使用rtt_studio开发I2C碰到的问题
发布于 2020-09-14 16:30:05 浏览:1679
使用i2c设备时可以查询到设备,但是rt_i2c_transfer出错,错误码为-1.利用逻辑分析仪抓包时,时钟线应该是有问题,这是指引脚和i2c初始化时出错吗?初始化代码是用cube mx直接生成的。具体代码如下: ``` static void MX_I2C2_Init(void) { hi2c2.Instance = I2C2; hi2c2.Init.ClockSpeed = 100000; hi2c2.Init.DutyCycle = I2C_DUTYCYCLE_2; hi2c2.Init.OwnAddress1 = 0; hi2c2.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT; hi2c2.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE; hi2c2.Init.OwnAddress2 = 0; hi2c2.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE; hi2c2.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE; if (HAL_I2C_Init(&hi2c2) != HAL_OK) { rt_kprintf("i2c init error"); Error_Handler(); } /** Configure Analogue filter */ if (HAL_I2CEx_ConfigAnalogFilter(&hi2c2, I2C_ANALOGFILTER_ENABLE) != HAL_OK) { rt_kprintf("i2c filter error"); Error_Handler(); } /** Configure Digital filter */ if (HAL_I2CEx_ConfigDigitalFilter(&hi2c2, 0) != HAL_OK) { rt_kprintf("i2c digit filter error"); Error_Handler(); } /* USER CODE BEGIN I2C2_Init 2 */ /* USER CODE END I2C2_Init 2 */ } void HAL_I2C_MspInit(I2C_HandleTypeDef* hi2c) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(hi2c->Instance==I2C2) { /* USER CODE BEGIN I2C2_MspInit 0 */ /* USER CODE END I2C2_MspInit 0 */ __HAL_RCC_GPIOH_CLK_ENABLE(); /**I2C2 GPIO Configuration PH5 ------> I2C2_SDA PH4 ------> I2C2_SCL */ GPIO_InitStruct.Pin = GPIO_PIN_4|GPIO_PIN_5; GPIO_InitStruct.Mode = GPIO_MODE_AF_OD; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF4_I2C2; HAL_GPIO_Init(GPIOH, &GPIO_InitStruct); /* Peripheral clock enable */ __HAL_RCC_I2C2_CLK_ENABLE(); /* USER CODE BEGIN I2C2_MspInit 1 */ /* USER CODE END I2C2_MspInit 1 */ } } 写寄存器函数如下 /* 写传感器寄存器 */ static rt_err_t write_reg(struct rt_i2c_bus_device *bus, rt_uint8_t reg, rt_uint32_t data) { rt_uint8_t buf[4]; struct rt_i2c_msg msgs; buf[0] = reg; //cmd buf[1] = (rt_uint8_t)data>>16; buf[2] = (rt_uint8_t)data>>8; buf[3] = (rt_uint8_t)data; msgs.addr = ADS_ADDR; msgs.flags = RT_I2C_WR; msgs.buf = buf; msgs.len = 4; /* 调用I2C设备接口传输数据 */ if (rt_i2c_transfer(bus, &msgs, 1) == 1) { return RT_EOK; } else { return -RT_ERROR; } } /* board.h 中如下 */ #define BSP_USING_I2C2 #ifdef BSP_USING_I2C2 #define BSP_I2C2_SCL_PIN GET_PIN(H, 4) #define BSP_I2C2_SDA_PIN GET_PIN(H, 5) #endif ``` ![微信截图_20200914162531.png](/uploads/20200914/f14f653b915b7806879ba0382071a393.png)
红枫
2020-09-14
这一段错误 ```c buf[0] = reg; //cmd buf[1] = (rt_uint8_t)data>>16; buf[2] = (rt_uint8_t)data>>8; buf[3] = (rt_uint8_t)data; ```
liuduanfei
2020-09-14
用软件I2C吧,估计没多少人用stm32的硬件I2C
1.7k
秋风乍起
NXP的I2C应该比ST的好用吧
Use of I2C device driver
关于I2C 驱动问题请教
我如何知道这个iic的io配置和我电路设计的是一致的?
I2C模拟读操作失败,不知道问什么进不去读函数
RTT的I2C有官方文档资料没有
求 STM32F103 IIC 自定义IO初始化 代码
报一个LPC4008代码中I2C的bug
RTOS IIC总线使用
关于在RTT中使用STM32 I2C的疑问
NXP MCXN947测评之 adc
