使用fal把外置w25q128 进行分区 原来的设想是分四个区
#define FAL_PART_TABLE \
{FAL_PART_MAGIC_WORD, "download", NOR_FLASH_DEV_NAME, FLASH_DOWNLOAD_ADDR, FLASH_DOWNLOAD_SIZE, 0}, \
{FAL_PART_MAGIC_WORD, "factory", NOR_FLASH_DEV_NAME, FLASH_FACTORY_ADDR, FLASH_FACTORY_SIZE, 0}, \
{FAL_PART_MAGIC_WORD, "romfs", NOR_FLASH_DEV_NAME, FLASH_ROMFS_ADDR, FLASH_ROMFS_SIZE, 0}, \
{FAL_PART_MAGIC_WORD, "filesystem", NOR_FLASH_DEV_NAME, FLASH_FATS_ADDR, FLASH_FATS_SIZE, 0}, \
其中romfs分区用来挂载 romfs文件系统 创建
const struct romfs_dirent _root_dirent[] =
{ROMFS_DIRENT_DIR, "easyflash", RT_NULL, 0},
{ROMFS_DIRENT_DIR, "download", RT_NULL, 0},
{ROMFS_DIRENT_DIR, "user", RT_NULL, 0},
{ROMFS_DIRENT_DIR, "factory", RT_NULL, 0},
const struct romfs_dirent romfs_root =
ROMFS_DIRENT_DIR, "/", (rt_uint8_t *)_root_dirent, sizeof(_root_dirent) / sizeof(_root_dirent[0])
flash_dev = fal_blk_device_create(FS_ROMFS_NAME);
if (flash_dev == NULL){
LOG_D("Can't create a block device on '%s' partition.\n", FS_ROMFS_NAME);
return -1;
//romfs分区 rom文件系统挂载到 /
if (dfs_mount(FS_ROMFS_NAME, "/", "rom", 0, &(romfs_root)) != 0)
if(dfs_mkfs("rom", FS_ROMFS_NAME) != 0)
LOG_E("Failed to initialize romfs! ");
else {
dfs_mount(FS_ROMFS_NAME, "/", "rom", 0, &(romfs_root));
四个文件夹 再将elm 挂载到/user 目录下
flash_dev = fal_blk_device_create(FS_FATS_NAME);
LOG_D("Can't create a block device on '%s' partition.\n", FS_FATS_NAME);
return -1;
//filesystem分区 elm文件系统挂载到/user
if (dfs_mount(FS_FATS_NAME, "/user", "elm", 0, 0) != 0)
if(dfs_mkfs("elm", FS_FATS_NAME) != 0)
LOG_E("Failed to initialize filesystem! ");
else {
dfs_mount(FS_FATS_NAME, "/user", "elm", 0, 0);
发现 我使用tftp 的时候
msh /user/webnet>tftp -s
tftp server is runmsh /user/webnet>server write file err! disconnect client
msh /user/webnet>
msh /user/webnet>
msh /user/webnet>
msh /user/webnet>
我就好奇了 这为啥不行
然后 我就直接把elm文件系统直接挂载在根目录下
return -1;
if (dfs_mount(FS_FATS_NAME, "/", "elm", 0, 0) != 0)
else {
dfs_mount(FS_FATS_NAME, "/", "elm", 0, 0);
tftp 就可以了 。。。。。
搞不懂 那要这个romfs干啥?
我的意思 是想把我的/目录下的文件都设置成只读的 然后fatfs 是可读可写的 但是我这样挂载的话 我都不能从外面写入文件到我的fatfs中 那我要这个romfs干啥。。。
