketData[PACKET_DATA_INDEX] != 0) { /* File name extraction */ i = 0; file_ptr = aPacketData + PACKET_DATA_INDEX; while ( (*file_ptr != 0) && (i < FILE_NAME_LENGTH)) { aFileName[i++] = *file_ptr++; } /* File size extraction */ aFileName[i++] = '\0'; i = 0; file_ptr ++; while ( (*file_ptr != ' ') && (i < FILE_SIZE_LENGTH)) { file_size[i++] = *file_ptr++; } file_size[i++] = '\0'; Str2Int(file_size, &filesize); /* Test the size of the image to be sent */ /* Image size is greater than Flash size */ if (*p_size > (USER_FLASH_SIZE + 1)) { /* End session */ tmp = CA; HAL_UART_Transmit(&UartHandle, &tmp, 1, NAK_TIMEOUT); HAL_UART_Transmit(&UartHandle, &tmp, 1, NAK_TIMEOUT); result = COM_LIMIT; } /* erase user application area */ FLASH_If_Erase(APPLICATION_ADDRESS); *p_size = filesize; Serial_PutByte(ACK); Serial_PutByte(CRC16); } /* File header packet is empty, end session */ else { Serial_PutByte(ACK); file_done = 1; session_done = 1; break; } } else /* Data packet */ { ramsource = (uint32_t) & aPacketData[PACKET_DATA_INDEX]; /* Write received data in Flash */ if (FLASH_If_Write(flashdestination, (uint32_t*) ramsource, packet_length/4) == FLASHIF_OK) { flashdestination += packet_length; Serial_PutByte(ACK); } else /* An error occurred while writing to Flash memory */ { /* End session */ Serial_PutByte(CA); Serial_PutByte(CA); result = COM_DATA; } } packets_received ++; session_begin = 1; } break; } break; case HAL_BUSY: /* Abort actually */ Serial_PutByte(CA); Serial_PutByte(CA); result = COM_ABORT; break; default: if (session_begin > 0) { errors ++; } if (errors > MAX_ERRORS) { /* Abort communication */ Serial_PutByte(CA); Serial_PutByte(CA); } else { Serial_PutByte(CRC16); /* Ask for a packet */ } break; } } } return result; } ``` 传到80%的时候ReceivePacket的返回值就是错误码了 有遇到过类似问题的朋友么?
DQXG_3150
2020-09-13
是因为我的ram是32K的
911
DQXG_3150
RTT-stdio 设置flash地址
RT Thread 尝试IAP功能时 分区FLASH无法擦写
请问用rtt做bootloader跳转前需要关闭哪些东西?
stm32f103rc IAP通过bootloder写入bin文件跑不起来
rtt编写的bootloader可顺利跳转至app但运行异常
如何确定文件在flash中的物理地址
关于STM32H743的bootloader的地址问题
stm32 hal库iap程序心得分享
iap跳转至app后,系统调度失败引起异常复位
STM32F429VGT6使用ST LINK下载bootloader串口输出乱码
