mo动态模块_Module
mo动态模块_Module
30
动态模块使用的疑惑,动态模块的子线程,mo文件运行一段时间后死机
发布于 2020-10-21 17:34:01 浏览:1424
在F4上面使用动态模块,按照教程做相应的配置,修改好链接脚本啥的, 最后msh下执行list_symbols可以看到所有的函数符号。 然后开始编写app模块 代码大致如下 ```c #include
#include "controller.h" static void thread_entry(void* parameter) { uint32_t index = 0; rt_thread_t now; struct tm* tm; time_t time_int; now = rt_thread_self(); rt_kprintf("this is app :%s\n",now->name); while (1) { time_int = time(RT_NULL); tm = localtime(&time_int); rt_kprintf("time %d %d %d\n",tm->tm_hour,tm->tm_min,tm->tm_sec); rt_thread_mdelay(30000); } } int main(int argc, char *argv[]) { rt_thread_t now; now = rt_thread_self(); rt_kprintf("this is app :%s\n",now->name); rt_kprintf("run %s\n",now->name); now = rt_thread_create("thread1",thread_entry, (void*)1,2048,22, 10); if (now != RT_NULL) rt_thread_startup(now); while(1) { read_wirte_data(); rt_thread_mdelay(300); } return 0; } ``` 运行效果正常一直在输出时间,但是msh下执行ps只能看到main所属的线程名字叫做rttapp(这是编译模块rttapp.mo的名字),却没有看到thread1线程的状态,但是这连个线程却在运行。 然后过了N久之后thread1线程突然因为pc地址错误而死机,效果如下: ``` psr: 0x21000000 r00: 0x0020019f r01: 0x08083ae4 r02: 0x00000002 r03: 0x00000003 r04: 0x00000002 r05: 0x200013bc r06: 0x08083ae4 r07: 0x20001200 r08: 0x20000c20 r09: 0x20024504 r10: 0x00000000 r11: 0x000007e0 r12: 0x00000190 lr: 0x08063a21 pc: 0x0805d918 hard fault on thread: thread1 thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- rttapp2 31 suspend 0x00000108 0x00000800 21% 0x00000006 000 tshell 12 suspend 0x00000184 0x00001000 30% 0x00000008 000 ntp_sync 26 suspend 0x000000a8 0x00000600 80% 0x00000002 000 sys_work 23 suspend 0x00000088 0x00000800 52% 0x0000000a 000 tidle0 31 ready 0x00000054 0x00000400 13% 0x0000001f 000 timer 10 suspend 0x00000080 0x00000400 17% 0x0000000a 000 main 10 suspend 0x00000148 0x00000800 57% 0x0000000a 000 bus fault: SCB_CFSR_BFSR:0x82 PRECISERR SCB->BFAR:0020019F ``` pc所指的: 0x0805d918我查了map文件,并无次函数地址 求大佬能解答一下
2020-10-21
> 查了map文件,并无次函数地址 那得刚好死在函数第1条指令才行,不然肯定不在函数地址啊,而是在函数里面。 你应该查反汇编,看这个地址在哪个函数里面。
文武斌
2020-10-22
我重新编译后,运行了同样的程序,还是会过段时间就死机,然后我查了每次死机后的PC指针的范围 ``` psr: 0x21000000 r00: 0x002008be r01: 0x08103e08 r02: 0x00000002 r03: 0x00000002 r04: 0x00000002 r05: 0x200013dc r06: 0x08103e08 r07: 0x20001200 r08: 0x20000c20 r09: 0x20023434 r10: 0x00000000 r11: 0x000007e0 r12: 0x00000190 lr: 0x080e3c21 pc: 0x080ddb18 hard fault on thread: thread1 thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- rttapp2 31 suspend 0x00000108 0x00000800 21% 0x00000003 000 tshell 12 suspend 0x00000184 0x00001000 23% 0x00000009 000 tidle0 31 ready 0x0000007c 0x00000400 13% 0x00000005 000 timer 10 suspend 0x00000080 0x00000400 17% 0x0000000a 000 main 10 suspend 0x00000148 0x00000800 60% 0x00000011 000 bus fault: SCB_CFSR_BFSR:0x82 PRECISERR SCB->BFAR:002008BE ``` 因为这个固件重新编译了,所以死机的PC跟上面发生了变化,但是大体上可以锁定了一个确定的位置,就是在这些库函数里面 ![QQ图片20201022104928.png](/uploads/20201022/c9d3a5c04bf5caea771fcd02f0a7afba.png)
XNXH_6023
2021-10-11
嵌入式、bsp、
楼主问题是否解决了? 我这边也是使用动态模块创建子线程遇到了同样的问题
1.4k
文武斌
27
74
貌似stm32f10x的应用模块在1.2.x版本不能正常编译
应用模块打开之后unload之后还在内存中
关于module.c的_load_shared_object的疑问
应用模块的rt_module_unload函数的bug
rtt 如何实现动态加载app
使用zmodem传输文件,应用模块文件传输完成,访问失败
RTT下应用模块编译具体方法
RTT应用模块编译出错
RTT应用模块编译问题
求问动态模块是什么意思呢
