mbedtls
求助 mbedtls 验证 CA 证书的问题
发布于 2021-01-14 12:09:17 浏览:1925
项目要用过HTTPS,用的STM32F411RE芯片,移植了官网的mbedtls-v2.7.10包,运行包里的tls_app_test例程时,报错 ``` [E/mbedtls.clnt] verify peer certificate fail.... [E/mbedtls.clnt] verification info: ! The certificate is not correctly signed by the trusted CA1. ``` 按步骤下的官网证书,没有优化TLS配置 附连接过程 ``` [D/mbedtls.clnt] Set debug level (2) [D/mbedtls.clnt] mbedtls client struct init success... [D/mbedtls.clnt] Loading the CA root certificate success... [D/mbedtls.clnt] mbedtls client context init success... [D/mbedtls.clnt] Connected www.rt-thread.org:443 success... [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:6850: => handshake [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 0 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 1 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:0777: => write client hello [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2867: => write record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2592: message length: 390, out_left: 390 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2599: ssl->f_send() returned 390 (-0xfffffe7a) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2626: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3025: <= write record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:1100: <= write client hello [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 2 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:1493: => parse server hello [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3904: => read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 5, nb_want: 70 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 5, nb_want: 70 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 65 (-0xffffffbf) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3937: <= read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:1775: server hello, total extension length: 21 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:1964: <= parse server hello [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 3 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:4513: => parse certificate [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3904: => read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 5, nb_want: 2693 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 5, nb_want: 2693 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 1973 (-0xfffff84b) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 1978, nb_want: 2693 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 715 (-0xfffffd35) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3937: <= read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:4786: x509_verify_cert() returned -9984 (-0x2700) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:4883: <= parse certificate [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 4 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:2311: => parse server key exchange [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3904: => read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 5, nb_want: 338 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 5, nb_want: 338 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 333 (-0xfffffeb3) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3937: <= read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:2024: ECDH curve: secp256r1 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:2253: Server used SignatureAlgorithm 1 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:2254: Server used HashAlgorithm 6 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:2612: <= parse server key exchange [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:2645: => parse certificate request [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3904: => read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 5, nb_want: 9 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 5, nb_want: 9 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 4 (-0xfffffffc) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3937: <= read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:2794: <= parse certificate request [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 6 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:2804: => parse server hello done [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3904: => read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3933: <= reuse previously read message [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3937: <= read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:2834: <= parse server hello done [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 7 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:4396: => write certificate [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:4413: <= skip write certificate [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 8 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:2846: => write client key exchange [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2867: => write record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2592: message length: 75, out_left: 75 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2599: ssl->f_send() returned 75 (-0xffffffb5) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2626: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3025: <= write record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3088: <= write client key exchange [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 9 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3139: => write certificate verify [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:0513: => derive keys [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:0985: <= derive keys [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3160: <= skip write certificate verify [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 10 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:4899: => write change cipher spec [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2867: => write record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2592: message length: 6, out_left: 6 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2599: ssl->f_send() returned 6 (-0xfffffffa) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2626: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3025: <= write record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:4913: <= write change cipher spec [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 11 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:5432: => write finished [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:5257: => calc finished tls sha256 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:5287: <= calc finished [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2867: => write record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:1313: => encrypt buf [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:1635: <= encrypt buf [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2592: message length: 45, out_left: 45 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2599: ssl->f_send() returned 45 (-0xffffffd3) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2626: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3025: <= write record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:5541: <= write finished [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 12 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3293: => parse new session ticket [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3904: => read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 5, nb_want: 207 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 5, nb_want: 207 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 202 (-0xffffff36) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3937: <= read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3384: <= parse new session ticket [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 12 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:4922: => parse change cipher spec [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3904: => read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 5, nb_want: 6 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 5, nb_want: 6 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 1 (-0xffffffff) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3937: <= read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:5000: <= parse change cipher spec [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 13 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:5558: => parse finished [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:5257: => calc finished tls sha256 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:5287: <= calc finished [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3904: => read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 0, nb_want: 5 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2358: => fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2515: in_left: 5, nb_want: 45 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2539: in_left: 5, nb_want: 45 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2541: ssl->f_recv(_timeout)() returned 40 (-0xffffffd8) [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2561: <= fetch input [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:1649: => decrypt buf [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2198: <= decrypt buf [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:3937: <= read record [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:5626: <= parse finished [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 14 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3511: handshake: done [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_cli.c:3400: client state: 15 [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2574: => flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:2586: <= flush output [D/mbedtls.clnt] packages\mbedtls-v2.7.10\mbedtls\library\ssl_tls.c:6860: <= handshake [E/mbedtls.clnt] verify peer certificate fail.... [E/mbedtls.clnt] verification info: ! The certificate is not correctly signed by the trusted CA ```
2021-01-14
## 建议 * `MBEDTLS_SSL_VERIFY_REQUIRED` 改为 `MBEDTLS_SSL_VERIFY_NONE` 禁用校验 * 把网站证书颁发机构的CA加进来。空间够的话,可以像浏览器那样全加进来。
1.9k
ysjsskhn
libcurl2rtt编译失败
rt-thread + mbedTLS 连接阿里云ssl握手不成功
rt-thread+polarssl https连接阿里云握手失败?
mbedtls+ stm32f411 握手耗时15s
mbedtls 定义全局变量就会死机
MbedTLS软件包编译失败 unknown type name 'DIR'
mbedtls/config.h文件缺失
mbedtls_client_read data error 错误
socket使用SAL TLS没有反应
Server 层的TLS案例
MCXN947测评系列(二)串口设备测评
