SPI-FLASH 文件系统 SPIFFS
发布于 2015-10-12 21:31:11 浏览:4544
[https://github.com/pellepl/spiffs](https://github.com/pellepl/spiffs) SPIFFS支持的特性: - Specifically designed for low ram usage - Uses statically sized ram buffers, independent of number of files - Posix-like api: open, close, read, write, seek, stat, etc - It can be run on any NOR flash, not only SPI flash - theoretically also on embedded flash of an microprocessor - Multiple spiffs configurations can be run on same target - and even on same SPI flash device - Implements static wear leveling - Built in file system consistency checks SPIFFS不支持的特性: - Presently, spiffs does not support directories. It produces a flat structure. Creating a file with path "tmp/myfile.txt" will create a file called "tmp/myfile.txt" instead of a "myfile.txt" under directory "tmp". - It is not a realtime stack. One write operation might take much longer than another. - Poor scalability. Spiffs is intended for small memory devices - the normal sizes for SPI flashes. Going beyond ~128MB is probably a bad idea. This is a side effect of the design goal to use as little ram as possible. - Presently, it does not detect or handle bad blocks.
4.5k
ljt8015
140
BBB的SPI驱动
求个SPI上挂两个或多个设备的使用例子
SPI设备有个bug
SPI驱动
请教rt_spi_configure函数理解
SPI FLASH挂载的问题
求助一个完整的 spi flash 驱动
关于同时使用文件系统与SPI FLASH的问题
RTT 可以移植到dsPIC单片机上么?
