SD卡_TF卡
虚拟文件
studio配置SD卡和虚拟文件系统,测试SD卡写入速度只有100多KB/s?
发布于 2020-09-15 14:11:27 浏览:2211
我用rtthread studio中的sd卡使用虚拟文件系统例程写入数据,我测的写入速度为120kb/s,看了下它的有关于sd卡初始化的代码,看不太懂,然后看了下原子的sd卡初始化过程,发现sd卡初始化后需要再设置下时钟,但是在rtt里面我没有找到相关的配置,有大佬知道什么原因导致速度过慢吗?怎么解决,求教,测试sd卡写入速度代码如下: ```c int fd, size; float speed ; float speed_time; int i; char buf[20]; int8_t s[256] = "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!" "RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer! RT-Thread Programmer!"; char buffer[80]; /* 以创建和读写模式打开 /text.txt 文件,如果该文件不存在则创建该文件 */ rt_kprintf("Write ...........\n"); rt_kprintf("tick is :%d !\n", rt_tick_get()); speed = rt_tick_get(); fd = open("/text.txt", O_WRONLY | O_CREAT | O_APPEND); if (fd>= 0) { for (i = 0; i < 1024; ++i) { write(fd, s, sizeof(s)); } close(fd); rt_kprintf("tick is :%d !\n", rt_tick_get()); speed = rt_tick_get()-speed; speed_time = 1000/speed; speed_time = (sizeof(s)*speed_time); sprintf((char*)buf, "%3.1f",(float)speed_time); rt_kprintf("Write done. speed:%f kb/s\n",speed_time); } /* 以只读模式打开 /text.txt 文件 */ fd = open("/text.txt", O_RDONLY); if (fd>= 0) { size = read(fd, buffer, sizeof(buffer)); close(fd); // rt_kprintf("Read from file test.txt : %s \n", buffer); if (size < 0) return ; } } ```
lizhen9880
2020-09-15
可做如下尝试: ## 方法1 如下drv_sdio.h中,默认SDIO_MAX_FREQ只有1M,将SDIO_MAX_FREQ根据自己的MCU SDIO的最高频率改大,可改到24M ![image.png](/uploads/20200915/8a7a7aa2278dea1531f0b8e7cab010a4.png) **如果这样做有效,建议你按照方法2来** ## 方法2 建议你修改board/Kconfig,增加如下配置 ```bash if BSP_USING_SDCARD config SDIO_MAX_FREQ int "sdio max freq" range 0 24000000 default 1000000 endif ``` 这样会在rt_config.h中增加SDIO_MAX_FREQ宏,drv_sdio.h中失效(如果你的Kconfig中已经有该项了,直接配置即可)
chenyingchun
2020-09-16
请按照lizhen9880的建议再试一下看看, 我这边用的F413, SDIO_MAX_FREQ 设置的50000000, 实测下来,写入速度可以最高可以达到3MByte/s ![SDIO.png](/uploads/20200916/5492a39b7c32d4648d7038a8ee3a33d0.png)
2020-09-15
测速可以用这个 `examples\file\writespeed.c`
2.2k
youstay
代码分享,stm32f407的sdio驱动。
求个在STM32F103 RTT上使用SDIO接口的例子
是否能增加一个 SDIO AP61xx 的驱动呢
sdio和fsmc驱动lcd冲突
关于rt-thread系统sdio驱动框架使用
sdio驱动是怎么使用的?也没有文档和例程啊
