任务调度
rt-thread 切换问题
发布于 2020-12-16 17:15:42 浏览:874
下面是任务调度的log: ``` start scheduler: max priority 0x20 startup a thread:tidle0 with priority:31 thread resume: tidle0 insert thread[tidle0], the priority: 31 startup a thread:led with priority:1 thread resume: led insert thread[led], the priority: 1 remove thread[led], the priority: 1 log: rt_led_running thread suspend: led remove thread[led], the priority: 1 remove thread[tidle0], the priority: 31 [0]switch to priority#31 thread:tidle0(sp:0x20008020), from thread:led(sp: 0x20008220) log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running log: rt_idle_running insert thread[led], the priority: 1 insert thread[tidle0], the priority: 31 remove thread[led], the priority: 1 [1]switch to priority#1 thread:led(sp:0x200081d8), from thread:tidle0(sp: 0x20008020) switch in interrupt ``` 到了 swich in interrupt 后出错,程序跳入到数据异常中断中去。 任务在第一次从led 切换到空闲任务的时候没有问题,到是任务从空闲切换到led的时候程序跳入数据异常中断错误中去,看log 任务切换的时候两个任务的sp没有问题感觉内存上应该没有问题,任务在switch in interrupt切换的时候死机,原因大概是在哪一块的
2020-12-16
别新发贴了,你用了一个新芯片,用了一个新编译器。 请先找个已移植好的平台学习对比下。
874
hfmm
30
RTT3.1.3低优先级任务delay后不能就绪的问题
rt_hw_context_switch_interrupt的逻辑
rt_schedule()函数里面,线程处于运行状态,为什么还要从就绪链表移除
好像一直不能回到线程里面
RT-thread任务调度的BUG
RT-thread任务调度的严重BUG
多传感器的任务调度问题
为什么RTT中空闲线程永远不能被挂起?
studio设置ROM启动地址和向量偏移后,无法进入任务调度
二个线程运行一会后,卡死在TK1线程,无法进行调度了
