STM32F407
硬石
rtt3.1.2使用PWM在我开发板上跑不起来
发布于 2020-11-13 15:17:14 浏览:1135
{{stm32f407-ys-explorer - test.zip(uploading...)}}{{stm32f407-ys-explorer - test.zip(uploading...)}}![捕获.PNG](/uploads/20201113/d2f71cf50016af7db289806ac129bf72.png) 想请大家看看我配置的PWM哪里出现了问题{{stm32f407-ys-explorer - test.zip(uploading...)}} #include "board.h" extern void HAL_TIM_MspPostInit(TIM_HandleTypeDef *htim); TIM_HandleTypeDef htim3; void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct; RCC_ClkInitTypeDef RCC_ClkInitStruct; __HAL_RCC_PWR_CLK_ENABLE(); //使能PWR时钟 __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1); //设置调压器输出电压级别1 RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE; // 外部晶振,8MHz RCC_OscInitStruct.HSEState = RCC_HSE_ON; //打开HSE RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; //打开PLL RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE; //PLL时钟源选择HSE RCC_OscInitStruct.PLL.PLLM = 8; //8分频MHz RCC_OscInitStruct.PLL.PLLN = 336; //336倍频 RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2; //2分频,得到168MHz主时钟 RCC_OscInitStruct.PLL.PLLQ = 7; //USB/SDIO/随机数产生器等的主PLL分频系数 HAL_RCC_OscConfig(&RCC_OscInitStruct); RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; // 系统时钟:168MHz RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; // AHB时钟: 168MHz RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4; // APB1时钟:42MHz RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2; // APB2时钟:84MHz HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5); HAL_RCC_EnableCSS(); // 使能CSS功能,优先使用外部晶振,内部时钟源为备用 // HAL_RCC_GetHCLKFreq()/1000 1ms中断一次 // HAL_RCC_GetHCLKFreq()/100000 10us中断一次 // HAL_RCC_GetHCLKFreq()/1000000 1us中断一次 HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000); // 配置并启动系统滴答定时器 /* 系统滴答定时器时钟源 */ HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK); /* 系统滴答定时器中断优先级配置 */ HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0); } void MX_TIM3_Init(void) { TIM_ClockConfigTypeDef sClockSourceConfig; TIM_MasterConfigTypeDef sMasterConfig; TIM_OC_InitTypeDef sConfigOC; htim3.Instance = TIM3; htim3.Init.Prescaler = 0; htim3.Init.CounterMode = TIM_COUNTERMODE_UP; htim3.Init.Period = 0; htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; if (HAL_TIM_PWM_Init(&htim3) != HAL_OK) { Error_Handler(); } sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL; HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig); sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET; sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK) { Error_Handler(); } sConfigOC.OCMode = TIM_OCMODE_PWM1; sConfigOC.Pulse = 0; sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH; sConfigOC.OCFastMode = TIM_OCFAST_DISABLE; if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_1) != HAL_OK) { Error_Handler(); } sConfigOC.Pulse = 0; if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_2) != HAL_OK) { Error_Handler(); } HAL_TIM_MspPostInit(&htim3); } **#include
** #include
#define PWM_DEV_NAME "pwm3" /* PWM设备名称 */ #define PWM_DEV_CHANNEL 1 /* PWM通道 */ struct rt_device_pwm *pwm_dev; /* PWM设备句柄 */ static int pwm_led_sample(int argc, char *argv[]) { rt_uint32_t period, pulse; period = 1000; /* 周期为0.5ms,单位为纳秒ns */ /* PWM脉冲宽度值的增减方向 */ pulse = 500; /* PWM脉冲宽度值,单位为纳秒ns */ /* 查找设备 */ pwm_dev = (struct rt_device_pwm *)rt_device_find(PWM_DEV_NAME); if (pwm_dev == RT_NULL) { rt_kprintf("pwm sample run failed! can't find %s device!\n", PWM_DEV_NAME); return RT_ERROR; } /* 设置PWM周期和脉冲宽度默认值 */ rt_pwm_set(pwm_dev, PWM_DEV_CHANNEL, period, pulse); /* 使能设备 */ rt_pwm_enable(pwm_dev, PWM_DEV_CHANNEL); /* 设置PWM周期和脉冲宽度 */ rt_pwm_set(pwm_dev, PWM_DEV_CHANNEL, period, pulse); } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(pwm_led_sample, pwm sample);
富士山下_LJH
2020-11-13
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base) { if(htim_base->Instance==TIM3) { /* USER CODE BEGIN TIM2_MspInit 0 */ /* USER CODE END TIM2_MspInit 0 */ /* Peripheral clock enable */ __HAL_RCC_TIM3_CLK_ENABLE(); /* USER CODE BEGIN TIM2_MspInit 1 */ /* USER CODE END TIM2_MspInit 1 */ } else if(htim_base->Instance==TIM11) { /* USER CODE BEGIN TIM11_MspInit 0 */ /* USER CODE END TIM11_MspInit 0 */ /* Peripheral clock enable */ __HAL_RCC_TIM11_CLK_ENABLE(); /* USER CODE BEGIN TIM11_MspInit 1 */ /* USER CODE END TIM11_MspInit 1 */ } else if(htim_base->Instance==TIM13) { /* USER CODE BEGIN TIM13_MspInit 0 */ /* USER CODE END TIM13_MspInit 0 */ /* Peripheral clock enable */ __HAL_RCC_TIM13_CLK_ENABLE(); /* USER CODE BEGIN TIM13_MspInit 1 */ /* USER CODE END TIM13_MspInit 1 */ } else if(htim_base->Instance==TIM14) { /* USER CODE BEGIN TIM14_MspInit 0 */ /* USER CODE END TIM14_MspInit 0 */ /* Peripheral clock enable */ __HAL_RCC_TIM14_CLK_ENABLE(); /* USER CODE BEGIN TIM14_MspInit 1 */ /* USER CODE END TIM14_MspInit 1 */ } } void HAL_TIM_MspPostInit(TIM_HandleTypeDef* htim) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(htim->Instance==TIM3) { /* USER CODE BEGIN TIM3_MspPostInit 0 */ /* USER CODE END TIM3_MspPostInit 0 */ __HAL_RCC_GPIOC_CLK_ENABLE(); /**TIM3 GPIO Configuration PC63 ------> TIM3_CH1 */ GPIO_InitStruct.Pin = GPIO_PIN_6; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; GPIO_InitStruct.Alternate = GPIO_AF2_TIM3; HAL_GPIO_Init(GPIOC, &GPIO_InitStruct); /* USER CODE BEGIN TIM2_MspPostInit 1 */ /* USER CODE END TIM2_MspPostInit 1 */ } } /** * @brief TIM_Base MSP De-Initialization * This function freeze the hardware resources used in this example * @param htim_base: TIM_Base handle pointer * @retval None */ void HAL_TIM_Base_MspDeInit(TIM_HandleTypeDef* htim_base) { if(htim_base->Instance==TIM3) { /* USER CODE BEGIN TIM2_MspDeInit 0 */ /* USER CODE END TIM2_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_TIM3_CLK_DISABLE(); /* USER CODE BEGIN TIM2_MspDeInit 1 */ /* USER CODE END TIM2_MspDeInit 1 */ } else if(htim_base->Instance==TIM11) { /* USER CODE BEGIN TIM11_MspDeInit 0 */ /* USER CODE END TIM11_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_TIM11_CLK_DISABLE(); /* USER CODE BEGIN TIM11_MspDeInit 1 */ /* USER CODE END TIM11_MspDeInit 1 */ } else if(htim_base->Instance==TIM13) { /* USER CODE BEGIN TIM13_MspDeInit 0 */ /* USER CODE END TIM13_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_TIM13_CLK_DISABLE(); /* USER CODE BEGIN TIM13_MspDeInit 1 */ /* USER CODE END TIM13_MspDeInit 1 */ } else if(htim_base->Instance==TIM14) { /* USER CODE BEGIN TIM14_MspDeInit 0 */ /* USER CODE END TIM14_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_TIM14_CLK_DISABLE(); /* USER CODE BEGIN TIM14_MspDeInit 1 */ /* USER CODE END TIM14_MspDeInit 1 */ } }
2020-11-13
代码请加标签,3个`(TAB键上面那个,也可以再写上语言名称,有更好的着色效果) https://club.rt-thread.org/ask/article/8.html ``` '''c static int goto_uboot(void) { } ''' ```
1.1k
富士山下_LJH
21
玩iot camera笔记之3测试试用3路pwm
[已解决]PWM输出异常分析
给RT-Thread添加PWM驱动框架
关于rt-thread-3.1.0 pwm
stm32f103ze 添加pwm 设备失败
