mem.c 静态代码pclint检查报错
发布于 2020-10-16 14:43:58 浏览:1145
``` --- Module: D:\pclint\mem.c (C) D:\pclint\mem.c 149 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 nmem = (struct heap_mem *)&heap_ptr[mem->next]; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 162 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 ((struct heap_mem *)&heap_ptr[nmem->next])->prev = (uint8_t *)mem - heap_ptr; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 166 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 pmem = (struct heap_mem *)&heap_ptr[mem->prev]; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 175 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 ((struct heap_mem *)&heap_ptr[mem->next])->prev = (uint8_t *)pmem - heap_ptr; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 217 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 mem = (struct heap_mem *)heap_ptr; ^~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 227 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 heap_end = (struct heap_mem *)&heap_ptr[mem->next]; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 239 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 lfree = (struct heap_mem *)heap_ptr; ^~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 300 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 ptr = ((struct heap_mem *)&heap_ptr[ptr])->next) ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 302 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 mem = (struct heap_mem *)&heap_ptr[ptr]; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 325 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 mem2 = (struct heap_mem *)&heap_ptr[ptr2]; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 340 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 ((struct heap_mem *)&heap_ptr[mem2->next])->prev = ptr2; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 377 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 lfree = (struct heap_mem *)&heap_ptr[lfree->next]; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 453 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 mem = (struct heap_mem *)((uint8_t *)rmem - SIZEOF_STRUCT_MEM); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 473 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 mem2 = (struct heap_mem *)&heap_ptr[ptr2]; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 484 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 ((struct heap_mem *)&heap_ptr[mem2->next])->prev = ptr2; ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 570 warning 2445: cast from 'uint8_t *' (aka 'unsigned char *') to 'struct heap_mem *' increases required alignment from 1 to 4 mem = (struct heap_mem *)((uint8_t *)rmem - SIZEOF_STRUCT_MEM); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ D:\pclint\mem.c 213 warning 523: expression statement involving operator ',' lacks side effects RT_DEBUG_LOG(RT_DEBUG_MEM, ("mem init, heap begin address 0x%x, size %d\n", ^ D:\pclint\mem.c 213 warning 505: redundant left argument to comma RT_DEBUG_LOG(RT_DEBUG_MEM, ("mem init, heap begin address 0x%x, size %d\n", ^ D:\pclint\mem.c 214 warning 505: redundant left argument to comma (rt_ubase_t)heap_ptr, mem_size_aligned)); ^ D:\pclint\mem.c 213 warning 505: redundant left argument to comma RT_DEBUG_LOG(RT_DEBUG_MEM, ("mem init, heap begin address 0x%x, size %d\n", ^ D:\pclint\mem.c 247 warning 525: unexpected negative indentation return -1; ^ D:\pclint\mem.c 246 supplemental 891: statement is controlled by preceding control structure if(mempool_ptr == NULL) ^ D:\pclint\mem.c 276 warning 523: expression statement involving operator ',' lacks side effects RT_DEBUG_LOG(RT_DEBUG_MEM, ("malloc size %d, but align to %d\n", ^ D:\pclint\mem.c 276 warning 505: redundant left argument to comma RT_DEBUG_LOG(RT_DEBUG_MEM, ("malloc size %d, but align to %d\n", ^ D:\pclint\mem.c 277 warning 505: redundant left argument to comma size, RT_ALIGN(size, RT_ALIGN_SIZE))); ^ D:\pclint\mem.c 276 warning 505: redundant left argument to comma RT_DEBUG_LOG(RT_DEBUG_MEM, ("malloc size %d, but align to %d\n", ^ D:\pclint\mem.c 279 warning 523: expression statement involving operator ',' lacks side effects RT_DEBUG_LOG(RT_DEBUG_MEM, ("malloc size %d\n", size)); ^ D:\pclint\mem.c 279 warning 505: redundant left argument to comma RT_DEBUG_LOG(RT_DEBUG_MEM, ("malloc size %d\n", size)); ^ D:\pclint\mem.c 279 warning 505: redundant left argument to comma RT_DEBUG_LOG(RT_DEBUG_MEM, ("malloc size %d\n", size)); ^ D:\pclint\mem.c 286 warning 523: expression statement involving operator ',' lacks side effects RT_DEBUG_LOG(RT_DEBUG_MEM, ("no memory\n")); ^ D:\pclint\mem.c 286 warning 505: redundant left argument to comma RT_DEBUG_LOG(RT_DEBUG_MEM, ("no memory\n")); ^ D:\pclint\mem.c 388 warning 523: expression statement involving operator ',' lacks side effects RT_DEBUG_LOG(RT_DEBUG_MEM, ^ D:\pclint\mem.c 388 warning 505: redundant left argument to comma RT_DEBUG_LOG(RT_DEBUG_MEM, ^ D:\pclint\mem.c 390 warning 505: redundant left argument to comma (rt_ubase_t)((uint8_t *)mem + SIZEOF_STRUCT_MEM), ^ D:\pclint\mem.c 389 warning 505: redundant left argument to comma ("allocate memory at 0x%x, size: %d\n", ^ D:\pclint\mem.c 428 warning 523: expression statement involving operator ',' lacks side effects RT_DEBUG_LOG(RT_DEBUG_MEM, ("realloc: out of memory\n")); ^ D:\pclint\mem.c 428 warning 505: redundant left argument to comma RT_DEBUG_LOG(RT_DEBUG_MEM, ("realloc: out of memory\n")); ^ D:\pclint\mem.c 564 warning 523: expression statement involving operator ',' lacks side effects RT_DEBUG_LOG(RT_DEBUG_MEM, ("illegal memory\n")); ^ D:\pclint\mem.c 564 warning 505: redundant left argument to comma RT_DEBUG_LOG(RT_DEBUG_MEM, ("illegal memory\n")); ^ D:\pclint\mem.c 572 warning 523: expression statement involving operator ',' lacks side effects RT_DEBUG_LOG(RT_DEBUG_MEM, ^ D:\pclint\mem.c 572 warning 505: redundant left argument to comma RT_DEBUG_LOG(RT_DEBUG_MEM, ^ D:\pclint\mem.c 574 warning 505: redundant left argument to comma (rt_ubase_t)rmem, ^ D:\pclint\mem.c 573 warning 505: redundant left argument to comma ("release memory 0x%x, size: %d\n", ^ --- Module Wrap-up --- Global Wrap-up --- Module: D:\pclint\mem.c (C) ```
ljt8015
2020-10-16
这些warning怎么清除?
1.1k
ljt8015
140
