GUI
LittlevGL_LVGL
LittlevGL_LVGL
LittleVGL2RTT软件包还有在维护吗,测试遇到一些问题求解
发布于 2020-11-03 14:23:07 浏览:1997
使用正点原子潘多拉开发板,rtthread studio,LittleVGL2RTT软件包,对接了LCD框架,可以显示界面 ![QQ图片20201103142027.png](/uploads/20201103/d0589049667959298ff2e847ef14c85d.png) 遇到的问题是屏幕分辨率240x240, 16位颜色,如果用帧缓冲需要115200字节的ram,潘多拉的(96+32)k字节不够用,用160x160正常使用 不用帧缓冲方式需要实现两个函数,实现之后不能正常显示
cheney
2020-11-06
LVGL支持三种缓存的配置: ```c /* LVGL requires a buffer where it draws the objects. The buffer's has to be greater than 1 display row * * There are three buffering configurations: * 1. Create ONE buffer with some rows: * LVGL will draw the display's content here and writes it to your display * * 2. Create TWO buffer with some rows: * LVGL will draw the display's content to a buffer and writes it your display. * You should use DMA to write the buffer's content to the display. * It will enable LVGL to draw the next part of the screen to the other buffer while * the data is being sent form the first buffer. It makes rendering and flushing parallel. * * 3. Create TWO screen-sized buffer: * Similar to 2) but the buffer have to be screen sized. When LVGL is ready it will give the * whole frame to display. This way you only need to change the frame buffer's address instead of * copying the pixels. * */ ``` 参见lv_port_disp_template.c中75行后面的示例代码,你可以选用第二种方法,其可以降低对于内存的消耗。
2k
277
58
[已解决]创建GUI显示线程,出现bus fault错误应该怎么解?
移植RTGUI后,使用RealBoard4088的按键驱动切换画面,出现一次按键,触发两次事件的异常
【已解决】keil中添加rtgui的demo程序的问题
RT-GUI触摸BUG?
【已解决】请问:如何把example目录下rtgui的例子添加到工程中
RT-GUI不需要开辟一块和屏尺寸相同的存储空间记录屏幕上的数据吗?
RT-GUI开发疑问?
RTGUI 发送消息队列失败
gui的汉字字库能只挑出自己使用的汉字编译吗?
建议RTGUI的汉字和BMP等方框绘图增加窗口支持
