安装
失败
studio 安装失败
发布于 2020-12-07 11:35:21 浏览:838
公司之前有加密系统 我申请帮我卸载了。 就是想测试下RTT ide 好不好用 。。已经够给力的了!!!!!! 因为之前跑 跑不通的嘛 然后是因为加密的原因。。。也不知道 这IDE到底怎么了。。安装失败。。。 log 如下:`!SESSION 2020-12-07 11:30:19.870 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.ui 2 0 2020-12-07 11:30:24.073 !MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point. !SUBENTRY 1 org.eclipse.ui 2 0 2020-12-07 11:30:24.073 !MESSAGE Cannot bind to an undefined command: plug-in='com.genuitec.eclipse.theming.ui', id='com.genuitec.myeclipse.help.darktheme.commandid' !ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2020-12-07 11:30:27.909 !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt". !STACK 0 java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons: C:\Users\Dawn\.swt\lib\win32\x86_64\chromium-3071\chrome_elf.dll: Can't load this .dll (machine code=0x1d) on a AMD 64-bit platform Can't load library: C:\Users\Dawn\.swt\lib\win32\x86_64\C:\Users\Dawn\.swt\lib\win32\x86_64\chromium-3071\chrome_elf.dll at org.eclipse.swt.internal.Library.loadLibrary(Library.java:329) at org.eclipse.swt.internal.chromium.CEFFactory.create(CEFFactory.java:30) at org.eclipse.swt.chromium.Chromium.loadLib(Chromium.java:1654) at org.eclipse.swt.chromium.Chromium.
(Chromium.java:103) at org.eclipse.swt.chromium.Browser.
(Browser.java:32) at org.rtthread.studio.application.login.LoginPage.createBrowserLogin(LoginPage.java:77) at org.rtthread.studio.application.login.LoginAction.login(LoginAction.java:29) at org.rtthread.studio.application.login.LoginAction.run(LoginAction.java:24) at org.rtthread.studio.application.ApplicationWorkbenchWindowAdvisor.login(ApplicationWorkbenchWindowAdvisor.java:803) at org.rtthread.studio.application.ApplicationWorkbenchWindowAdvisor.postWindowCreate(ApplicationWorkbenchWindowAdvisor.java:786) at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:784) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001) at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:139) at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:95) at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:77) at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1559) at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1530) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:910) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:118) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.lambda$2(WorkbenchSourceProvider.java:671) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89) at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1193) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1054) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1064) at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1543) at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2193) at org.eclipse.swt.widgets.Control.windowProc(Control.java:4765) at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:348) at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1502) at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2153) at org.eclipse.swt.widgets.Display.windowProc(Display.java:4770) at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method) at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:211) at org.eclipse.swt.widgets.Shell.open(Shell.java:1263) at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:747) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:693) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:781) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:752) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:746) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:730) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1099) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156) at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:642) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:569) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151) at org.rtthread.studio.application.Application.start(Application.java:154) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595) at org.eclipse.equinox.launcher.Main.run(Main.java:1501) !ENTRY org.eclipse.osgi 4 0 2020-12-07 11:30:27.987 !MESSAGE 应用程序错误 !STACK 1 java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons: C:\Users\Dawn\.swt\lib\win32\x86_64\chromium-3071\chrome_elf.dll: Can't load this .dll (machine code=0x1d) on a AMD 64-bit platform Can't load library: C:\Users\Dawn\.swt\lib\win32\x86_64\C:\Users\Dawn\.swt\lib\win32\x86_64\chromium-3071\chrome_elf.dll at org.eclipse.swt.internal.Library.loadLibrary(Library.java:329) at org.eclipse.swt.internal.chromium.CEFFactory.create(CEFFactory.java:30) at org.eclipse.swt.chromium.Chromium.loadLib(Chromium.java:1654) at org.eclipse.swt.chromium.Chromium.
(Browser.java:32) at org.rtthread.studio.application.login.LoginPage.createBrowserLogin(LoginPage.java:77) at org.rtthread.studio.application.login.LoginAction.login(LoginAction.java:29) at org.rtthread.studio.application.login.LoginAction.run(LoginAction.java:24) at org.rtthread.studio.application.ApplicationWorkbenchWindowAdvisor.login(ApplicationWorkbenchWindowAdvisor.java:803) at org.rtthread.studio.application.ApplicationWorkbenchWindowAdvisor.postWindowCreate(ApplicationWorkbenchWindowAdvisor.java:786) at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:784) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001) at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:139) at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:95) at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:77) at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1559) at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1530) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:910) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:118) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.lambda$2(WorkbenchSourceProvider.java:671) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89) at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1193) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1054) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1064) at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1543) at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2193) at org.eclipse.swt.widgets.Control.windowProc(Control.java:4765) at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:348) at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1502) at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2153) at org.eclipse.swt.widgets.Display.windowProc(Display.java:4770) at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method) at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:211) at org.eclipse.swt.widgets.Shell.open(Shell.java:1263) at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:747) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:693) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:781) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:752) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:746) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:730) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1099) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156) at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:642) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:569) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151) at org.rtthread.studio.application.Application.start(Application.java:154) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595) at org.eclipse.equinox.launcher.Main.run(Main.java:1501) !ENTRY org.eclipse.e4.ui.workbench 4 0 2020-12-07 11:30:28.003 !MESSAGE !STACK 0 java.lang.NullPointerException at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:212) at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:230) at org.eclipse.ui.part.WorkbenchPart.dispose(WorkbenchPart.java:103) at org.eclipse.ui.internal.views.markers.ExtendedMarkersView.dispose(ExtendedMarkersView.java:622) at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.invalidate(CompatibilityPart.java:264) at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.destroy(CompatibilityPart.java:424) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966) at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:462) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:159) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:81) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:77) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:187) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:102) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:144) at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:911) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:233) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:140) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:132) at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:194) at org.eclipse.osgi.container.Module.publishEvent(Module.java:483) at org.eclipse.osgi.container.Module.doStop(Module.java:641) at org.eclipse.osgi.container.Module.stop(Module.java:505) at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:207) at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:213) at java.lang.Thread.run(Thread.java:748) !ENTRY org.eclipse.e4.ui.workbench 4 0 2020-12-07 11:30:28.019 !MESSAGE FrameworkEvent ERROR !STACK 0 org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTException: Device is disposed at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966) at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:462) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:159) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:81) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:77) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:187) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:102) at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:144) at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:911) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:233) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:140) at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:132) at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:194) at org.eclipse.osgi.container.Module.publishEvent(Module.java:483) at org.eclipse.osgi.container.Module.doStop(Module.java:641) at org.eclipse.osgi.container.Module.stop(Module.java:505) at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:207) at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:213) at java.lang.Thread.run(Thread.java:748) Caused by: org.eclipse.swt.SWTException: Device is disposed at org.eclipse.swt.SWT.error(SWT.java:4595) at org.eclipse.swt.SWT.error(SWT.java:4510) at org.eclipse.swt.SWT.error(SWT.java:4481) at org.eclipse.swt.widgets.Display.error(Display.java:1185) at org.eclipse.swt.widgets.Display.asyncExec(Display.java:681) at org.eclipse.ui.internal.WorkbenchWindow$6.changed(WorkbenchWindow.java:735) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:117) at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:365) at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:380) at org.eclipse.e4.ui.internal.services.ContextContextService.setEventCaching(ContextContextService.java:130) at org.eclipse.e4.ui.internal.services.ContextContextService.deferUpdates(ContextContextService.java:88) at org.eclipse.ui.internal.contexts.ContextService.deferUpdates(ContextService.java:93) at org.eclipse.ui.internal.contexts.ContextService.deactivateContexts(ContextService.java:208) at org.eclipse.ui.internal.contexts.SlaveContextService.dispose(SlaveContextService.java:208) at org.eclipse.ui.internal.PartSite.dispose(PartSite.java:366) at org.eclipse.ui.internal.ViewSite.dispose(ViewSite.java:60) at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.disposeSite(CompatibilityPart.java:446) at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.disposeSite(CompatibilityView.java:278) at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.internalDisposeSite(CompatibilityPart.java:437) at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.invalidate(CompatibilityPart.java:272) at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.destroy(CompatibilityPart.java:424) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58) ... 27 more `
rcp
2020-12-07
C:/Users/Dawn/.swt/lib/win32/x86_64/chromium-3071/chrome_elf.dll 检查下这个文件存在吗,如果不存在可能被杀毒软件误删了, 存在的话确认下是否被加密了,导致studio无法加载呢 ?
838
keyq
23
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
【学习分享】初探RT-Thread系统调度
