NTP_网络校时
log RTC hasn't been configured 啥异常?
发布于 2020-09-17 15:41:44 浏览:1864
按照官方文档 开启了RTC功能,并配置了NTP。可以看到时钟确实是同步了,但是启动时会有如下的log 信息输出 [I/drv.rtc] RTC hasn't been configured, please use
command to config. 请问这是什么原因导致的啊? stm32f4xx_hal_conf.h中开启了#define HAL_RTC_MODULE_ENABLED board.h 中开启了 #define BSP_USING_ONCHIP_RTC RTT setting中开启了 ![image.png](/uploads/20200917/93761ae680ee38db1aa7abbfab84d77a.png) ![image.png](/uploads/20200917/6fc9af0d99ad4a6d397bd2969945430c.png) 这个log我需要怎么处理?
leeherry
2020-09-20
drv_rtc.c文件里面的 ```c RT_WEAK uint32_t HAL_RTCEx_BKUPRead(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister) { return (~BKUP_REG_DATA); } RT_WEAK void HAL_RTCEx_BKUPWrite(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister, uint32_t Data) { return; } ``` 这两个函数有问题,是空的 到xxxx_hal_rtc_ex.c文件里面,找到这两个函数,复制粘贴就好了 例如 stm32f407zg 的 ```c /** * @brief Writes a data in a specified RTC Backup data register. * @param hrtc pointer to a RTC_HandleTypeDef structure that contains * the configuration information for RTC. * @param BackupRegister RTC Backup data Register number. * This parameter can be: RTC_BKP_DRx where x can be from 0 to 19 to * specify the register. * @param Data Data to be written in the specified RTC Backup data register. * @retval None */ void HAL_RTCEx_BKUPWrite(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister, uint32_t Data) { uint32_t tmp = 0U; /* Check the parameters */ assert_param(IS_RTC_BKP(BackupRegister)); tmp = (uint32_t)&(hrtc->Instance->BKP0R); tmp += (BackupRegister * 4U); /* Write the specified register */ *(__IO uint32_t *)tmp = (uint32_t)Data; } /** * @brief Reads data from the specified RTC Backup data Register. * @param hrtc pointer to a RTC_HandleTypeDef structure that contains * the configuration information for RTC. * @param BackupRegister RTC Backup data Register number. * This parameter can be: RTC_BKP_DRx where x can be from 0 to 19 to * specify the register. * @retval Read value */ uint32_t HAL_RTCEx_BKUPRead(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister) { uint32_t tmp = 0U; /* Check the parameters */ assert_param(IS_RTC_BKP(BackupRegister)); tmp = (uint32_t)&(hrtc->Instance->BKP0R); tmp += (BackupRegister * 4U); /* Read the specified register */ return (*(__IO uint32_t *)tmp); } ``` //只粘贴函数的内容,不要粘贴所有 //细节处自行修改 RT_WEAK uint32_t HAL_RTCEx_BKUPRead(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister) { uint32_t tmp = 0U; /* Check the parameters */ assert_param(IS_RTC_BKP(BackupRegister)); tmp = (uint32_t)&(hrtc->Instance->BKP0R); tmp += (BackupRegister * 4U); /* Read the specified register */ return (*(__IO uint32_t *)tmp); } RT_WEAK void HAL_RTCEx_BKUPWrite(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister, uint32_t Data) { uint32_t tmp = 0U; /* Check the parameters */ assert_param(IS_RTC_BKP(BackupRegister)); tmp = (uint32_t)&(hrtc->Instance->BKP0R); tmp += (BackupRegister * 4U); /* Write the specified register */ *(__IO uint32_t *)tmp = (uint32_t)Data; }
wofei1314
2020-09-17
这个应该只是一个信息提示,告诉你,RTC被改过了,后面的使用data命令可以手动调整,并没有其它的意思
1.9k
walawala365
RTC驱动框架几点建议
[新人试水] LPC1768 Nano3_9 添加RTC
STM32 关于RTC的问题
stm32f4xx-HAL BSP的RTC设置不对
关于STM32的RTC设置年份不正确的问题
RTT的RTC驱动调试
rtc驱动中的bkp模块起不到防止时间的重新设置
rtc时钟跑十几个小时后,比实际时间快几秒怎么解决
stm32如何断电之后开发板rtc时间继续往前跑
