创建线程提示SCB_CFSR_BFSR:0x04 IMPRECISERR 错误
发布于 2020-10-19 14:23:36 浏览:2761
1.系统版本: RTThread Nano 3.1.3 build Oct 19 2020 2.硬件版本:STM32F107RC 创建线程代码: ```c #define THREAD_PRIORITY 25 #define THREAD_STACK_SIZE 512 #define THREAD_TIMESLICE 5 ALIGN(RT_ALIGN_SIZE) static char thread2_stack[256]; static struct rt_thread thread2; static rt_thread_t tid1 = RT_NULL; /* 线程 2 入口 */ static void thread2_entry(void *param) { rt_uint32_t count = 0; /* 线程 2 拥有较高的优先级,以抢占线程 1 而获得执行 */ for (count = 0; count < 10 ; count++) { /* 线程 2 打印计数值 */ // rt_kprintf("thread2 count: %d\n", count); } // rt_kprintf("thread2 exit\n"); /* 线程 2 运行结束后也将自动被系统脱离 */ } int main(void) { MX_GPIO_Init(); rt_thread_t tid; #ifdef RT_USING_HEAP tid = rt_thread_create("thread", thread2_entry, RT_NULL, 128, THREAD_PRIORITY, 20); RT_ASSERT(tid != RT_NULL); #endif rt_thread_startup(tid); } ``` 内存初始化代码: ```c #define STM32_FLASH_START_ADRESS ((uint32_t)0x08000000) #define STM32_FLASH_SIZE (256 * 1024) #define STM32_FLASH_END_ADDRESS ((uint32_t)(STM32_FLASH_START_ADRESS + STM32_FLASH_SIZE)) /* Internal SRAM memory size[Kbytes] <8-64>, Default: 64*/ #define STM32_SRAM_SIZE 64 #define STM32_SRAM_END (0x20000000 + STM32_SRAM_SIZE * 1024) #if defined(__CC_ARM) || defined(__CLANG_ARM) extern int Image$$RW_IRAM1$$ZI$$Limit; #define HEAP_BEGIN ((void *)&Image$$RW_IRAM1$$ZI$$Limit) #elif __ICCARM__ #pragma section="CSTACK" #define HEAP_BEGIN (__segment_end("CSTACK")) #else extern int __bss_end; #define HEAP_BEGIN ((void *)&__bss_end) #endif #define HEAP_END STM32_SRAM_END #if defined(RT_USING_USER_MAIN) && defined(RT_USING_HEAP) #define RT_HEAP_SIZE 10240 static uint32_t rt_heap[RT_HEAP_SIZE]; RT_WEAK void *rt_heap_begin_get(void) { return rt_heap; } RT_WEAK void *rt_heap_end_get(void) { return rt_heap + RT_HEAP_SIZE; } #endif #if defined(RT_USING_USER_MAIN) && defined(RT_USING_HEAP) rt_system_heap_init(rt_heap_begin_get(), rt_heap_end_get()); #endif /* Heap initialization */ //#ifdef RT_USING_HEAP //#if STM32_EXT_SRAM // rt_system_heap_init((void*)STM32_EXT_SRAM_BEGIN, (void*)STM32_EXT_SRAM_END); //#else //#if defined(__CC_ARM) || defined(__CLANG_ARM) // rt_system_heap_init((void*)&Image$$RW_IRAM1$$ZI$$Limit, (void*)STM32_SRAM_END); //#elif __ICCARM__ // rt_system_heap_init(__segment_end("HEAP"), (void*)STM32_SRAM_END); //#else // /* init memory system */ // rt_system_heap_init((void*)&__bss_end, (void*)STM32_SRAM_END); //#endif //#endif /* STM32_EXT_SRAM */ //#endif /* RT_USING_HEAP */ /* Heap initialization */ #if defined(RT_USING_HEAP) // rt_system_heap_init((void *)HEAP_BEGIN, (void *)HEAP_END); #endif ``` 去除线程之后,正常。 错误信息 ![image.png](/uploads/20201019/9bfeaec401c21c276b0503775c2c54a4.png)
goodwell
2020-10-19
问题解决了,主要是因为配置文件,配置了RT_THREAD_PRIORITY_MAX的最大值为8,所以才会导致整个问题,然后只要将THREAD_PRIORITY改为一个小于8的值,就可以了。
2.8k
goodwell
求高手指点,RTThread下nanosleep()函数功能如何实现?在线等啊
RTT1.2.2在新塘Nano130KE3BN的移植中始终出现栈溢出的问题
官方能否出一个nano在mdk下移植finsh到stm32的教程
从裸机开始,创建一个RT-Thread Nano系统工程
Nano版如何启用shell
项目从RTT 2.x NANO移植到 RTT 3.x ENV 环境
nano 版本有没有集成到 IAR 中啊?
关于MDK5的RT-THREAD NANO中添加MSH组件的例程
rtt_nano版本,源代码在哪里下载啊?
RTT Nano 在keil 使用C++11 的问题
MCXN947测评系列(二)串口设备测评
