auto
update
FlashDB在哪里修改版本号实现自动更新?
发布于 2020-10-09 20:52:50 浏览:1264
如题,easyflash可以通过设置版本号实现参数自动更新,flashDB在哪里设置?
刘小飞
2021-03-19
![image.png](https://oss-club.rt-thread.org/uploads/20210319/45c6ae3d6ce454a0aa71e751728e5871.png) 这里更改版本号进行更改判断 ``` static void kv_auto_update(fdb_kvdb_t db)//这个代码是自动更新的源码 { size_t saved_ver_num, setting_ver_num = db->ver_num; if (get_kv(db, VER_NUM_KV_NAME, &saved_ver_num, sizeof(size_t), NULL) > 0) { /* check version number */ if (saved_ver_num != setting_ver_num) {//判断是否更新 struct fdb_kv kv; size_t i, value_len; struct kvdb_sec_info sector; FDB_DEBUG("Update the KV from version %u to %u.\n", saved_ver_num, setting_ver_num); for (i = 0; i < db->default_kvs.num; i++) { /* add a new KV when it's not found */ if (!find_kv(db, db->default_kvs.kvs[i].key, &kv)) { /* It seems to be a string when value length is 0. * This mechanism is for compatibility with older versions (less then V4.0). */ if (db->default_kvs.kvs[i].value_len == 0) { value_len = strlen(db->default_kvs.kvs[i].value); } else { value_len = db->default_kvs.kvs[i].value_len; } sector.empty_kv = FAILED_ADDR; create_kv_blob(db, §or, db->default_kvs.kvs[i].key, db->default_kvs.kvs[i].value, value_len); } } } else { /* version number not changed now return */ return; } } set_kv(db, VER_NUM_KV_NAME, &setting_ver_num, sizeof(size_t)); } ```
liuduanfei
2020-10-10
FDB_KV_AUTO_UPDATE 使能 KV 自动升级功能。该功能使能后, fdb_kvdb.ver_num 存储了当前数据库的版本,如果版本发生变化时,会自动触发升级动作,将更新新的默认 KV 集合至当前数据库中。
tangYi0_0
2021-03-03
![14fb08634e26649828162c5c03fead13.jpg](https://oss-club.rt-thread.org/uploads/20210303/14fb08634e26649828162c5c03fead13.jpg)
pjdu
2021-03-19
谢谢各位!
1.3k
pjdu
24
54
flashDB有两个变量未定义?
FlashDB 初始化时出现 check failed
FlashDB初始化isn't initialize OK
flashDB重复更新同一个参数的问题
flashDB kv ts 最大存储字节在哪里设置
操作flashDB时thread 提示error -2 超时
flashdb 断言错误问题求解
FlashDB没法选择版本
flashdb出现moved kv日志后,再去查询发现数据有丢失
FlashDB 中 tsdb 如何实现 记录FILO的查询显示
