TIM
关于在L4潘多拉上定时器TIM3跑hwtimer_sample例程出错的问题
发布于 2020-09-29 18:43:31 浏览:1094
使用的是RT-Thread master 4.0.3,在hwtimer_sample.c中使用了TIM3,但是出现以下问题: 1.在hwtimer_sample.c设置定时器超时值为5s启动定时器,但是tick返回的值间66/67ms ![2.PNG](/uploads/20200929/7a92c3bda242fcfab31a95cf4a8e5866.png) 2.在cubemx中系统时钟设置的为80M,在hwtimer_sample.c设置定时器超时值为1s启动定时器,经过验证TIM3中断了16次(若使用TIM15亦中断16次且问题1中的tick返回值正好相差1s),如果timer_init函数中的以下代码是有效的,那经过计算,系统时钟应该是256M,请问以下代码有否有效,如果没有,那定时器的分频系数等是在哪里设置的? ```c tim->Init.Period = 10000 - 1; tim->Init.Prescaler = prescaler_value; tim->Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; if (timer->info->cntmode == HWTIMER_CNTMODE_UP) { tim->Init.CounterMode = TIM_COUNTERMODE_UP; } else { tim->Init.CounterMode = TIM_COUNTERMODE_DOWN; } tim->Init.RepetitionCounter = 0; ``` 以下为问题相关代码: hwtimer_sample.c例程: ``` #define HWTIMER_DEV_NAME "timer3" /* 定时器名称 */ /* 定时器超时回调函数 */ static rt_err_t timeout_cb(rt_device_t dev, rt_size_t size) { rt_kprintf("this is hwtimer timeout callback fucntion!\n"); rt_kprintf("tick is :%d !\n", rt_tick_get()); return 0; } static int hwtimer_sample(int argc, char *argv[]) { rt_err_t ret = RT_EOK; rt_hwtimerval_t timeout_s; /* 定时器超时值 */ rt_device_t hw_dev = RT_NULL; /* 定时器设备句柄 */ rt_hwtimer_mode_t mode; /* 定时器模式 */ /* 查找定时器设备 */ hw_dev = rt_device_find(HWTIMER_DEV_NAME); if (hw_dev == RT_NULL) { rt_kprintf("hwtimer sample run failed! can't find %s device!\n", HWTIMER_DEV_NAME); return RT_ERROR; } /* 以读写方式打开设备 */ ret = rt_device_open(hw_dev, RT_DEVICE_OFLAG_RDWR); if (ret != RT_EOK) { rt_kprintf("open %s device failed!\n", HWTIMER_DEV_NAME); return ret; } /* 设置超时回调函数 */ rt_device_set_rx_indicate(hw_dev, timeout_cb); /* 设置模式为周期性定时器 */ mode = HWTIMER_MODE_PERIOD; ret = rt_device_control(hw_dev, HWTIMER_CTRL_MODE_SET, &mode); if (ret != RT_EOK) { rt_kprintf("set mode failed! ret is :%d\n", ret); return ret; } /* 设置定时器超时值为5s并启动定时器 */ timeout_s.sec = 5; /* 秒 */ timeout_s.usec = 0; /* 微秒 */ if (rt_device_write(hw_dev, 0, &timeout_s, sizeof(timeout_s)) != sizeof(timeout_s)) { rt_kprintf("set timeout value failed\n"); return RT_ERROR; } /* 延时3500ms */ rt_thread_mdelay(3500); /* 读取定时器当前值 */ rt_device_read(hw_dev, 0, &timeout_s, sizeof(timeout_s)); rt_kprintf("Read: Sec = %d, Usec = %d\n", timeout_s.sec, timeout_s.usec); return ret; } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(hwtimer_sample, hwtimer sample); ```
2021-03-18
如果是st的系列芯片均建议使用stm32cubemx来配置芯片管脚和初始化。
1.1k
hem
潘多拉开发板AP6181 外设支持报错
潘多拉wifi管理例程中ap模式未启动
潘多拉开发板上I2C设备驱动开发
潘多拉开发板 综合例程 调试报错
潘多拉开发板在VSCODE无法执行micropython
潘多拉添加freemodbus例子出现错误
潘多拉开发板OV2640拍摄JPEG格式的照片
SFUD 提示闪存超过32g
有谁用潘多拉开发过OV2640吗
请问潘多拉开发板怎么烧录micropython固件
NXP MCXN947测评之 adc
