int main(void)
int ret = 0;
int sock, bytes_received;
struct server_addr;
/* 通过网卡名称获取网卡对象,名称可以通过 ifconfig 命令查看 */
struct netdev *netdev = netdev_get_by_name("W5500");
if (netdev == RT_NULL)
rt_kprintf("not find network interface device name().\n");
return 0;
/* 设置默认网卡对象 */
netdev_set_default(netdev);
if(sock != RT_NULL)
closesocket(sock);
sock = RT_NULL;
/* 创建一个socket,类型是SOCKET_STREAM,TCP类型 */
if ((sock = socket(AF_INET, SOCK_STREAM, 0)) == -1)
/* 创建socket失败 */
rt_kprintf("Socket error");
sock = RT_NULL;
/* 初始化预连接的服务端地址 */
struct hostent *host = gethostbyname("192.168.1.203");
struct sockaddr_in server_addr;
server_addr.sin_family = AF_INET;
server_addr.sin_port = htons(9600);
server_addr.sin_addr = *((struct in_addr *)host->h_addr);
rt_memset(&(server_addr.sin_zero), 0, sizeof(server_addr.sin_zero));
/* 连接到服务端 */
if (connect(sock, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)) == -1)
/* 连接失败 */
rt_kprintf("Connect fail!");
closesocket(sock);
/*释放接收缓冲 */
return 0;
//开启线程
dt_test_isWhile = 1;
dt_test_runing = 1;
rt_thread_t tid;
tid = rt_thread_create("os_test", dt_WIZ_test_thread_entry, &sock,
1024, (RT_THREAD_PRIORITY_MAX / 3), 20);
RT_ASSERT(tid != RT_NULL);
rt_thread_startup(tid);
rt_thread_mdelay(10000);
closesocket(sock);
void dt_WIZ_test_thread_entry(void *parameter)
int sock = *(int*)(parameter);
char *dev_data_buff = rt_calloc(1,BUFSZ);
int dev_bytes_received;
int ret,i=5;
if (dev_data_buff == RT_NULL)
rt_kprintf("No memory");
return;
while(dt_test_isWhile)
//接收设备数据
dev_bytes_received = recv(sock, dev_data_buff, BUFSZ - 1, 0);
rt_thread_mdelay(10); //等待dt_pass_through_stop关闭sock,防止多次关闭同一个sock
//cmd_printf(1,dev_data_buff,dev_bytes_received); //打印发送数据
//发送设备数据到网络
if(dev_bytes_received>0)
ret = send(sock, dev_data_buff, dev_bytes_received, 0);
if (ret <= 0)
/* 接收失败,关闭这个连接 */
if(sock!=RT_NULL)
closesocket(sock);
rt_kprintf("thr_web_sock send error %d,close the socket.",ret);
dt_test_isWhile = 0;
dt_test_runing = 0;
rt_kprintf("quit.");
问题:在main线程创建线程,w5500开启堵塞接收recv(sock, dev_data_buff, BUFSZ - 1, 0);,main函数中延时closesocket(sock);此事会出错wiz_recvfrom函数的wiz_do_event_changes中rt_wqueue_wakeup死掉。
目的:在一个堵塞的socket中接收线程中要怎么跳出堵塞函数除了关闭socket
如果不支持多线程操作同一个socket,如何跳出接收堵塞呢?除了设置socket接收超时还有其他的方法吗?
只有网络断开才能退出了
可以用select的方式来做,不用阻塞
select的方式研究了一下,不太会用,现在暂时用的socket接收超时做的
