bug
rt_event_事件集
set
rt_event_recv bug
发布于 2020-12-01 16:31:12 浏览:1664
rt_event_recv 源码中 为了不出现重复代码,逻辑写的有些复杂,可以优化,用goto 或许会更清晰一些 ,或者适量的重复代码也可以让代码的阅读性更好。 比如能正常接收时直接处理返回。而不是用if else 拖到最后。 ``` rt_err_t rt_event_recv(rt_event_t event,rt_uint32_t set,rt_uint8_t option,rt_int32_t timeout,rt_uint32_t *recved) { struct rt_thread *thread; register rt_ubase_t level; register rt_base_t status; RT_DEBUG_IN_THREAD_CONTEXT; /* parameter check */ RT_ASSERT(event != RT_NULL); RT_ASSERT(rt_object_get_type(&event->parent.parent) == RT_Object_Class_Event); if (set == 0) return -RT_ERROR; /* initialize status */ status = -RT_ERROR; /* get current thread */ thread = rt_thread_self(); /* reset thread error */ thread->error = RT_EOK; RT_OBJECT_HOOK_CALL(rt_object_trytake_hook, (&(event->parent.parent))); /* disable interrupt */ level = rt_hw_interrupt_disable(); /* check event set */ /*判断触发模式*/ if (option & RT_EVENT_FLAG_AND){ /*判断事件触发条件是否满足或者大于 获取的逻辑与的要求 */ if ((event->set & set) == set) status = RT_EOK; } else if (option & RT_EVENT_FLAG_OR){ /*判断事件触发条件是否满足获取要求某一个条件 */ if (event->set & set) status = RT_EOK; } else{ /* either RT_EVENT_FLAG_AND or RT_EVENT_FLAG_OR should be set */ RT_ASSERT(0); } /*达到触发条件*/ if (status == RT_EOK) { /* set received event */ /*设置接受到的事件条件*/ if (recved) *recved = (event->set & set); /* received event */ /*如果条件触发是一次性的则将此条件清除*/ if (option & RT_EVENT_FLAG_CLEAR) event->set &= ~set; } else if (timeout == 0) /*未达到触发条件,且 不等待*/ { /* no waiting */ thread->error = -RT_ETIMEOUT; } else /*未达到触发条件,但是超时等待*/ { /* fill thread event info */ thread->event_set = set; thread->event_info = option; /* put thread to suspended thread list */ /*未达到触发条件 ,且设置超时等待,则将线程挂入事件等待链表,然后设置并启动线程定时器*/ rt_ipc_list_suspend(&(event->parent.suspend_thread), thread, event->parent.parent.flag); /* if there is a waiting timeout, active thread timer */ if (timeout > 0) { /* reset the timeout of thread timer and start it */ rt_timer_control(&(thread->thread_timer), RT_TIMER_CTRL_SET_TIME, &timeout); rt_timer_start(&(thread->thread_timer)); } /* enable interrupt */ rt_hw_interrupt_enable(level); /* do a schedule */ /*线程进入等待,切换任务,此处会挂起*/ rt_schedule(); if (thread->error != RT_EOK) { /* return error */ return thread->error; } /* received an event, disable interrupt to protect */ level = rt_hw_interrupt_disable(); /* set received event */ if (recved) *recved = thread->event_set; } /* enable interrupt */ rt_hw_interrupt_enable(level); RT_OBJECT_HOOK_CALL(rt_object_take_hook, (&(event->parent.parent))); return thread->error; } RTM_EXPORT(rt_event_recv); ``` 修改成这样是否会更好? ``` rt_err_t rt_event_recv(rt_event_t event,rt_uint32_t set,rt_uint8_t option, rt_int32_t timeout,rt_uint32_t *recved) { struct rt_thread *thread; register rt_ubase_t level; register rt_base_t status; RT_DEBUG_IN_THREAD_CONTEXT; /* parameter check */ RT_ASSERT(event != RT_NULL); RT_ASSERT(rt_object_get_type(&event->parent.parent) == RT_Object_Class_Event); if (set == 0) return -RT_ERROR; /* initialize status */ status = -RT_ERROR; /* get current thread */ thread = rt_thread_self(); /* reset thread error */ thread->error = RT_EOK; RT_OBJECT_HOOK_CALL(rt_object_trytake_hook, (&(event->parent.parent))); /* disable interrupt */ level = rt_hw_interrupt_disable(); /* check event set */ /*判断触发模式*/ if ((option & RT_EVENT_FLAG_AND) && ((event->set & set) == set) || /*判断事件触发条件是否满足获取要求某一个条件 */ (option & RT_EVENT_FLAG_OR) && (event->set & set)) /*判断事件触发条件是否满足或者大于 获取的逻辑与的要求 */ status = RT_EOK; else RT_ASSERT(0); /* either RT_EVENT_FLAG_AND or RT_EVENT_FLAG_OR should be set */ /*达到触发条件*/ if (status == RT_EOK){ thread->event_set = (event->set & set); goto _EXIT_OK; } if (timeout == 0) /*未达到触发条件,且 不等待*/ { /* no waiting */ thread->error = -RT_ETIMEOUT; goto _EXIT_ERR; } /*未达到触发条件,但是超时等待*/ /* fill thread event info */ thread->event_set = set; thread->event_info = option; /* put thread to suspended thread list */ /*未达到触发条件 ,且设置超时等待,则将线程挂入事件等待链表,然后设置并启动线程定时器*/ rt_ipc_list_suspend(&(event->parent.suspend_thread), thread, event->parent.parent.flag); /* if there is a waiting timeout, active thread timer */ /*这个地方 难道timeout 不是一定大于0 吗?*/ if (timeout > 0) { /* reset the timeout of thread timer and start it */ rt_timer_control(&(thread->thread_timer), RT_TIMER_CTRL_SET_TIME, &timeout); rt_timer_start(&(thread->thread_timer)); } /* enable interrupt */ rt_hw_interrupt_enable(level); /* do a schedule */ /*线程进入等待,切换任务,此处会挂起*/ rt_schedule(); //此处为什么要判断这个 ,不是很明白 if (thread->error != RT_EOK) { /* return error */ return thread->error; } /* received an event, disable interrupt to protect */ level = rt_hw_interrupt_disable(); _EXIT_OK: /*设置接受到的事件条件*/ if (recved) *recved = (event->set & set); /* received event */ /*如果条件触发是一次性的则将此条件清除*/ if (option & RT_EVENT_FLAG_CLEAR) event->set &= ~set; _EXIT_ERR: rt_hw_interrupt_enable(level); RT_OBJECT_HOOK_CALL(rt_object_take_hook, (&(event->parent.parent))); return thread->error; } ```
mysterywolf
2020-12-01
c语言中,goto要慎用。尤其是这段代码已经经过10多年的检验,不可能无缘无故重新换成一种高风险的写法。 后续RTT会进行一些安全类的认证,例如MISRA2004 2012中都禁止使用goto语法。 另外问一下这个函数发现什么bug了吗?
1.7k
楼兰听雨
rt_thread事件某位如何置0,如何简单获取某位状态
有单独清除事件标志的函数么?
rt_event事件问题
事件集的选择清除重置事件标志位
Nano 内核FinSH 的 list_event 查询问题
Nano 初始化两次 event,使用list_event 导致的问题
关于事件集和邮箱那一块
rt-thread事件集多线程接收的一个疑问?
事件集在中断服务函数与线程之间的同步的疑问
生产者消费者中是否可以使用一个事件集来代替多个二值信号量?
